Home Forums Chat Forum Winter tent- tunnel or geodesic?
Viewing 40 posts - 41 through 80 (of 99 total)
  • Winter tent- tunnel or geodesic?
  • convert
    A winter tent isn’t usually a light tent. As you will be in it from 6pm until 7am you need something bigger imo so you can at least sit up in it and have room inside for all your winter gear.
    I have a hilleberg akto and soulo – and both are too small imo for winter camping.
    More like 5pm to 8am, or longer in the Highlands, if not longer.
    I’ve got a soulo too. For me it’s about the right compromise – pretty tough and only medium heavy. Not sure I’d want to go any less robust, especially on a solo trip; but whilst if it was bigger it’d be heavier and weight is already such a big issue in the winter (especially solo) that I’ll take a bit cramped as the compromise. If the weather was too tough for a soulo it’s probably an error being there solo and you should be with someone and therefore in a 2 man tent.
    I’ve found UK winter in the mountains is all about compromises – unpredictably slow travel, less predicable weather and good pitching less certain. Add a good dollop of reduced hours of lights and I’d want a tent that can pitch well in compromised circumstances (ground quality and or wind speed/direction) so geodesic or semi geodesic makes sense to improve your chances of a safe and comfortable night.
    We do a grim kind of winter in the UK. The bluebird days are few and far between. The biggest difference moving to the Highlands has made for me in the winter is choosing my timing more freely and carefully. This is ten fold more important with over nights in comparison to day trips. When I used to just visit regularly I’d force the trip I wanted to do to fit the time I was up. Recipe for some rubbish and/or lethal experiences.
    montgomery
    I spent a couple of winters living out of a tent in the Highlands and found a tipi tent was a good compromise for 16 hour nights in terms of space and weight (I’m 6′ 4″).
    P1090298
    They handle snow well.
    May snow above Houxia
    I wouldn’t spend the night on Ben Macdui in one during a hurricane – but then I wouldn’t choose to do that in any tent. That’s what weather forecasts and bothies are for.
    My current winter tent is a Luxe tipi, pictured here on the summit plateau of Cadair Idris this January:
    montgomery
    As a bonus, the central pole (I use a trekking pole lash-up) makes a good FM radio booster – tie the radio aerial to it, and there were very few places even in remote glens where I couldn’t suck in a signal.
    shermer75
    Review of the Big Agnes Copper Spur HV2 Expedition tent here:
    https://ultralightoutdoorgear.co.uk/blog/cairngorm-treks-review-big-agnes-copper-spur-hv2-expedition-6b2bd2/
    They seem to have tested it pretty thoroughly including in 50-60 mph winds, hopefully they are reliable reviewers. I really want them to be because this tent is much more affordable! The packed size is a lot more bulky than the Tarptent or Hilleberg options though
    shermer75
    How do you lash your poles together?
    montgomery
    One pole, with a sawn off extension piece made from another old pole surplus to requirements. You can also buy joining sections to use two poles.
    shermer75
    So you’re shoving the end section of an old pole on to the bottom of a complete pole?
    boblo
    Personally, I wouldn’t use a tent that relies on Trecking poles. I’ve bent mine reasonably frequently and they can get lost. It would be annoying (to say the least) being unable to pitch because of this. I like to separate the duty of things when I really really need them to work. E.g. camera/nav/phone. Fine to just use a phone when it’s not serious, not so when you really need them to work/have charge.
    I’ve a Big Agnes Seedhouse SL2 which I use for 2 person bike/back packing or solo long distance bikepacking. There are lots of wavy wand type poles held together with little bits of plastic and it’s in no way geodesic (i.e. made up of triangles). I would image, they’re great up to a point in winter – spacious etc but not particularly wind resistant or robust. I note the Copper Spur Exped has a nylon inner rather than the usual Yankee mesh. This is important as a mesh inner can be bloody draughty and cold in winter. Also watch for pitching inner first followed by clipping on the flysheet with lots of little buckles/clips. It’s a PIA in ‘normal’ conditions (rain) so in Winter it could be a bit of a fight…
    matt_outandabout
    This
    In my view there’s something rather dangerous about YouTubers/Insta/Influencers heading out for wild camps in properly dodgy weather and pitching high on a summit. Then pop an image up or show 30seconds of a tent flapping.
