Drop bar position a...
[Closed] Drop bar position and shape
I'm struggling to get happy with the bars on my bike.
When in the drops, the brake levers are a long reach, unless I move my hand up the curve, at which point it's pulling my elbows down and wrists uncomfortable. I end up having to get fingers around the levers and pull just enough that I'm not dragging brakes, just to ensure I can get to them.
When in the hoods it feels ok, perhaps not wide enough, but it tips by wrist upwards compared to my arm. I've angled the brakes a touch inwards at the top, which helps.
Today I rotated the bars downwards more, but it still isn't 'right'.
Could it be the shape of my bar? Perhaps worth trying a different bar?
Also, how do I know what width of bar to go for - I think a touch wider would work better?
Posted : 20/12/2020 12:32 pm
Not sure which series of Tiagra you have, but newer ones have proper reach adjusters (no need for rubber blocks)
I would have said also that this levers are fitted too high up on the bars.
Posted : 20/12/2020 12:42 pm
I get this problem. I find anatomic bars work better for me.
like this:
http://www.dedaelementi.com/en/zero-100-anatomic/
I also think your levers are rotated too far round. They need to go a bit more clockwise looking at the picture.
Posted : 20/12/2020 12:44 pm
Ooh, I'll check if reach is adjustable.
I did wonder about rotating the levers a touch clockwise.
Then though, being shallow drop, my hand ends in the bottom return curve of the bar - increasing distance to lever tip.
Posted : 20/12/2020 12:47 pm
I would say your levers are a little too high. I tend to position mine so the the run from the top of the bar onto the top of the hoods is about horizontal. But personal preference really.
How wide are your bars. I've got On One Midge bars on my gravel bike, think it's 420 at the top, flaring to 560. They're an acquired taste, but I like them. Did take a lot of tweaking to get the shifters at the right height and angle, and also the bars rotated just right. The SSCX bike has a much more modest flare.
Posted : 20/12/2020 12:48 pm
If you are looking for new bars, these have a nice shape, but drop bars are a bit like saddles...
https://eu.ritcheylogic.com/eu_en/bike/handlebars/comp-venturemax-handlebar
Do you know what series the levers are?
Posted : 20/12/2020 12:53 pm
I appreciate that we are all a bit different, but this is how I have the drop bars and levers set up on my two road bikes.
I have small/medium sized hands and can easily brake from the hoods or the drops.
Those bars are Woodchippers, so heavily flared. I don't have a similar photo of my Cube but that uses standard compact drops.
I'd suggest you rotate your bars back to make the top flat/parallel to the ground, then move the levers back down so that they are upright. Try that a few times before finally re-taping.
Posted : 20/12/2020 1:06 pm
I always aim for the tops of the hoods to be horizontal and a nice flat transition from the tops of the bars to the hoods as it gives a big flat area to rest your wrists when holding the hoods. From the photo, I would try moving the levers down. Bar shape does appear to be more round in comparison to the ergo shape of many others
Posted : 20/12/2020 1:09 pm
4700
Posted : 20/12/2020 1:18 pm
There is no one, universal placement of levers on drop bar. If someone is insisting on that it telling total BS...
What suits you best is the best. Never mind how does it look.
In regards to not reaching to the levers from the drops... Might be that you are just small handed like me and standard drop bars will be too much for you.
Hence I went with Ritchey Beacon. Wide flare and ultra compact drop 80mm and very short of reach 65mm.
Might be that's your golden ticket?
Also sometimes playing with stem that got extreme rise, by extreme I mean like swan neck style stem, or something like Ergotec Charisma High.
That mainly allows rolling handlebars front a lot to shorten reach and drop effectively.
Cheers!
I.
Posted : 20/12/2020 1:34 pm
V similar bars to mine but my brake levers are lower and drop section a little flatter.
When in "comfy" position on the drops, my hands are on the flat section and I don't expect to reach the brakes. I move them forward of I need to brake. I'm used to road bikes tho, many years including chain gangs and road races.
I wonder if moving your saddle forward might help the drops position easier? I have also found saddle angle very crucial in terms of whether your hands are pushing/pulling the bars to compensate for it.
Posted : 20/12/2020 1:50 pm
Agree with the others that your bars are drooping forwards a bit, and your brakes are mounted too far up the bar to compensate.
I've added mine for comparison...until I just looked at the photo, I would have claimed the flat top of my bars are aligned with the hood of the brake, however it looks like mine actually rise slightly first.
Photo annotations are probably a bit exaggerated but illustrate the difference. Should resolve the wrist angle on the hoods, may help reach the brakes if not, at least make the hand position more comfortable.
Posted : 20/12/2020 1:53 pm
I’d be rotating the levers round further round the bars, clockwise on that pic. I’d wind the reach of levers in too.
