Best
Muriel
EVAH!
Leave it as is!
As much as I'd like to its not an option flashy, has to be painted over.
Get a decent white undercoat and then do a couple of layers. Should be fine.
I used the Polycell stuff, admittedly for some stubborn water/leak stains, and it seemed alright.
http://www.polycell.co.uk/product/polycell-one-coat-stain-stop/
Not ridiculously priced at £20 for a litre at [url= http://www.homebase.co.uk/en/homebaseuk/polycell-stain-stop---1l-277295 ]Homebase[/url]
I'd use aluminium paint as a primer, as it should give a dense cover and stop any of the colours bleeding through.
Shouldn't be too bad. Zinsser primer then a good trade paint over the top. Don't use the cheap crap. Couldn't get zinsser locally last time so used the polycell primer linked by Jamie and it was ok. Use a roller not brush though.
Could you look at stripping /sanding it back with an orbital sander first? Depends what the wall is made of.
Is it plaster on brick or what?
Don't see the point in adding more layers of thick paint unless you have to.
Can't you stick something over the top and paint that, so that future generations of archeologists can ponder the significance of the original?
Keep it, it will grow on you 😀
If it's made of rock, then the design will go all the way through.
Bloody hippies with thier irreversible wall art.
[quote=nickdavies ]Shouldn't be too bad. Zinsser primer then a good trade paint over the top. Don't use the cheap crap.
Was looking at [url= http://www.screwfix.com/p/zinsser-bulls-eye-1-2-3-primer-sealer-2-5ltr/10136 ]Zinsser paint [/url] then crown trade magnolia.
wall is plaster don't really want to sand wall, enough to do without sanding that wall.
Yep, that stuff is pretty good.
And also +1 for good quality paint over the top.
Just stick a big patch of white paint on it and see what it does. If its been drawn / painted with a mix of media some might migrate through the paint (inks / sharpies are a devil for this - they might not be obvious in the final artwork but might have been used to draw the design out originally) and keep migrating through with every subsequent layer. Similarly some artist paints will create a surface that emulsion won't readily bond to. Similarly the brush work might show through in relief - particularly the outlining of shapes. So you might not need to sand it off, but you might need to sand it flat.
So slap any old emulsion on and see if anything weird happens before committing to buying anything. You might be better off going over it with lining paper.
If you have a problem with it bleeding through would it be worth adding a layer of lining paper over the top. My thinking is that lining paper is cheaper than paint and should give you a more neutral surface to paint on to.
[edit] sorry, just read the tail end of the post above Doh!
]sorry, just read the tail end of the post above Doh!
Thats alright - it was an edit 🙂
Is that a coat hook right in the middle?
RUINED.
They're for erotic auto-asphixiation shenanigans whilst imagining yourself at the mouth of hell
attack it with a hammer and then replaster it. Shouldn't be too much hassle.
Rather than bullseye you might find wallpaper cover up is cheaper and does the job you need.
Paint it grey, the cheap value stuff will do. Covers bold colours better than white, but is still light enough to not affect a lighter final coat.
Second the poly cell stuff it covered a deep purple wall I needed to be rid of!!
My old flat had kawasaki-green walls with a navy blue "feature" wall - the t**t even painted the radiator, the windowsill, and all the woodwork dark navy blue.
Using grey undercoat is a good call - wish I had thought of that 🙁
I still have nightmares about it.
I'd 'size' the wall with paste, then paper over with lining paper. (joins go horizontal as less noticeable)
Then paint over. Less paint, and someone will get the joy of rediscovering it in 30 years time...
You could even print out this thread and stick it to the wall 😉
Zinzer BIN would be my go to stain blocker, brilliant stuff.
Plaster it ?
Is the reflection in the water going in the wrong direction? It should be heading back to the right bottom corner rather than the left, shouldn't it?
I'm struggling to imagine what circumstances could possibly mean that is truly the case.
You have to let that live forever. Lining paper FTW.
That's an original ****sy, you have to preserve it or sell it.
