• This topic is empty.
Viewing 1 post (of 1 total)
  • Bite point on Elixir 5's (bodge)
  • lovewookie
    They get a bit of a slagging but I find them quite nice. Had a bit of a problem though even with the lever all the way out the bite point was a little too inboard for my liking.
    bled them, a few times, slightly overfilled them, but it made little difference.
    Took the lever off to see if the pushrod anchor could be moved on it’s thread, but nope, it’s a rivet.
    Then had a look at the plastic bit the pushrod goes into. It’s pretty deep, and I only needed a small adjustment really so I took a small amount of aluminium foil, folded it small to make a something about 2mm thick that would fit inside as a spacer.
    Stuck it in, replaced the lever and pushrod, squeezed the lever really hard to bed it in and hey presto, the bite point can now be adjusted to where I want it without the lever pulling back so far to crush my finger (middle finger braking problem..)
    so far no problems.
The topic ‘Bite point on Elixir 5's (bodge)’ is closed to new replies.
