What is the general...
[Closed] What is the general consensus on MTB tandems?
Getting them so hot they stop stopping you is a whole other thing.
You still have good lever feel but can't stop, only slow down.
How does that work then? What causes it?
Posted : 06/01/2013 10:23 pm
What causes it?
Trying to stop at the bottom of long steep hills. 😆
Graham.
When we first went to try out a tandem they gave us a few tips to get us going.
Captain gets on first and stands with legs wide apart away from the pedals.
Then the stoker gets on and clips in. Next the stoker turns the crank so the captains favourite pedal for setting off is in the correct position. Captain then clips in that foot and you both pedal off together.
Sound a bit long winded but works rather well as a base until you get to know what works for the pair of you.
We've got to the stage now when we aproach a gate, mrs ssstu jumps off opens the gate and i ride through. she them jumps back on as i ride out of the gate. 😀
Posted : 06/01/2013 10:34 pm
 JRTG
As said before, it is really worth getting a suspension post too, my wife was really struggling until we got one for her.
I had to shout out for bumps without one (I kept forgetting....)
It does get better as you sort of learn to move with the captain but that does take quite a lot of practice. We got a older version USE one for about £30 from CRC.
[i]"How does that work then? What causes it?"[/i]
http://en.wikipedia.org/wiki/Brake_fade
Or, to put it briefly, there's a maximum temperature at which friction linings will still create friction with the disc or drum.
Long descents can raise the brakes above that temperature, so that they no longer work, just when you need them most.
[i]"Captain gets on first and stands..."[/i]
Yeah, like a lot of things it sounds complicated when written down, but I'm sure it soon becomes second nature.
[i]"I had to shout out for bumps..."[/i]
I'm doing that too. The 2.3" tyres are surprisingly good at soaking up the bumps, but we'll probably get a suspension seat post as well.
Posted : 07/01/2013 9:50 am
Ooooh, need to suggest that one to mrs tandemwarriors, though I think with her wee legs we may need an ejector seat!
We also can't stand and pedal, so lots of grunting low gears. We have folded the 32t sprocket over on a SRAM cassette before!
Graham. I've a USE shokpost in the garage if you're interested.
Rob
Posted : 07/01/2013 10:40 am
Thanks, if it's 27.2mm, then yes.
Posted : 07/01/2013 10:58 am
Not sure it's worth the money, as a lot of the bits look distinctly 'average' but...
Lapierre Tandem in 'invite-only' CRC sale:
£1439.99
Frame - Tandem X2 Race Mtb Alloy Hydroformed
Shock Absorber -
Fork - Suntour Duro 20 Qlc 1,5 120-160mm
Headset - Fsa Big Fat Pig 1.5"
Bottom Bracket - Shimano Octalink Bbes25c18
Crankset - Shimano Lx Td Fcm571 26x36x48 170mm
Stem - Syncros Am 1.5 80mm / Lapierre Tdm 27.2
Seatpost - Suntour Ncx 27.2x350 / Syncros
Handlebars - Syncros Fr2014 40x710 / Black Straight 25.4x580
Front Derailleur - Shimano Slx Fdm661l6 34.9
Rear Derailleur - Shimano Xt Rd-M772sgs
Brakes - Formula Rx 203 White/Blue
Shifters - Shimano Slx 3x9s
Saddle - Lapierre By Sanmarco White/Blue
Wheel - Alex Fr32 / Lapierre Hubs
Sprocket - Shimano Hg50 11x32 9s
Tires - Continental Rubberqueen Tr 26x2.40
Weight - 20.9kg
Posted : 08/01/2013 7:26 pm
A further refinement - Cap'n gets on by leaning the bike away from him and lifting right foot straight over top tube (as opposed to swinging over saddle as on a solo) then stands as above with left pedal forward and crank horizontal. Stoker mounts by putting left foot on pedal then swinging leg over cowboy style whilst Cap'n holds brakes on. Pedals then repositioned for takeoff if necessary.
Posted : 08/01/2013 8:45 pm
We mount the other way around and most other tandem racers we've seen do too. The captain trys to stay on the bike as much as possible with the stoker hopping on and off as necessary to lift the back end around obstacles.
When we've both been pushing I throw my right leg over the front bars and clip in on the right, by this time Madame has lifted her foot over the rear top tube and as I feel her right foot hit the pedal I set off with both of us giving a good push with the left foot to get rolling. A good shove and a half turn of the cranks is usually enough to gain enough speed to allow us to get our left feet on the pedals before a stall.
We're not the most gifted crew so we often resort to running through technical sections where more able crews can still ride - running often proves faster than riding but would no doubt offend any purists watching.
Even if I use SPDs up front Madame often has flats on the back so she can bale and get back on more easily.
Posted : 08/01/2013 9:27 pm
Racing will certainly warrant speed over elegance.
Posted : 08/01/2013 9:33 pm
Just been directed to this thread as I have recently been loaned a tandem by Charlotte's tandems. I am using the tandem to encourage my son, who cant ride a bike due to a disability, to get out on a bike.
Been out for a couple of rides but I am having problems transporting it.
I currently have a Thule 591 bike rack but obviously the tandem is too long, does anyone have any suggestions how I can use this type of rack or any suggestions of what rack you use.
Posted : 07/04/2013 2:57 pm
My 6 year old has learning difficulties so I bought a Kona Ute to take her out on family bike rides. I found the Thule 591 wasn't long enough for the Ute. I toyed with the idea of a third spar across the roof for the back wheel but ended up buying an Avenir Tandem rack. It isn't of the same quality as Thule gear but it does the job. Hardest part is lifting the bike onto the roof of a people carrier!
Tredz doing them for £80.
Posted : 07/04/2013 3:26 pm
I use a kayak V bar http://www.kirtonkayaks.co.uk/home/index.php/shop/shop-racks/134-v-bar-kit with a hole drilled in it and an front axle bolted through. Front wheel off, forks clamped to the axle, rear wheel strapped to the back of the bar. I already had the V bar (and still use it mostly to carry kayaks around - I currently own a Mondeo estate, and before that a 406 estate which the tandem will fit in the back of with seats down and wheels off), so it only cost me about £10 to make, however I'm sure you could buy a length of aluminium section to do something similar with.
Posted : 07/04/2013 3:27 pm
I was looking at buying a second hand thule 591 rack and cutting it up trying to extend the bar that I have. but I think it will take some engineering which I am not capable of doing myself.
Posted : 07/04/2013 7:26 pm
Cheaper and easier to follow my suggestion. I checked on ebay and you can get suitable lengths of alu section for £15 to £20 delivered, and then you just have to be capable of drilling holes.
Posted : 07/04/2013 7:36 pm
Pendle do a roof rack thingy for tandems.
Posted : 07/04/2013 7:53 pm
Page 3 / 3
