Dad very pale at quoted cost to fix these 3 warning lights.Any Ford/mondeo experts out there?
So far research says to check the ABS sender units are sending 1.5-2.0V per front wheel.
Really need to get the fault codes read. Local garage should be able to do that.
Wheel sensor is the mostly likely cause of all those faults at once.
Been to local garage - unable to fix, from what I can gather from dad they did clean and check the sensors. But I think these are quite easy to unplug and multimeter to the sender unit and spin wheel to see if a voltage is generated?
www.fordmondeo.org
BBA-Reman can sometimes be helpfull.
http://www.bba-reman.com/uk/index.aspx
[url= http://www.fordmondeo.org/forum/showtopic.php?fid/242/tid/840517/pid/2005277/post/last/#LAST ]Earlier thread I have placed on fordmondeo.org[/url]
good thinking spooky.
