Semantics really but don't let that stop you being right.
Distraction is distraction be it fixed to a window or in your hand.
It's a recommendation in the highway code, not necessarily law (not a 'must').
Problem I have is the whole point of it is to be able to see oncoming traffic and take action to protect yourself and not be in the way as much as it's possible, however frequently runners don't do anything at all to get out of the way. Continue running towards you and with oncoming traffic the other side it makes it hard to judge both your speed towards them and their speed towards you to safely stop in time. Walkers usually step to the side of the road and more often that's enough to simply pass or overtake. Makes perfect sense for walking and I walk against traffic if no pavement.
davidtaylforth - Member
Yeh it's a piss take. They don't even pay **** road tax.
[daily-mail-mode]No high-vis either! 👿 , and that's in the highway code [/dail-mail-mode] 😉
Why? The maximum any runner is likely to be doing is around 20Kmh, most will be closer to 10Kmh, and you should know your own speed.
A basic driving skill - judging speed and distance - it allows you to proceed smoothly with little or no deceleration and acceleration.
Why should runners or walkers have to get out of the way?
Why don’t motorists pull over and allow those on foot to pass unimpeded?
I was always taught to face oncoming traffic to you can see the danger and avoid it if necessary by stepping or tucking into the hedge. Also gives a bit more confidence to the driver that you have been seen.
On a mobile phone related question and the holding of said device. I could have sworn there was a law where you couldn't fix a holder into the swept area of the windscreen? I regularly see holders in the middle of the windscreen, and also occasionally right in the drivers eyeline!! Was I mistaken about the swept rule
the peeps who I really don't understand are those who go running on busy touristy streets e.g. the South Bank in the height of summer. It looks totally unfun and unproductive.
I have a soon to be 17 year old who is revising for her theory test by doing practice tests, not actually reading the HC - "none of my friends read it they just practiced the test"
I did a speed awareness course a few years back. One young lad admitted that he didn't know any road signs bar the half dozen that were on the practical test.
What that all means, is that the STW specialist driving kangaroo court is about the only place I can think of, where driving behaviour is discussed. Given the effect poor driving can have on entire families in the blink of an eye, if hurting one persons feelings on a thread like this, causes one contributor, or forum lurker, to think a little more about how they behave on the road, then long may it continue.
Well said.
Yesterday I paid £1200 in 'road tax'
How big and ostentatious a car do you have to drive to pay that much?!? 😯
Eight and a half Ford Fiestas. (-:
VED's changed recently, you pay a premium on the first year and then a flat rate of £140. That looks like the first year on a new car to me.
Using the road is a big and constant risk assessment activity for all who use the roads whether they be drivers, cyclists or pedestrians. Its all about giving yourself the best chance of survival. If I'm walking on the road there is a risk of a motorist (or cyclist for that matter) not seeing you for any reason, so I want to be able to see them coming and at least have the opportunity to jump or dive out of the way.
My dads best mate lost his then fiancee waling along a dark road one night in the same direction of the traffic. They were walking holding hands, a car came from behind and hit her and pulled her hand from his as she was run over. Not sure why the driver didn't see them..at the end fo the day for her it is irrelevant. At least if they were walking facing the car she might have stood half a chance of getting out of the way.
Accidents happen, that is a fact of life. You have to take responsibility of your own safety at the end of the day and assume that everyone else using the roads are imbeciles and will do something unexpected at some point. It's inevitable, so you have to be vigilant and ready for it. Nobody else is going to look after you, and its pointless what the rights and wrongs of any situation are and what the Highway Code says if you're dead.
No i don't.
Meh, suit yerself, still got a hangover then?
No matter, others have explained quite adequately, so don’t worry about it...
trail_rat - Member
Semantics really but don't let that stop you being right.Distraction is distraction be it fixed to a window or in your hand.
Well, yes, but that’s covered in law anyway, and is not concerned about a phone being used as a satnav, just being distracted while driving, and as I’ve said, I consider trying to use a screen mounted away from line of sight to be a far greater distraction than one sat in your peripheral vision, and having a heated argument on a BT-based phone link through the car’s infotainment system would be no different to the same heated argument with a person sat in the same car!