Id also be looking at the bars themselves, they seem a similar to a pair I had on an old Kona and I didn’t like them at all. RHM Zero bars are a good, compact shape and worth looking at.
Posted : 20/12/2020 1:57 pm
Thank you all.
@spooky_b329 - those lines do help show things.
The bars are Uni which came on the bike.
I need some new bar tape 'in case', then will faff with the angle of the dangle of things some more.
It may just be they are odd shape, they do feel narrow, and are only a couple of cm wider than the bars which came on mrs_oab's XS giant.
Posted : 20/12/2020 3:49 pm
get a shallow drop with some decent flare, venturemax is good. base the width on where your collar bone goes into your shoulder as a start but this is mainly for an aero position on the road, so for gravel I'd say that width plus a bit. go wider still if using a short stem, say 70mm or less. don't be araind to turn your levers in a little to get a more comfy position for your hands, this has the added benefit of throwing the brake lever out a bit making it easier to reach
https://flic.kr/p/2j14un5
Posted : 20/12/2020 4:09 pm
Yeah those levers are pretty high up. I've often had that issue but for me it was really caused by the bars being too low.
Posted : 20/12/2020 4:11 pm
 kilo
Another for bars too far up, your saddle looks quite far back as well.
Posted : 20/12/2020 4:40 pm
You might just not get on with drop bars no matter the shape, size or drop.
Posted : 20/12/2020 5:09 pm
Glad the photos helped. I also echo the comments about a shallow drop and the shape...again if you compare the photos, my bars bend tightly at the top and then the radius increases through the drop. I replaced the 'traditional' bars on my commuter with a similar pair that are also slightly flared, I can ride in the drops for longer and with more comfort now.
Posted : 20/12/2020 5:30 pm
Also, if you get more tape get some without adhesive. It doesn't slip (or at least my Boardman stuff didn't) because it's still tacky on the back, but you can retape it as many times as you want. A big plus when you're still fettling position.
Posted : 20/12/2020 5:36 pm
+1 for silicone backed, glueless tape 👍👍👍
Cheers!
I.
Posted : 20/12/2020 6:01 pm
Have you tried a shorter stem or a bar with a shorter reach? I fitted an On-One Brian bar and it fixed that problem for me.
I generally ride for a few days without bar tape while I fiddle with the lever position and bar angle. That helps.
Posted : 20/12/2020 6:12 pm
Interesting.
My saddle is set back a bit as I didn't feel stretched out when I first got it.
A wider bar will in effect lengthen the reach, so I could pull the saddle back forward a touch.
I might just add a venture max to the order.
It's not 'bad', it's just not 'right'
Posted : 20/12/2020 6:34 pm
or the other extreme
https://flic.kr/p/2kiNXZm
https://flic.kr/p/2kiPx3B
Posted : 20/12/2020 7:03 pm
@rOcKeTdOg Is that lower pic near North Berwick? Oddly familiar. 🙂
Posted : 20/12/2020 9:42 pm
@epicyclo deepest darkest Warwickshire
Posted : 20/12/2020 9:45 pm
Looks like they are angled upwards?
And mounted too high, as others have said.
Posted : 20/12/2020 10:12 pm
I, like several other posters, also think your levers are a little high in the original pic.
If you’re going to move them, mark the bars with a sharpie pen, so you can move them both by the same amount.
There is no ‘right’ or ‘wrong’ way really, what matters is whether they are comfy or not.
But, having said that, spooky’s picture is very close to what i do.
Also, as others have said, some people just never get on with drops at all.
Doesn’t cost anything/much to experiment though.
Posted : 20/12/2020 10:23 pm
Spooky's pic looks more comfortable to me as well. I think that will move your hoods forward by a bit, but it seems your saddle might be able to move forward a touch to compensate.
+lots for non-sticky bar tape as well. I have no idea what benefits the glued stuff might have that would offset the utter ballache of removing it.
Posted : 20/12/2020 10:37 pm
@matt_outandabout
4700.
Ok so apart from bar / lever position 4700 has reach adjust without needing rubber shims.
If you roll the tops of the rubber hoods back there is an adjuster screw underneath.
Posted : 20/12/2020 10:49 pm
Roll the bars forward a bit more. The extension on the drop is designed to be level a la:
Reach to the levers will probably be reduced by 20mm+!
EDIT: Bar width usually dictated by distance between Acromiom which puts the majority of men on 40cm (c-c) although sizing up will help with stability riding off-road. Most off the shelf bikes come with 42cm as stock.
Posted : 20/12/2020 11:20 pm
As we move into T4 I need to sort my bars out, what silicone tape or are they all such and much?
