Train drivers what ...
[Closed] Train drivers what do they do??
steel tyres mean that trains can coast for miles and miles using minimal energy
Funnily enough, someone told me on a bike ride a couple of weeks ago that apparently if you give a train at Caterham station, which is on the North Downs, a little shunt, it can in theory a least, roll all the way Victoria station by the Thames about - 18 miles away.
I'm not sure whether it's actually true but I can well believe it, because despite the only slight gradient, I'm sure the rolling resistance must be minimal.
Posted : 07/02/2011 2:30 pm
Pilots don't earn their money at 36,000ft, they earn it when the plane's near the ground.
Exactly, hence autopilot the rest of the way.
Posted : 07/02/2011 2:57 pm
Banavie, playing with Helensburgh to Oban today, Pass of Brander was enough excitement last year!
Posted : 07/02/2011 3:20 pm
brakes
. . . . or if there might be a leaf on the track within a 300 mile radius
Spoken like a true non railway man who has no concept of what leaves on the line actually means!
And to be fair I was the same till about 2 years ago.
Posted : 07/02/2011 3:30 pm
I feel I should clarify this further having seen another post above again misunderstanding the leaves on the line issue.
While you are not wrong about leaf mulch in autumn causing grip issues, the real danger lies in its insulative properties, ie the signalling system can briefly loose detection of a train.
This can cause the signalling systems route (which in turn protects the train and its intended path) to release and potentially allow another route to set over the top. 2 trains on trying to occupy the same bit of track rarely has a good outcome.
Posted : 07/02/2011 3:35 pm
Leaves are a two fold problem, yes they cause slippage but more importantly they also act as an insulator, in bad area's trains will disappear off the signalling system as they no longer activate track circuits, this could then allow the signal protecting the train to revert to a proceed aspect and allow another train into the signalling section.
NOT GOOD!
Posted : 07/02/2011 3:36 pm
Damn beat me too it!
Posted : 07/02/2011 3:37 pm
Spot on sir!
"While you are not wrong about leaf mulch in autumn causing grip issues, the real danger lies in its insulative properties, ie the signalling system can briefly loose detection of a train."
Wrong side track circuit failures far less common than rail head contamination causing poor brake effect, but yes very dangerous, also theres no alarm given to a signaller by the system if this happens.
Posted : 07/02/2011 3:47 pm
"Experienced a very heavy landing at Edinburgh few years back in awful weather. Pilot earned his pay that day."
It was probably the auto pilot that landed the aircraft, not the pilot.
A mate of mine is an airline pilot and he says its very rare the pilot will land the aircraft. We landed in Manchester in the middle of a serious hail/thunderstorm and the aircraft was pitching all over the place. Some people scream as we came in becuase it felt like the wing was going to hit the deck rather than the wheels. My mate said he was convinced the auto pilot would have done the landing as a pilot would have been too chicken.
Oh and he said the hardest part of the job is not living in one time zone. His bbody is screwed and cant tell when its day or night.
Posted : 07/02/2011 4:01 pm
TPWS stops the train after passing a red signal
Does it? I seem to remember being asked to sit next up front to verify every signal to the driver when this got switched off for whatever reason. (This was nearly 15 years ago though)!
15 years ago and I'm thinking of AWS aren't I.
Posted : 07/02/2011 4:03 pm
That must take some nerve to sit there and not touch the controls whilst a computer lands the plane!
Posted : 07/02/2011 4:14 pm
TPWS, if fitted to a signal, will stop a train which has passed it at danger. AWS stops it if driver doesn't acknowledge an alarm in time.
Posted : 07/02/2011 4:17 pm
I did very little last night, or indeed the night before 😆 Hope that answers the op's question.
Leafall isn't much fun. I braked at walking pace on a bad night last Autumn. Steep falling gradient (1:40ish) All 16 axles locked up straight away, speedo straight to zero (works off wheel rotation-no rotation train thinks it's stood still), sanders and WSP (think of it as train ABS) stopped working as the speedo had stopped working beacause the train's poor ****less computer thinks it's not moving! Hey presto a 250 tonne skeleton bob!
