I have a pair of M575 brakes linked to a pair of LX (2007 vintage) Dual Control levers.
My ‘issue’ (apart from being slow and using the brakes too much) is that I can not seem to get the front brakes to bite well anymore. I have relatively new pads, (sintered) and have made sure I have aligned the pads, cleaned the discs with white spirit and bled the brakes. I have even taken to sanding the pads (with an electric sander and rough grade paper) to get the ‘glaze’ off the pad surfaces, as they had been squealing for a bit.
Squeal of death has gone, mostly, but I can’t even do an endo in the car park, they are that pony. I have also tried the old tricks like riding through muddy puddles, down big hills to get them hot and bed in, but still to no avail. Back brake seems ok. Both levers have similar amount of pull/reach/movement.
Can anyone think of anything obvious I am missing? Maybe a pad not moving freely?
It probably makes no difference but I am running the brakes on a hardtail with 180mm front/160mm rear.
