hi.. couple of questions first up..
what type of system do you have at the moment.. do you have no pump at all and relying on heat to move the water? or a pump that is nt working as you d like?
hot water likes to flow and will get anywhere.. so is there zero heat in the affected radiators..even when every other radiator is closed..if so the pipework is blocked at some point.. if there is some background heat in the radiator but its not getting hot then the whole system need balancing..
when you say they flushed the system did they do it properly or simply attach a machine and hope for the best or did they take each radiator off take them outside and flush them through as well as flushing the pipework via both flow and return?
it would be as rare as hens teeth for a system that presumably worked at some point to stop working for no good reason and a blockage is odds on the culprit.