By the time I'd cleared the worst of the contamination and got the damn thing under control I was doing nearly 40mph. I really may have well not been there, it's bloody scary. All that mass, all those people and there's little you can do other that stick the brake in emergency and hope!
Until you've experienced it, it's hard to comprehend. Next time you travel by train on a dank, drizzly Autumn day spare a though for the driver who may well have been through several pairs of p[ants that day.
Posted : 07/02/2011 4:19 pm
Or indeed if it's approaching a red un to fast (or the bobbies told you to pass it a red and you forget to press the override button 😳 ) and for that matter a permanent speed restriction if fitted.
Posted : 07/02/2011 4:22 pm
IIRC the leaf mulch on rails is more of an issue these days, as modern trains have disc brakes which act on the vertial plane of the wheel, whereas older trains had brakes which act on the tread of the wheel, thus clearing a lot of the much off the wheel as it rotates, I think heat generated by braking also plays a part in keeping tread brakes clear of muck too.
Posted : 07/02/2011 5:02 pm
Can't remember the exact number but the chance of a driver hitting someone is really high, some have hit people a couple of times. Not nice for anybody involved.
(Recently retired from industry after 34 years in a nice warm office except for odd trips to Craigentinny, Forth Bridge, and worked at Heaton for a spell)
Posted : 07/02/2011 5:03 pm
😯 Remind me again why I pay £130 a month to get on one of these?
Posted : 07/02/2011 5:17 pm
So, in summary, if a train skids it thinks it's not moving?!?! 😯
Some would say that's a bit of a design flaw there
Posted : 07/02/2011 5:32 pm
Leaf fall season Is horrendous , nothing worse than putting on the brakes and the speedo drops to zero as your heading for a red signal . Truly awfull feeling of helplessness. As they say better to walk 50 feet TO a signal than 5 feet back FROM a signal.
Posted : 07/02/2011 6:21 pm
Dangerous?
Sat right at the front, I mean, if anything goes wrong....
I guess from a stats point of view accidents are rare on the railways, but when they do occur the driver's cab doesn't look like a good place to be.
Posted : 07/02/2011 6:26 pm
Is the conclusion then that drivers do actually earn their pay?
Quite a few S&T type people on here it seems.
Posted : 07/02/2011 6:46 pm
Is there a demand for train drivers? How easy is it to become one. I think I fancy a wee change of career.
This is a serious question btw!
Posted : 07/02/2011 6:56 pm
Not read the whole thread, but my understanding is that much like 'fly by wire planes' trains are at such level of automation, the now only rewuire 1 driver and 1 dog.
Posted : 07/02/2011 7:01 pm
Railway lore has it that one driver at Selhurst depot had so many jumpers that he was called "The Terminator".
Many years ago a colleague of mine was sent out to..... erm look for bits after an incident and barfed when he saw what he thought was the top of a scalp in the mud, turned out to be a large bit of hairy coconut shell! 😀
Posted : 07/02/2011 7:02 pm
Tiggs Its a case of just looking at the passenger companies websites . The likes of First Scotrail took on a few 'Boil in the bag' drivers a few year back as they get government grants to train them up. You would be wasting your time trying the freight companies as the industry really is in a poor state. I've clung onto my job for the past few years by doing other duties (Shunting) but the future looks pretty grim for future freight. If you were succesfull at an Interview you would have to face an aptitude test then company medical . I was 18 weeks in Doncaster then 150 hours with a minder driver before getting my final assesments . So Its a fairly long process.
Posted : 07/02/2011 7:09 pm
Have a look here if you want to see how easy the job is and ho wit is never ever scary and the signallers and train drivers sit on their arses all day....
http://www.raib.gov.uk/latest_news/110131_pn_carstairs.cfm
This was a close one which could have been much much worse if the signalman was not on the ball.
