I've got an old Hope O2 brake with a Pro lever, when working it is great, loads of power.
But at the moment it is broken. Not sure what is wrong but when I pull the lever it brakes effectivley but the lever doesn't return (and no the bolts holding the lever on are not too tight), also not sure but the piston may be sticky on one side.
I have all the spare parts (lever rebuild kit, seals, brake fluid, tool) to do it myself but just wondering about getting Hope/a shop to do it to save the diagnosis hassle.
Any idea how much this would cost or if you are the opinion I should not be so lazy and do it myself then what do you think I should do first to solve the problems?
keppoch
