Viewing 10 posts - 1 through 10 (of 10 total)
  • A Question for the cable experts!
  • jasonm945
    I am just thinking about replacing my gear outers (they’re full length) and a search on here recommends Shimano’s SP41.
    Question is, would I notice any difference if I bought cheaper 4mm outer and filled it with silicone grease, or is SP41 so good that nobody can beat it ❓
    Jay
    jam-bo
    Xtr cable sets are the best. CRC had them cheap a while back
    jasonm945
    Not really the question I asked!
    goldenwonder
    Some will say yes, there’s a huge difference.
    I personally do what you’re thinking & buy outer per 30m roll & spend the difference in money saved elsewhere.
    Use good quality inners though, not the crappy cheap galvanised one- Stainless or better still XTR
    tk46hal
    No! If I was replacing outer cables I would pop into my LBS and pull some off his reel, Oh! and probably replace the inners as well.
    jasonm945
    I have some new SS shimano inners, wes just thinking about a 30m roll of outer, but Shimano’s is v expensive…
    glasgowdan
    You don’t need expensive inners – just narrower 1.1mm ones as they run so much more smoothly inside. SP41 full length outers + 1.1mm inners = happy shifting for months and months.
    cynic-al
    I have seen cheap outer not work on 10s road, replace with sp41 and it worked – but there is no more sensetive gear system.
    I don’t like grease in cables FWIW.
    1.1 inners I do like.
    cp
    Shimano from Merlin for me – just about the cheapest around, just buy more than a tenner’s worth for free postage.
    http://www.merlincycles.com/bike-shop/mtb-parts/mtb-accessories/cables-1/shimano-sis-outer-gear-casing.html
    As cyinc-al, I’ll not use cheap stuff again. Clarks is OK, but Shimano ‘just works’.
    orangeboy
    Sp41 works well and should not be costly by the meter and even comes in lots of colours
    The genuine shimano 4mm end caps with the seals in work very well but can be a pain to find
    And SRAM pit stop 1.1 mm stainless inner is the best IMO
The topic ‘A Question for the cable experts!’ is closed to new replies.