Saying using a satnav on a phone mounted on the screen is specifically illegal is just plain daft.
INRAT I assume you left yourself enough time to stop. Safer running against the traffic and I have had to make the off last minute dive into a hedge when running to avoid selfish drivers.
Three, with changes in policing
The word you're looking for is thirdly.
Secondly, after passing the L test, very few people actually bother to try and improve their driving skills,
Ironically it's the same with reading and writing skills.
This. Well put.
ticsmon - MemberWent round a blind bend today
Then you were travelling too fast.
Bends are only "blind" if you are going too fast for the distance that you can see.
Onzadog - MemberFirst off, driving is a privilege, not a right.
Actually it's neither, but if soundbites make you happy, crack on. 🙂
xxx
sbob
IAM SfL, RoSPA Gold (lapsed).
The arguement would be that either the passenger operates the sat nav if it needs used on the hoof or you pull over. Just like you should have done in the olden days with an atlas.
No need to be pawing at any gadget on the dash or on the windscreen.
As I said distraction is distraction .
The onus is on the user to ensure they use it safe. How ever the hand held law is to make it easier for police to prosecute for folk using their phones as it's plain to see at a quick glance and makes it easier to get a conviction to stick.
There is no denying it the safest place for a phone to be is out of reach of the driver. See guy changing the music while driving his truck....... No temptation if it's out of reach.
It's not well put. Respectful of your experience etc, but STW is not a place for driving to be 'discussed'. It's where people will seek to unearth any vulnerability in a comment and launch a not-even-passive aggressive attack, with an air of high-horseness that Salvador Dali would struggle to depict.
When was the last time you saw a driving thread where someone replied "Well yes, I can see why you think like that, but it's actually this..".
To have a 'discussion' needs some basic respect for the people you're taking to, and when it comes to this place there isn't any*
*God knows why that is, maybe it's just an internet forum thing.
It gives the walker /jogger time to see the car and bail into a hedge /ditch or over a wall.
If a cars a approaching from behind and not looking where they are going, you won't know whether you need to take evasive action.
That's my understanding, and it makes sense to me.
whitestone - Member
Why? The maximum any runner is likely to be doing is around 20Kmh, most will be closer to 10Kmh, and you should know your own speed.A basic driving skill - judging speed and distance - it allows you to proceed smoothly with little or no deceleration and acceleration.
Relative speed, 10Kmh towards you + 48Kmh (30mph) towards the runner = 58Kmh (36mph). Faster than the speedometer is telling you.
In judging speed and distance, having a moving object coming towards you with no intention of stopping, is equivalent to you overtaking and judging speed and distance with an oncoming vehicle. That's fine when you're in control of the decision to overtake, but less so when you've got a runner heading towards you out of your control.
While I can stop in time, I just find it disconcerting when a runner continues to run towards me, whereas a walker is not a problem. Usually because they step out of the way, and even if I have to stop, they're not still walking towards me. They wait until it's safe to move on.
Walkers are curteous and clear out of your way Why don't runners don't you mean ?
deadkenny - Member
...While I can stop in time, I just find it disconcerting when a runner continues to run towards me, whereas a walker is not a problem...
But why should a runner have to stop?
Is the car driver's use of the road more important than the runner's?
A runner isn't going to be "out of control" they are going to be in more control than the nut holding the steering wheel.
Why is the relative speed of a car and a runner worse than that of two cars?
Sounds to me like you are making excuses to justify you not being inconvenienced.
Why don't cyclists pull over and get out my way when I come up behind them. The speed difference is so much I have difficulty gauging it so he should just get out my way.....
bensalesYesterday I paid £1200 in 'road tax'
SaxonRider - MemberHow big and ostentatious a car do you have to drive to pay that much?!?
First year on a new full size 4 door saloon. Just happens to have a big engine that kills baby robins whenever I drive it.
But for the Brexiteers I’m supporting British industry.
whitestone - Member
It isn't. However, cars are not normally coming head on with no intention to stop or avoid collision.