Posted : 20/12/2020 11:35 pm
I really don't think this is the case on most bars .
Posted : 20/12/2020 11:37 pm
Perhaps not on some of the more extreme flared/ergo variants but most standard shape drop bars (even with flare) are designed to be set up as below:
Like I said, this is how they are designed to be set up but not necessarily how all people will find them most comfortable.
Source: https://www.cyclingweekly.com/group-tests/bike-handlebars-345953
Posted : 21/12/2020 12:13 am
Mark them with a Sharpie or Tippex, ease off the bolt tension in the stem and STI's until the bars and shifters can be moved up or down with effort, then go ride somewhere smooth. Nudge the bars up and down until comfy, then do the same with the shifters. If it still isn't right, look at bar profile / height, stem length and, as a last resort, seatpost setback.
Posted : 21/12/2020 1:31 am
That's how the ZIPP Service Course SL bars are meant to be set up. Read around a bit and other bars are designed to have the drops point approximately at the rear axle.
If it were me, I'd flip the stem, rotate the bars so that the curve of the tops is level, the hoods are level and continuous with the tops. That will move the levers significantly lower on the front curve.
Posted : 21/12/2020 1:44 am
Flipping the stem will increase the reach even further. Roll the bar OP!
Posted : 21/12/2020 2:13 am
Roll the bar OP!
Which will increase the reach on the hoods.
This has some good pictures of various set-ups and the advantages and disadvantages. I'd copy their 'neutral' examples based on what you've said
https://cyclingtips.com/2018/09/how-to-set-up-road-bike-drop-handlebars-tips-guidelines/
Posted : 21/12/2020 4:08 am
Come-on @cromolyolly, OP's issue is NOT the position on the hoods but reaching the levers on the drops. Rolling the bars forward will bring the levers CLOSER to him at a more neutral angle. OP also says that the angle of the hoods tips his wrist upwards so having them set closer to level might offset this. Flipping the stem and therefore lowering the bar will increase the angle of his wrists.
I appreciate that this isn't a road forum but it is a road bike we're advising on.
Posted : 21/12/2020 7:43 am
 igm
Everyone’s different, but for me before I put the brakes on I like to set the bars level as they sweep forwards so the lead in to the hoods is level. Then the brakes go on with a really small up lift on the hoods, erring on the side of flat.
For me the OP’s photo has the bars rotated too far forward (clockwise in the photo) and the brakes are too high on the bars.
Rotating the bars back and pushing the levers forward on the bars would both give me a more natural position and bring the lever tips closer when in the drops.
But you’re not me.
Posted : 21/12/2020 9:43 am
LOL. The photos on that link you posted don't even have them set up like that 🙂
Posted : 21/12/2020 12:34 pm
OP’s issue is NOT the position on the hoods but reaching the levers on the drops. Rolling the bars forward will bring the levers CLOSER to him at a more neutral angle.
It will actually move the levers further away. It will only help him reach the levers if he puts his hand in a different place on the drops, which could be achieved without moving the bars at all. The relationship between the levers and the handlebars is determined by where the brifters are positioned on the bars not the angle of the bars themselves.
Totally agree, having the hoods level with certainly help. Flipping the stem won't have any impact on the angle of the wrists, unless you change something else as well.Moving the levers on the bars will achieve positioning of the wrists on the hoods and reach to the lever on the drops.
Even on a road bike, if your seat is too high, you don't generally solve it by installing longer cranks.
Posted : 21/12/2020 3:23 pm
Yep, they appear to be pointing up, which will make the levers further to reach.
Not sure how the OP hasn't worked this out himself.
Posted : 21/12/2020 3:27 pm
I’m hoping these pics work
url= https://i.postimg.cc/R6FwrwWx/367-BD6-F6-B7-D0-4976-9200-FB1-E1-A6-D9-B31.jp g" target="_blank">https://i.postimg.cc/R6FwrwWx/367-BD6-F6-B7-D0-4976-9200-FB1-E1-A6-D9-B31.jp g"/> [/img][/url]
[url= https://i.postimg.cc/hJ7q250k/3-D428-F65-8-BC3-469-D-B43-D-993-D2-DCEDBFB.jp g" target="_blank">https://i.postimg.cc/hJ7q250k/3-D428-F65-8-BC3-469-D-B43-D-993-D2-DCEDBFB.jp g"/> [/img][/url]
[url= https://i.postimg.cc/mzyZSnLb/695-E0932-7-AE6-4-AC2-A457-484-EA81-EA74-D.jp g" target="_blank">https://i.postimg.cc/mzyZSnLb/695-E0932-7-AE6-4-AC2-A457-484-EA81-EA74-D.jp g"/> [/img][/url]
It’s my first time fitting drops. I’ve got Ritchey Beacons after some great advice on here last week.
