Hi
I have bought a new headset for the tandem – deep insertion as I previously have slightly ovalised the headtube with a shallow headset.
The problem is that the reamed part of the headtube is only 15 mm deep and the headset is 22mm deep.
Do I get the headset turned down or ream the headtube out deeper? I am concerned with removing to much metal from the headtube – it needs to be reamed out 2-3 mm wider and the reamed out portion is already below where is is welded onto the rest of the frame. This would leave the wall thickness 2.2mm after reaming – its 4mm where it is not reamed.
So
Turn down the headset cups to shorten them or ream out the frame?
