Al, I’m a gear junkie and I started out 25 years ago with various flavours of Patagonia half zip Capilene tops and they still work well today after all those years. Since then I think I have tried every thing from lots of other polyester or propylene tops, blends of polyester and merino, bamboo mixes, charcoal mixes and every density of merino possible.
Up until recently I insisted on a zipped design however I was recommended to try Craft tops and I can say with confidence if you pick a Craft top wisely they will outperform all others from a wicking and fast drying perspective.
Their range is huge and by using a bit of nous with layering you will be fine. In low temps 5 or less I will use the long sleeve top with the perforated weave, then a shirt sleeved zipped enduro merino wool top, the a light weave polyester running top and possible an ultra light weight pretext outer smock top.
In warmer weather I select the sleeveless perforated Craft top as my wicking base layer and then what ever takes my fancy over it. So Craft next to my skin, then what ever takes your fancy layer wise to suit the conditions.
Fwiw I thought the two HH base layers tops I owned were the worst I ever tried
