Changing the switch that operates the glass hatch on my X type estate. The switch has an aluminium body that sits over a steel tube. It’s nicely corroded together. Any tips for separating them? Given that its going through glass violence isn’t an option.
Second problem is on the inside of the glass. There’s a steel assembly that bolts to the glass. No problem with that. There’s also little rubber pad that’s been glued rather untidily when the main dealer changed the switch 5 years ago. Any ideas for weakening the glue enough to get the parts apart?
I know it’s not a bike but I can’t go ride until its fixed.