I’ve given these a quick spin, and they feel good. Does this seem like an ok set-up?
I’m aware that the reach of the levers is very tight. It was the only way I could reach them with the old bars. I’ll loosen them off a bit when I’m sure I have a good position.
PS comments about state of garden, dirtiness of chain, etc all considered.
Posted : 21/12/2020 3:32 pm
I'd always assumed the levers on those types of bars should angle in towards the front wheel slightly, to match the angle of the drops - otherwise you will need to pull your fingers back a long way to get them around the levers when on the drops - or you have to angle your wrists backwards. But give it a go and adjust as needed. It's about comfort for you, not some theoretical 'rule'
Posted : 21/12/2020 4:07 pm
I see what you mean. It felt ok when I was riding - I think as the bars are so wide my arms were angled in that direction.
I’ll give it another try, though, before I put the tape on, and I’ll bear your comment in mind.
Posted : 21/12/2020 4:26 pm
Finally some bar tape arrived to enable me to have a play.
You can see old lever position (background) after I've rolled the bars flatter. The new rolled up bars with moved down lever position does indeed increase reach, a lot. I've moved saddle forward.
Posted : 10/01/2021 2:59 pm
 isoo
To me it looks like your bars have a classic bend, where you're not supposed to get a flat ramp leading into the hoods. Like on Scotroutes' first photo above. That way you just hook your thumbs on the lever, which really isn't the way modern brake levers are meant to be used. It will also lower your hood position significantly.
So new bars might be in order...
Posted : 11/01/2021 12:25 pm
I'd roll the bar forward and move the lever up the bar a bit (quite a lot, actually).
Posted : 11/01/2021 12:49 pm
I’d roll the bar forward and move the lever up the bar a bit (quite a lot, actually).
Which would take me back to my starting position, that doesn't work for me...
I do think new bars may be needed...
Posted : 12/01/2021 4:55 pm
I don't think you're far off. I'd move the hoods up a touch, not much, and you're about there.
Posted : 12/01/2021 5:02 pm
That's what I've settled on @lunge - bars as is, shifter nudged up a touch.
Posted : 12/01/2021 5:24 pm
Give it a go, but you may prefer a bar that has the same shape at the top but curves round closer to flat (or even slightly upward) at the end.
I certainly like that kind of shape, so I've got something to push against when honking out of the saddle.
Posted : 12/01/2021 5:35 pm
Matt,
The bottom section of your bars should be parallel to the floor (or as near as dammit).
How tall are you? I'd wager your bars are too high, and your saddle is too high - this is a combination that'll force you in to an upright position. Lower both, and try and stretch out more.
Posted : 12/01/2021 7:21 pm
I don't think this is true. Modern bars come in such a variety of shapes this would really curtail your fit options if it's even possible.
I tweaked the bars on my new bike and the position I ended up with is pretty much the same as how it is in this pic, maybe rotated forwards a smidge:
Posted : 12/01/2021 10:21 pm
The 90's called and want their bike-fit back.
Posted : 12/01/2021 10:41 pm
The 90’s called and want their bike-fit back
Out of order. In the 90s we actually looked at the rider on his bike before advising.
Posted : 12/01/2021 10:44 pm
I have the same problem with reach to the levers. From experience a short reach and drop works best for me. I set my bars with an imaginary ball bearing in the open end that would slowly roll out. So,not parallel to the ground. Then hoods which would give as smooth a transition as possible from top of bar to top of hood.
Posted : 12/01/2021 11:06 pm
So slightly worse than I had to start with?
I've only done one short ride so far. It feels a longer reach, however the drops and reach to levers is much better, my wrists also felt less 'pulled'.
Posted : 13/01/2021 7:53 am
Posted : 27/02/2021 11:21 pm
1. "ground" no need to thank me 🙂
2. I set mine with a bit of a tilt, perfectly flat means my wrist is bent uncomfortably on the flat section. But they aren't compacts.
3. Not sure I would say everyone should have their bars set up a specific way, you can then get into stuff like KOPS which I don't agree with.
Posted : 28/02/2021 12:05 am
An update.
The bars are better rolled up more and levers further around. I prefer them.
I am still not convinced that I have the 'right' shape of bar for me / my wrists. It is princess and pea stuff still - it feels that when I ride on the hoods it is a good pull forward. it feels a touch 'odd' to be in the drops, it pulls my arms in (too narrow? no flare?) and means the reach to the brake constantly feels a stretch in my hand.
Please recommend some other bars to try - I ride 80% road, less reach would still be good. Cheap too as I cannot spend dafty money trying out ideas.
Posted : 19/03/2021 12:21 pm