    Good campcraft and hillcraft says ‘why the heck would you do that?’
    I watched one where two of them had tents basically flattened all night, and in the morning they took a photo and bailed out. In the background of the photo was a sheep fank I’ve camped in before – surrounded by 5′ high walls with flat grass inside… 🤦‍♂️
    That said, a good winter camp is ace and stretches your skills and preparation. You know it’s cold when it ‘snows’ inside the tent…
    matt_outandabout
    And tent wise: I’m a tunnel tent fan. My tents have been a Macpack Minaret (nearly 3kg…), then Alpkit Delta (too light for heavy weather, and not as stable) and Robens Arch.
    I also oversee DofE and previously outdoor centre kit store. When pitched right, the tunnel tents have all survived wild weather better than tents with really long poles. A couple of times I’ve had to get up and rotate the tent to realign with the wind.
    My Minaret was the last tent standing of 7 on an ML assessment – and one of the other tents flattened and pole broken was a Quasar…
    But a 3 or 4 season strong mountain tent is not light or compact when packed.
    BadlyWiredDog
    I’ve had two Minarets and used them everywhere from Scotland to the Andes, bombproof for me. Tunnels can be really stable in high winds, but rely on proper orientation – need to be pitched end on to the wind direction – and stable guying. Geodesics tend to be less fussy about wind direction and are generally less reliant on guys / pegging for structural rigidity. There’s also a school of thought that says tunnels distort in high winds, while geodesics are more ikely to simply fail catastrophically because there’s less ‘give’ in the structure.
    I owuldn’t use a Laser of any type. Nasty, fiddly, claustrophobic things and everyone I know who has one has had problems with breakages etc.
    Full winter tents tend to be heavy and sometimes poorly vented thans to lack of mesh. I have an MSR Access 1, which is a sort of four-season valley tent and its achilles heel is poor ventilation, but it’s strong for its weight and while I wouldn’t pitch it in an exposed place in really foul conditions, for ‘normal’ winter stuff it’s good and reassuringly more robust than lightweight, spring/summer tents.
    I guess the obvious question is always what are the worst conditions you expect to encounter and how much of a margin do you need beyond that? The problem you have is that while you can buy a tent that’ll cope with pretty much anything in extremis, it will also tend to be heavy and bulky as a result.
    montgomery
    No, a section inserted into the middle of the pole; the handle supporting the apex of the tent, the ferrule planted in the ground. Black Diamond Expedition pole – solid, it’s not going anywhere.
    steezysix
    +1 for Pyramid type tents, one other advantage is that you don’t really to worry too much about the wind shifting during the night as they have the same profile on each side. They can also be used without an inner which means you can keep your boots on inside and dig down into the floor to make a cold sink.
    shermer75
    What’s a cold sink?
    B.A.Nana
    I’d like to add to the macpac love-in, but I can never work out how to post images these days.
    Winter
    thelawman
    OK, I’ll concede this was May rather than wintertime, but it had happily stood up to a rough old wet and windy night immediately before taking the pic
    Minaret in mid Wales
    shermer75
    Are Macpac still good? They’ve been bought out, no?
    gowerboy
    And here is a Nallo GT in some Welsh snow.
    270C02C5-CEAA-4DB1-B2F8-3C5B978B217B
    gowerboy
    As well as the Nallo I have a Helags for summer use. It has a higher cut fly sheet and mesh doors so isn’t a winter tent; but it is quieter in the wind than the Nallo. I think that is because the poles are closer together.
    I recon that the Kaitum, a winter version of the Helags would be a great tent as it has loads of room and would be solid. It is very expensive tho.
    thegeneralist
    What’s a cold sink?
    No idea but looking at what it says on the tin I presume it a hole that’s lower than the bit of ground you’re sleeping on that allows the cold air to sink into the hole rather than being around you.
    As ever it sounds like something that could be more easily dealt with by a better sleeping bag, but that’s not as cool trendy.
    steezysix
    Yes, this ^
    It also allows you to sit up with your feet in the pit, which is generally a bit more pleasant for cooking, getting dressed, etc.
