Hexus = heavy, rusty and tyre levers that snap. Lezyne SV10 has never let me down and still looks new 8 years later. Hexus is a discarded, rusty lump.
Yeah tell me about it brother! Hexus support group right here.
It’s made from cast iron coated in tin foil. Initially it’s nice and shiney, so ideal if you need to signal an SOS when you’ve come to fix your bike and realise the tool’s not upto the job. But keep it in a backpack or saddle bag and the tin foil gets rubbed off, leaving a rusty lump behind.
Then you’ve got the 8mm hex key bit, which is slid onto the 5mm allen key. Every time you need to use the 5mm allen key, you have to remove the 8mm bit first, which isn’t too much of a problem unless they’re rusted together!!!!
As for the chain tool; FML. You have to use one of the (separate) plastic tyre levers to operate it. So you’ve got a rusty lump of iron in one hand, a little bit of brittle plastic (that’s probably half **** after you tried to use it to remove a tyre) in the other hand, and then a oily chain in the other hand, and yeh, you don’t have three hands!! All of this on a freezing cold mid November evening. You’re better off leaving the Hexus at home and just taking your mobile phone so you can call for a lift if needed.
It got to the point where I was scared to ride my bike incase I had a mechanical and I had to use the Hexus.
