Biggest volume trai...
[Closed] Biggest volume trail riding tyres?
[#4015543]
I know, and I'll do 10 hail Marys, but help me out on this.
2.4 rubber queens?
Posted : 28/05/2012 4:48 pm
2.4 Advantages come up pretty big...
Posted : 28/05/2012 5:17 pm
Bontrager XR4 in 2.35 is huge.
Just put one on the front, very good tyre indeed- grippy, very predictable and comfy at 20psi.
Mines a tubeless one, but it's got a tube in at the mo.
If it's as good in the wet as it is in the dry, it'll be my new favourite tyre.
Posted : 28/05/2012 5:50 pm
 br
2.4 Nobby Nic's are a good size, but the Bonty is ace for a front, if very, very slow.
Posted : 28/05/2012 5:52 pm
Another for advantages. I can't even fit the 2.25's in my giant trance.
Posted : 28/05/2012 6:42 pm
But how about in ust flavour as I think I just Keller me 2.3" prowler on its second ride?
Posted : 28/05/2012 6:45 pm
2.3 Nevegals come up pretty huge and slow!
Posted : 28/05/2012 6:47 pm
Tyres are definitley getting better, 'specially the cheaper ones.
Can't believe how good the Spesh and Bonty ones are now.
I reckon I've tried most of the Maxxis ones, particularly love Ignitors, but I'm just not paying over £30 for a tyre anymore, it's ridiculous.
XR4's for me from now on.
Mrs S loves Spesh Purgatorys, another excellent high volume tyre for not much dosh.
Still got an Advantage and a Minion Supertacky as spares, plus a knackered pair of Cinders for emergencies, but I actually prefer the cheaper ones.
Posted : 28/05/2012 6:56 pm
2.5 Nevegal... Not that common but they do come in folding bead, weigh in at about 700g, and measure a genuine 2.5 across.
Rubber Queen has a lot of volume, they're pretty wide but they're also tall. Bigger in volume than my 2.4 Advantage.
Posted : 28/05/2012 7:00 pm
2.4" RQs are mahooooosive. That is a SCIENCE FACT.
Posted : 28/05/2012 7:03 pm
2.35 Hans Dampfs are a good size
Posted : 28/05/2012 7:08 pm
2.4 nobby Nics here.
Best trail tyre I ever had, 2.35 Vredestein Killer Bees, perfect for even wet trail centres, fast light and grip well on everything bar mud. Huge volume too.
Posted : 28/05/2012 7:16 pm
I'm running 2.3 Spesh Resolutions at the mo and they seem absolutely mahoosive compared to the 2.0 Bonty Mud X I've just taken off!
Posted : 28/05/2012 7:57 pm
Continental Der Kaiser 2.5 Black Chilli.....very grippy.
took mine off for now and running Advantage 2.25 on the front with maxxis crossmark 2.25 on the rear.
Posted : 28/05/2012 8:20 pm
Of the tyres I have to hand the order is 2.4 Ardent > 2.4 Fat Albert > 2.4 Nobby Nic > 2.35 Small Block 8.
Posted : 28/05/2012 8:52 pm
Bonty XR4 2.35 is big compared to the Nevegal 2.35 that it replaces. The XR4 size would be nearer to a Nevegal 2.5 if there is such a thing.
Posted : 28/05/2012 8:56 pm
ADvantage 2.4 - like a motocross tyre...
Posted : 28/05/2012 9:15 pm
the answer should be on mtbtires.com - the guy measures them rather than going 2WOW, THEY'RE BIG12
Posted : 28/05/2012 9:24 pm
I do wonder if I'm the only person on here that owns a ruler, let alone knows how to use it... FWIW a pre-2012 XR4 2.2 measures ~58mm on a Flow and ~55mm on a skinny XC rim. International Mountain Bike mag (free online thingy) provide measurements on their tests - could we club together and get Singletrack and Dirt a ruler each, maybe even a nice metal one?
Posted : 28/05/2012 9:39 pm
At what point is the measurement taken? Across the widest point on the tread or the widest point of the sidewall? The rim makes a difference as you have shown and the pressure will make small differences especially if the contact patch is measured.
Posted : 29/05/2012 8:37 am
Both ideally. Those were taken at 30psi. You can't measure the contact patch accurately. How hard would it be to use a popular rim like a 719 or Flow to standardise the measurements? Mind you, you read the same wooly comments like 'could use a shorter stem and wider bar' with nothing to qualify what that's in comparison to.
Posted : 29/05/2012 8:49 am
Well, to be fair, the OP asked about volume, not width, so there's no need to get snotty about people offering advice, is there? 😉
Posted : 29/05/2012 4:17 pm
The 2.35 XR4 must be big. The 2.25 are looking a bit tight on my bike. Bigger than 2.35 High Rollers by some way
Posted : 29/05/2012 5:58 pm
2.35 Hans Dampf are enormous. bigger than the 2.4 Swamp Thing that it replaced.
Posted : 29/05/2012 6:06 pm
chiefgrooveguru - Member
Pff, rulers are for dilettantes
Posted : 29/05/2012 7:35 pm
