VWists. Old Tdi Pas...
[Closed] VWists. Old Tdi Passat alternator removal?
[#6134069]
Our old Passat's (W reg, 1.9 tdi) alternator was goosed, we replaced the car. I'd like to try and fit another alternator as the car is too good to scrap.
I went to remove the alternator only to find the lower mounting bolt can't be fully removed as it hits the rear side of the radiator fan. It looks as though I will have to remove the whole cast alloy bracket that the power steering pump is also mounted to. Is that the only way to get the offending bolt out?
Posted : 22/04/2014 3:59 pm
don't listen to anything molgrips says - he completely gutted his Passat to change a wiper blade 😉
Posted : 22/04/2014 4:01 pm
I have removed the alternator on a B4 Passat actually, but it was not a TDI engine it was a TD, and I can't remember any issues with it. Sorry!
Posted : 22/04/2014 4:08 pm
Thanks folks, I just found this.
http://forums.tdiclub.com/showthread.php?t=200181
Posted : 22/04/2014 4:21 pm
Fix it day at Moont Towers. After a bit of faffage trying to make an alternative to the special VW pulley locking tool I discovered that my Facom ratchet pliers would hold it just as well. Scrappy alternator for £18 all back in and charging perfectly. A couple of wee things for the MOT and I'll fire it on ebay.
Posted : 23/04/2014 6:28 pm
Result. Good work.
Posted : 23/04/2014 6:35 pm
