Hi
The Aeris runs a 63mm stroke shock, and has 140 / 150mm travel modes.
This makes the leverage ratio 2.22 or 2.38, both of which I consider to be low. Aeris does not need much damping from the rear shock due to the low leverage ratio.
In regard to the CCDB (reliablity aside for a moment), this shock (either variant) needs setting up carefully. If set up badly, the CCDB will perform worse than a RS monarch or X-Fusion O2. Too much damping combined with the low leverage ratio will kill the activity of the suspension, leaving it feeling “dead”.
If set up well then the CCDB is an excellent performer that can be tuned to suit most riders. This is important to consider when reading reviews, as the reviewer may not have taken the time (a day on the trails fiddling with dials) to set up the shock before conducting the review. The monarch and O2 shocks on the other hand work much better “out of the box”.
In terms of the difference between the inline and piggyback versions of the CCDB, jemima was correct above – the extra surface area and oil volume keep the temperature (and thus damping) more stable over long runs.
I hope this helps!
Dan (Aeris designer)
