What concrete mix?
[Closed] What concrete mix?
And flipping heck redmex, this is a post pad for a posh deck not the Hoover dam. My question about plaster was a question, a handful of cement in a bag of bonding makes it set so fast it can steam, a useful trick used by plasterers to set beading in place. I doubt it works the other way but asked. The comment about watering the hole stems I'm sure from the instructions on a bag of postcrete where it's added to the hole as a dry mix. Small quantities of concrete like a single post hole could dry and not set, I'm sure from your cement knowledge comments you know all that. Your p'taking isn't helpful.
Posted : 11/06/2021 8:23 pm
Well given I’ve never done it before I should err on the side of caution, don’t you think that would be wise?
Yes, a bit of caution is wise, and some good advice was given by most. However some of these suggestions are bordering on the ridiculous, for what you have asked for help with.
I was laughing at the suggestions put forward, rather than your initial question.
You’ve asked the equivalent of which coil spring compressors to buy when swapping the shocks on my Passat and been sent to red bull F1 team HQ as that’s the right way to ensure your suspension will be perfect. When what you need is a simple solution for a relatively simple run of the mill job. Like you said the ground around you is hard as nails already. Dig a hole, and use the mix that’s printed on the back of the cement bag. 😀
Posted : 11/06/2021 9:16 pm
Those look good, just make sure they are suitable (the simpson site will tell you everything you need to know, including approved fasteners, whether it requires the top supported (since you are build a roof, you are 'supporting' the top for most purposes.)
These would be easy to install and adjust but I think srequir top support.
https://www.deckexpressions.com/simpson-strong-tie-zmax-6-in-x-6-in-galvanized-adjustable-post-base/
If you want hidden
https://tradefixdirect.com/post-supports/simpson-concealed-post-base
Posted : 11/06/2021 10:57 pm
I’ve just installed a shelter base on a site in Sheffield! 4 pads@ 1mx 1m x.6 and 2 @ 1.2x1.2x.8 it will be a pergola type shelter about 4m x 5m I don’t think you will need anything quite as Daft any of the mix suggestions with decent resin anchors /threaded rod unless in Sheffield then you will need to use my sizes good luck 😉
Posted : 12/06/2021 12:40 am
Those pad sizes are massive, much larger than I was going to make.
Posted : 12/06/2021 10:14 am
Massive covers it well !! If I was building my own it would probably have 2bags post Crete on each post but you know computer says 6m3 needed.
Posted : 12/06/2021 11:56 am
How deep were they?
I don't have a computer, only STW and my anxiety.
Posted : 12/06/2021 12:59 pm
@molgrips they were 600 deep for 'small' bases 700 deep for larger ones glad im not the only one worried they might not support the shelter safely !! Pity the poor sods who have to break it out in years to come I guess a bit of CAD involved alongside a fear of a PI claim when little johnny is crushed under the collapsing tower. DFE paying so all good in the end
Posted : 12/06/2021 4:58 pm
Page 2 / 2
