go to a professional. It can be surprisingly fairly priced. Ring around, especially the mobile guys.
If your aircon is not working then you’ll likely already have lost the refrigerant already.
A common cause of refrigerant loss is a damaged condenser: holes from stones being thrown up from the road. Professionals will check the system, regas, check for leaks and leave you with a properly gassed, lubed and set system. If your condenser is damaged then they may offer a better price and speed for replacement than a dealer.
Or, you could just leave it, open the window and enjoy the warmth. After this warm spell you won’t need your aircon again until you need to demist the windows in, ooh, September?
