You can buy new springs for the Pawls.
I rebuilt an XC Hub recently with cheap bearings, all seemed good on the bench, however when the wheel was bolted into the bike, everything tightened up and the freewheel wouldn't freewheel.
I haven't rebuilt it with quality bearings as its an old wheel I keep as a spare.
The only other time I rebuilt the hub was using Hope bearings and it all worked a treat.
I did replace the axle as well, maybe it hadn't been machined correctly?
Id you put the internal spacer in? Schoolboy error 🙂 No reason 'cheap' bearings would lock up when the wheel is in the frame if everything had gone together properly and the bearings where the right size. Going graunchy v quick maybe …
I bought a "just serviced"* pair of Hope hubbed wheels off the classifieds which were in this state. They were cured by seating the bearings properly (ie good and hard).
* When "just serviced" actually means failing to put seat the new bearings properly and completely screwing the freehub bearings to boot… they were my last classifieds buy 😉
Sounds to me like you mixed up the spacers. The spacer in the freehub is not the same size as the spacer the separates the freehub from the body. Been there, done that, had to strip and rebuild again to get it working
I just picked up set of Hope XC hubs on Mavic 521 rims for a bargain price on ebay, the seller said the rear bearings were a bit rough, which was an understatement to say the least, the hub had been abused and forgotten and the bearings corroded onto the axle and hub. Took me several days to get the bearings out.
Step 1 prepare a handy tool to support the hub
Step 2 slide a washer or old bushing on a M5 bolt and place in the end of the axle to protect it from the blows from the 2lb lump hammer.
That used to be a philips head, gives some idea of the bashing that was required!
Step 3 when it doesn't shift soak it in penetrating fluid for 2 days.
Step 4 when that doesn't work, spray verucca freezing spray down the hole in the axle to chill it so it shrinks and slides out of the bearings.
step 5 discover the whole lot was so corroded because the drive side oil seal was completely worn out, as were the o-rings in the axle endcap spacer thingammyjigs.
Rich you sorted? PM me if you need springs or wotnot and I'll take a look in my bits box later, pretty sure I got some. Can take em out tonight, meeting as normal.
The right thing to do in this situation mate (or at least in my case is :-
Pick up phone
Dial +44 (0) 1282 851200
Speak to nice lady and arrange a service
Post to hope
Pay £17.50 (IIRC) plus a bit of postage
Receive a few days later a fully serviced and as good as new hub.
Alright if you can afford it, the 4 bearings off Ebay cost £2.40 and the oil seal from CRC at £1.99 works out less than it would have cost to post to HOPE.
4X 6001-2rs bearings £14.90 (not skf that I ordered but of similar quality) are now in the freezer, will attempt pressing in an hour.
Is it normalbearing grease to use to press the bearings in or us copperslip?
Rich
Scruff if you could bring some with you that would be cool,no motor @ the minute so will be heading out from Longdon!
The bearings giving me a problem are the freehub ones,light grease and first frozen bearing inserted whacked several times seems it will not go past a certain spot about 5mm from the lip stainless its flaking its getting that much abuse (bearing stilll smooth).
i thought it would be a good idea to strip my pro2 while walking around the garden last night (my mind was in a bit of a mess)
yes, freehub removal, while on the move over wood chippings!
i now have 3 pawls.
cock.
oh well, spare wheel for the weekend….
rich (or anyone else in the know): if ive paid for next day postage, and the item didnt come next day, but was dispatched on time by the poster (betd) who do i talk to about getting my 7 quid back!?
x
