Yes, I should know better.
Doing a lowers service on my Revs, tightened up the foot nuts using a torque wrench to the specified amount – got to about 3Nm (50% of specified) and the damper side bolt washer started to invert, backed it off and replaced the crush washer.
Then doing the air leg the base of the bolt, the half moon washer part of the bolt started to sheared off about 2Nm. Rubbish.
Trimmed the bolt down, and replaced the crush washer on the air side, put in 100psi in both chambers and popped down a drip tray – if it doesn’t leak overnight I’ll see if it loses anything during a ride.
Anyone done the same on their Rockshox? I’m guessing the air side can be replaced by a Fox M8 base nut, although the damper looks specific.
Ricks