    If you don’t fancy getting out of the tent for a piss then it also doubles as a toilet, but obviously that is disgusting and I would never do it 🤫
    wbo
    I’m a bit surprised by the love for pyramid tents in the winter as while they have some advantages, and I have one as a big summer tent, they’re not my favourite tent in the winter… the extra space inside makes them cold, and using them without an inner makes them even colder, even if you do dig out the snow in the middle to drop the floor, and bury the valances.
    montgomery
    Light a pillar candle; toasty in no time and you have room to hang up clothing to dry. The slope of the sides also means they deal better with condensation than other designs I’ve tried.
    Not sure how well the cold sink idea meshes with the leave no trace philosophy, but I have been known to pack away everything under the flysheet in foul weather, dig (and use in comfort) a small cathole with my trowel, then quickly drop the fly and away….
    steezysix
    Sorry, I should have specified that the cold sink is only when pitching on snow, definitely not advocating digging into the earth! And generally just for number one, yellow snow never hurt anyone…
    thelawman
    The cold sink idea I think comes from snow holing, an engineered lowest point to take melting snow and condensation drainage down to the bottom of the cave. Avoids the worst of it soaking into your kit
    shermer75
    Haha!
    Now it makes sense!
    shermer75
    That’s an amazing photo! Did you wake up and it was like that? It must be quite weird, digging your way out of your tent! You’re being buried alive, basically!
    gowerboy
    I woke up and it was all very quiet and dark. Inside it was quite cozy really. The door on the tent is quite vertical so I opened it and there was a wall of snow in the way half way up. Apart from the snow load, I guess the main issue is that the more you get covered the less ventilation you have.
    boblo
    Back in the day I had a double A pole mountain tent with snow valances and wired elephants trunks at the top of each porch to avoid the occupants suffocating in snow… Phoenix Phortress. It was bulky, heavy and great.
    ampthill
    Having been in a tent that collapsed under the load of snow it’s not great. That was an old school vango Mk4 I think
    shermer75
    I have literally no idea what this means lol
    thelawman
    Blimey! That must have been an impressive dump of snow, the Mk4 was like the cockroach of tents in its day
    thelawman
    Basically a tube of material, probably the same stuff as the flysheet, held open at the free end by a hoop of wire or plastic, and held along it’s length in a similar manner. Bit like a snorkel for the tent, but without sticking vertically upwards
    shermer75
    Has anyone tried a Lightwave tent? They are single skin tents, but the hype is that that are breathable so therefore don’t have the condensation issues. They get good reviews for their 4 season tents, but I’m old enough to take reviews with a pinch of salt tbh
    steezysix
    The trouble with tents in winter is that because the outside air is so cold and your body is warm, you’ll always get condensation somewhere. It can either occur either inside your clothes (bad), inside your sleeping bag (not great but manageable) or mostly on the inside of the tent (best). When it condenses on the inside of the tent it will freeze and can be brushed or shaken off in the morning. This happens to both single and double skin tents, it’s just visible when there’s no inner to hide it. I have a Black Diamond Firstlight tent which is super breathable, basically made of pertex so not waterproof – I still get condensation frozen on the inside each morning in winter. I wouldn’t buy a winter tent based in it’s breathability.
    boblo
    Sorry about this… I’m not sure about single skin for winter in the UK. They were used at high altitude on big stuff but that’s dry cold and no rain. Here, you’re unlikely to get that and Gore Tex etc definitely gets condensation under the right conditions.
    I’d pick something double skin and roomy to avoid having to touch the sides. You’ll get condensation but it’ll be on the inside of the fly which the inner should (mostly) keep you away from.
    slowoldman
    I have an old G1 Ion – a small 2 man semi geodesic. A well made and sturdy little tent. Quite “cosy”. I think the nearest current equivalent is the G20.
    matt_outandabout
    Some of them are singleskin.
    Most are double.
    Generally well regarded.
    No idea about that single skin one.
    matt_outandabout
    Also, I’ve had way, way, way more wet, windy, cold camps than frosty, and even rarer snow. I’ve snow holed as many times as I’ve had to dig a tent out of proper snow – 5 times.
    And when it has been snowy, we’ve sought shelter of trees, walls, valley or bothy…or all together.
    slowoldman
    Most are double.
    Yes mine has a separate fly.
