The new On-One Jones...
that is lovely.
650b+, 3 inch fat tyres and similar outside diameter to 29er
(Pure speculation here)
There's a lot of tubes going on there, so won't be light...very interesting though!
Desperately carving a new niche?
Gopping
Is it stainless, or just polished before painting?
953?
its a bike.
Would be nice if it was 953, I know Cotic tried it but they just snap apparently
Wasn't the problem with the cotic that they made it lighter than the 853 tubes but the same strength, so it was quite flexy, then did eventualy snap? Not an inherent problem of 953, just that for MTB tubesets there was no way to make it better than 853 as it's already the optimum ammounts stiffnes to strength.Would be nice if it was 953, I know Cotic tried it but they just snap apparently
650b+, 3 inch fat tyres and similar outside diameter to 29er(Pure speculation here)
Surly instigator got there first (on my list of "things to look out for in the sales because it's not great VFM at the moment")
[img]
[/img]
Instigator is 26+ making it similar or slightly bigger than 650b. 650b+ would just be the same size as a normal 29er pretty much...
Gopping
Just one of the worst words. It's awful.
Boom tish.
Yeah. It's going to be no lightweight.
A comment from [url= http://singletrackworld.com/forum/topic/stooge-cycles-whos-interested-slack-29er-content#post-5740626 ]this thread[/url] made me start thinking about this frame. So yeah - stays are unbraced until they meet the other top tube. Will be interesting to see what happens.
Seat tube is heavily bent over to see if we can induce some flex.
It'll be a really interesting test of "vertical compliance".
Someone's meant to be making me a titanium one too.
0.9/0.6/0.9 chromoly, cleaned for welding.
Almost a soft-tail then? Nice!
Laterally stiff though? 😉
Jones-a-like attempt to get some actual vertical movement at the rear then?
I remember early alloy lugged carbin tubed Trek bikes had interesting flex in all directions. Super noodle was the nick name for my mates...
I'm unclear how Jones does that, as those frames look quite triangulated and braced. I can see how the Jones seat tube could bend backwards and forwards.
We'll see.
He's got a video somewhere on his website showing apparent movement while riding, I can't remember where the camera is mounted though.
Edit- Here it is:
Exactly, The advantage is you can make it lighter but it ends up being very flexy (very thin tubing is used with 853 as it is) and it did eventually snap, I beleive Cy has it on his wall somewhere.
Back to the on-one will be very interested in knowing how the vertical give experiment works out, and how much lateral flex it induces
My Cotic 931 hasn't snapped but it is a little bit flexy-makes it more comfortable- I'm quite glad of that in my advancing years.
It isn't lighter than 853 except for the lack of paint apparently
Ooops, edited as I realise it is 931 not 953
Ah so there are some (at least one) out there! Is it on Soul geometry? is it all 953 or just parts? (ie the Bfe with 853 in parts of it?)
see edited version!
Back on topic, if the chainstays can flex enough, why not just do what softails used to and put an elastomer shock absorber in the seatstay?
Because complex tubing is more nice, and also more niche! 🙂
So just to clarify is the wheel size 650b+ ?
Or make a carbon fibre frame with a proper shock that weighs less.
I dunno. It's just an itch I wanted to scratch.
[quote=thepurist ]It'll be a really interesting test of "vertical compliance".
Leaving aside the meme, I'd be worried about torsion.
Have you ever thought about FEA to see what happens rather than prototyping something that may be crap?
cor, a second jeff inspired copy, its nice to know his geometry has stood the test of time. It'll all be 51-55 degree offset rigid forks next to mimic the truss fork geometry.....
I'm quite surprised no one posted this yet with regards to this thread (or any other on-one/Planet X thread)[url= http://i.ebayimg.com/00/s/MTIwMFgxMjAw/z/LXkAAOSwq5lToGAu/$_57.JP G" target="_blank">http://i.ebayimg.com/00/s/MTIwMFgxMjAw/z/LXkAAOSwq5lToGAu/$_57.JP G"/> [/img][/url]
You wanted to scratch a Jones itch?
I have a hunch the seat tube won't flex much.
And before any pedantic gits pick it up, yes I know offset is in mm not degrees...just a senior moment 😀
Amazing.
If Brant wont say what it is, then allow me... it's a woman's shopping bike and goes by the moniker La Menstrual Cycle.
Almost-soft-tail. I like it.
If the chainstays do not connect to the seat tube (I initially thought that was how the Jones was designed) I predict a lot of twist in the rear wheel, you may get some vertical flex but a lot of torsional flex too. Ok I'm no engineer - so it's just an opinion 🙂 ! Goes and has a look at a real Spaceframe - the three top tube/extended seat stays are all connected to form a virtual tube that has quite a large diameter, which provides the lateral stiffness. The curved centre tube allows for some (small) flex in the seat tube, which is aided by having a long flexible 27.2mm seatpost, presumably the chainstay flex comes from having a ver shallow triangle and curved ends to the seat stays, plus the flattened areas, regardless - it does flex, you can see it on the vid on Jeff's blog. Also, in the video - you can see some unwanted lateral flex (nothing's perfect!) in the seat tube - so it's possible your design would have more flex, be interesting to see how it rides!! 😉
There's a lot of flex in the post + ST area when seated but stood up the whole frame seems to work as a sort of leaf spring. You can feel it when landing, ride a diamond frame off the same stuff and it feels quite different. It makes sense when looking at it side on, remembering how rigid the fork is and not thinking of flex as coming from just the rear triangle (not meant as egg sucking as I know you'd recognise that a lot of frame flex/comfort that is perceived as 'rear compliance' is front end give).
But if you put a 12PSI 650x3.3" tyre in the back of a space frame I'm not sure if there would be much frame flex, as far as I understand it's why Jeff doesn't sell a fat space frame, although there's pics of one he did make ages ago somewhere.
(you all knew I couldn't not chip in on the Jones aspect eh)
I can see how this idea could work differently, more seated flex, if the rear end's not affected too much by not attaching stays and ST. May as well try it. I cut a 1" section out of an old hardtails stays once to see how it flexed, and rode- briefly..
I can see how this idea could work differently, more seated flex, if the rear end's not affected too much by not attaching stays and ST. May as well try it. I cut a 1" section out of a hardtail stays once to see how it flexed, and rode- briefly..
Maybe I should get more bracing added, then cut it out.
The RC51 of pushbikes.
I want the return of "mega oversized tubing", ALA the era of the 'freemans catalogue bike'!
DrP