Not inconvenienced. I'm fine with stopping aside from the adjustment to stopping distance accounting for their speed towards me. Just trying to avoid hitting the oncoming runner, concerned for their safety, whilst also being concerned with other hazards on the road.
epicyclo - Member
If there's no requirement to stop or consider you own safety with regards to oncoming traffic, there's no point in being able to see oncoming traffic.
trail_rat - Member
Nope, I'm slowing down and able to judge the difference in speed easily and not being concerned that they're still coming towards me once I'm at the same speed. The cyclist has every much right on the road as a car (they came before cars). So do pedestrians, but it is their responsibility to take caution, as much as everyone else. My point is, some runners don't take that caution. It "inconveniences" them to upset their rhythm 😉
Which is sod all.
You don't answer the question of why a runner would seek a collision with a motor vehicle?
As the driver of a motor vehicle you are the most dangerous thing in this situation. (You being a generic "you" not you in person)
I don't appear to have a problem dealing with oncoming motor vehicles that have no intention to stop. In fact most drivers don't seem to have any such problem. Why then is a human being outside a motor vehicle such a problem for you?
Rule 2
If there is no pavement, keep to the right-hand side of the road so that you can see oncoming traffic. You should take extra care andbe prepared to walk in single file, especially on narrow roads or in poor light
keep close to the side of the road.
It may be safer to cross the road well before a sharp right-hand bend so that oncoming traffic has a better chance of seeing you. Cross back after the bend.
Unless there's another addendum that says jump into ditch and get out of way of on coming car.
whitestone - Member
I have no idea, but in my experience many do, and in particular referring to the Highway Code posted, "keep close to the side of the road" isn't what I observe.
I have a big problem when there's a car overtaking heading towards me and I have to slam the brakes on while he dives in narrowly missing a deadly head on collision. I should think most drivers have the same problem.
The runner is far less of a problem. As I said in the beginning, it's just disconcerting compared to a walker who typically moves out of the way or keeps close to the side.
Just a comment really on where the reason for walking against traffic fails if the person is not prepared to use that advantage for their own safety. I'd prefer they run with traffic in which case, and walkers walk against.
[quote=trail_rat ]The arguement would be that either the passenger operates the sat nav if it needs used on the hoof or you pull over. Just like you should have done in the olden days with an atlas.
I'm not sure anybody is suggesting fiddling with a satnav whilst driving. Perfectly legal to have a phone in a holder using it as a satnav though. If somebody has been prosecuted for using a phone as a satnav, it's either because they're holding it in their hand, or because they were clearly distracted by it in a way most people aren't.
Of course some people are distracted by their phones whilst driving, clearly you shouldn't text, select music, change settings on a satnav etc. whilst driving - but then people used to fiddle with their radio whilst driving.
driving in an unsafe manor
You've driven in Peckham then?
It may also be correct as there may be something in construction and use about mounting items higher than the dashboard on the screen. I do wonder how the modern Audis manage to get around this one with the screen that pops up from the dash.
[quote=Sandwich ]It may also be correct as there may be something in construction and use about mounting items higher than the dashboard on the screen. I do wonder how the modern Audis manage to get around this one with the screen that pops up from the dash.
Ah, meant to cover this one earlier - yes, according to the guidance issued by DfT a satnav is equivalent to a sticker, and anything larger than 40mm diameter (which is pretty much every satnav or satnav mount) can't be placed within the swept area of the windscreen. Construction and use regs section 30.
Hence almost all screen mount satnavs are breaking the law. The Audi thing may be positioned so that it's below the normal sightline of the bottom of the screen - though it would also seem to be covered by the exemption "Original vehicle design features and drivers aids, such as sun visors, are allowed".
Personally my phone mount is on the dash to the left of the steering wheel - at about the same height as the instruments, so checking it is as safe and convenient as glancing down at those.
deadkenny - Member
'But why should a runner have to stop?'
You're right. I didn't phrase it correctly.
Why does a driver think that the runner has to stop and get out of his way rather than the driver slow down (or stop) and give the rider a wide berth?
After all the driver is the one wielding the deadly weapon.
Or is there an implicit suggestion that the driver's journey is more important than the runner's safety?
It's not saying shuffle along with your back to the hedge to minimise the amount of space you take up. Most drivers aren't looking for pedestrians near the side of the road if there's no pavement.
I rarely run on roads but I think I'd prefer someone to risk a collision with oncoming traffic while I leap into the 2ft of safe space to my right.
