Front fork upgrade ...
[Closed] Front fork upgrade advice needed
[#10782630]
Hi, I have a Giant XTC SE. From 2005. Still original with the supplied hydraulic brakes. I know it’s nothing special but is to me. Not done loads of miles. However I am looking to upgrade the forks. Nothing new just looking for a good used upgrade. Can anyone suggest what to look out for please? It’s still fitted with the 26 inch wheels.
Thanks, Nigel.
Posted : 26/08/2019 5:15 pm
What fork is on there now?
New fork wise you’d struggle to get much anyway with a straight steerer for 26” wheels - also I assume you’re on 9mm at.
The only vaguely reasonable fork I’m aware of new is a Suntour Epicon that I think is 26” / straight steerer etc.
Secondhand you could look for something like a Rockshox Revelation or Reba perhaps.
Posted : 26/08/2019 10:18 pm
Hi it says marzocchi race which I think is a suntour one. Not great. Not sure how the calliper would fit on either as it’s disc
Posted : 31/08/2019 8:30 am
You'll be struggling unless you go second hand. There aren't that many 26er straight steerer forks out there now. Even something like this
https://www.on-one.co.uk/i/q/FOXFV26RL2/x-fusion-velvet-26---275-rl2-fork
Which is reasonable quality, would involve getting a new front wheel if you're 9mm QR currently.
Posted : 31/08/2019 8:52 am
Front fork you say. What fork have you currently got on the back?
Posted : 31/08/2019 9:27 am
Marzocchi were a brand in their own right - better than Suntour. They’re now part of Fox but that’s only recent.
Looking at the spec of the bike, unless you can pick up something cheap / secondhand in terms of forks I wouldn’t bother in hindsight. The xtc se looks very dated and wasn’t that well spec ‘d from new. Your money would be much better spent on a Voodoo Bizango or Hoodoo or something like a Vitus Nucleus where you’ll get all new components and much better geometry in the frame for trail riding.
Posted : 31/08/2019 10:21 am
Most likely your current fork will be 1 1/8 straight steerer, 9 mm QR, and ISO brake mounts, but you need to check that. I'm guessing the original fork was probably 80 mm travel, 100 mm at most. Something like a used Rockshox Reba or Revelation with 100 mm to 120 mm travel would be obvious things to look for. If you can find a U-Turn model, that would be perfect. I had a couple of XTCs over the years, they were good trail bikes.
Posted : 31/08/2019 12:09 pm
