I was playing with mine over garburn pass today, and cant work out if it helps or not.. in the end i just reverted back to normal, as even with the blowoff threshold set to minimum they still felt a bit wooden, and sometimes it seemed harder to get over rocks as the forks didnt compress straight away.
I’ve only got 100mm travel forks, (F100RLC) and am on an epic which climbs well anyway so maybe not much point using it on this, but just wondered when people use theres? Do you keep turning it on + off for long climbs / descents, of just leave it on and use the blowoff feature.
Bit of a suspension numpty…
I just started playuing with it really as i had the forks serviced at TFT, and they sent it back with some recommended settings and there was one for the lockout threshold (blowoff) so i thought i’d give them a try.
