Just a quick off topic question before I raise this issue with the powers that be…can’t really find an answer on Google but I think I know what it will be.
Situation:
Flight of external stairs, at top is a steel gate that opens away from the stairs across the landing. There is no landing on the outside, you unlock the gate with a key whilst standing on the stairs and then it opens away from you across the landing. Is this permitted? I know it definately wouldn’t be allowed to open the other way, over the stairs… (it was installed in the past three or four years)
The issue is compounded as it has a heavy self closing mechanism to open against, and it can only be partially opened due to mechanism being poorly designed/installed, so you have to manouver round the gate to get off the stairs.
It is the main/only access to the building except for fire exits.