I work in the industry but thankfully not on the ops side, don't think i would be able to remember even half of the rule books that the drivers/signalmen have to...
Posted : 07/02/2011 7:46 pm
For those that think you could train a monkey to drive a train, you'd be surprised how many people struggle with the job. Early mornings, late nights, weekends, takes it's toll on the family life. And yes, it carries it's own stress. Long periods in the cab on your own, not "doing a lot" but if you don't do what you are supposed to do precisely when you are supposed to do it then there may be trouble ahead, literally. When you're clocking up anything up to 15,000 stops a year, with irregular stopping patterns and potential railhead adhesion problems to contend with (explained above but yeah, bloody scary), aggressive passengers, trespassers, stuff lobbed at your window (i've been bricked and had my 2nd man's window put through with an air gun), the constant back of the mind fear of a fatality, not to mention the all too regular killing of wildlife and pets, dogs, foxes, birds of prey etc, it is pretty bloody horrible hitting something as beautiful as say,a buzzard, an owl or some poor family's pet.
The rules, working instructions, local instuctions, route and traction knowledge all add up to a fair weight of knowledge and also a fair weight in books! Yeah, it's good money but we "work" for it, even if it's not the conventional idea of work. Besides, as any railwayman or woman knows, the money means nowt compared to the cameraderie, the stunning sunrises, sunsets and natural spectacles you get to see whilst bombing along, plus working shifts and weekends means we get to hit the trails when it's all nice and quiet, and you can't put a price on that. 🙂
Posted : 07/02/2011 8:13 pm
Your right about the scenery Johnny , I used to go over the Forth bridge at sunrise most mornings and down the Ayrshire coast passed some of scotlands best golf courses truly stunning. I tend to work 3 weeks of long hours and get a week rest free so it Is good for quiet trail centres etc.
Posted : 07/02/2011 8:31 pm
Dibbs - Member
Sitting in the cab knowing that if some pillock decides to jump in front of your train you'd not be able to stop for a mile or so!! Not for me thanks
Neighbour drives for Virgin Trains out of Liverpool to London. He's had a couple of people jump in front of him and to be honest he's not the sort of personality to deal with it well, longer periods of time off sick etc.
Posted : 07/02/2011 8:41 pm
I had an attempted suicide the other night. Stopped about 6yds short of him. He didn't move at all, made no attempt to get out of the way, just sat there on the rail staring at me. "I want to die" is all he said to me when I challenged him.
I did the same job last night and I must admit I felt my stomach tie up in apprehension as I approached the spot.
Posted : 26/02/2011 1:15 am
Bloody hell, that's some heavy shit to have to deal with mate. The poor bloke. 😥
Just 'orrible, that.
Posted : 26/02/2011 1:23 am
I've been the one called out to clear the mess up on more occasions than I care to remember, yes the rail industry can pay well depending on what you do, but it's not a nice job sometimes.
Posted : 26/02/2011 3:00 am
Friend of mine hit a bloke between Birmingham and Wolverhampton a few months back, really shook him up, was off work for ages!
The rules and regulations railway employees have to know is phenomenal, coupled with the unsociable hours, solitary confinements, strict D&A policy and the potential to kill thousands of people in one foul swoop I think we earn our money!
I wouldn't swap my Signallers job for anything!
Posted : 26/02/2011 7:33 am
Enjoy your sleep too much Chris.... 😉
Posted : 26/02/2011 7:46 am
Shhhhhhhhhh
Posted : 26/02/2011 7:55 am
If that were a jumper (its not), it would appear the driver gets a good few seconds for the reality to sink in before the bump...
And failing to dodge a tornado...oops (skip to 50 seconds if you're impatient)
Posted : 26/02/2011 9:31 am
[url= http://www.guardian.co.uk/lifeandstyle/2011/feb/26/run-over-by-freight-train ]Article in todays Guardian[/url]
Posted : 26/02/2011 9:46 am
Page 3 / 3
