Too much oil in the...
[Closed] Too much oil in the car and now it's stopped working.
[#2871994]
The girly friends motor had too much oil in it around a litre too much. This has never caused me problems in my motor but hers conked out on the way to work. The engine still turns but won't fire and there are no visable leaks anywhere so what's the score.? Do I keep turning the thing until it fires. I have let out said excess btw.
Posted : 21/06/2011 9:45 am
Something else I reckon.
Too much oil means that there's less room under the cylinders which increase the pressure in the crank case, leading to leaks and damaged seals. WAY too much means that the pistons can't even turn, as my neighbour found out - he didn't realise that changing the oil meant letting the old oil out before putting in 4l of new oil...
You don't sound as if you have either problem.. I suppose that something might've become gummed up with excess oil during the over-filled state.. spark plugs perhaps?
Posted : 21/06/2011 9:52 am
[i]This has never caused me problems in my motor but hers[/i]
You put 2 pints of extra oil in cars [i]as a matter of course[/i]?
as above - increased crank pressure/pistons slapping oil causing hydraulic compression problems, oil pushed back up engine breather into inlet manifold and oiling engine up.
Inspect the plugs, if they're all oily then it might be worth draining oiul, refilling with the proper amount and changing plugs. After that start checking for bent connecting rods.
Posted : 21/06/2011 10:02 am
That ^^
It's consistent with it conking out after a short while.
You might be able to get it to run by spraying engine de-coker into the manifold as you crank, then giving it a good thrash.
Posted : 21/06/2011 10:08 am
I often wonder how some people get through life 😆
OP - is it a petrol or diesel engine?
Posted : 21/06/2011 10:13 am
There's a reason breathing's autonomic.
Posted : 21/06/2011 10:17 am
If you know nothing about cars it is an easy thing to do. You fill up the fuel tank, washer bottle etc so why not the engine with oil? That was the thinking of the lady I met at the petrol station who had put 5 litres in to the engine with another 5 ready to go in. The oil light had come on, she had stopped, phoned home and was told to put oil in the engine, so she was....
Posted : 21/06/2011 10:19 am
Interesting situation this guy was in. They were both doctors who'd just moved over from India. I saw him struggling one day with a brand new petrol mower (tiny lawn) in the rain with grass about a foot long, he was complaining that the mower kept conking out. I explained about rain and cutting really long grass, then I asked 'Don't you have grass in India?' he said 'Yes, but we pay people to cut it!'
Interesting culture shock really - he was a pretty intelligent and capable bloke and he learned fast, but he was starting from zero experience in anything practical because where he's from if you have any money you pay people to do it all for you.
Anyway hijack over 🙂
Posted : 21/06/2011 10:21 am
You must have got on really well together!
Posted : 21/06/2011 10:57 am
Come over here treat our sick can't even mow the lawn... 😐
Posted : 21/06/2011 10:59 am
We did, I wasn't being sarky! Extremely nice chap.
Posted : 21/06/2011 11:02 am
My mum once filled her Mini engine up with oil till she could see it in the rocker cover (about a gallon).
Posted : 21/06/2011 11:03 am
Yes, they say opposites attract. I mean really, "Don't you have grass in India?"
Posted : 21/06/2011 11:04 am
wwaswas - Member
You put 2 pints of extra oil in cars as a matter of course?
OP, what type of engine is yours/hers?
A bit of oil getting pushed into the inlet won't trouble a diesel, but petrols certainly won't like it.
Posted : 21/06/2011 11:10 am
Posted : 21/06/2011 11:27 am
just think your self lucky it didnt run away at 100 million miles an hour and blow out its conrods and pistons .....
im waiting for the day my old landy does that - the engines notorious for it due to heavy breathing from the rocker to the air intake !
5th gear , dump the clutch and hit the anchors hard if it does 😉
Posted : 21/06/2011 11:32 am
This reminds me of the time that my ex-wife killed her car by topping it up with water instead of antifreeze. And kept using water. And more, until a really cold snap, where her block froze, then cracked, the worked for a couple of miles until the water melted and ran out leading to a seized engine.
That was a fun phone call.
A bit of oil getting pushed into the inlet won't trouble a diesel...
http://en.wikipedia.org/wiki/Diesel_engine_runaway
Posted : 21/06/2011 11:35 am
MTG - other than 'not well' how did it end?
Posted : 21/06/2011 12:16 pm
That or put a load of water into the air intake and hydro-lock it...
Posted : 21/06/2011 12:20 pm
An ex female colleague o ashamedly admitted it took her ages to put oil in her car. She pulled out the dipstick and started filling from there!
had the op now?
Posted : 21/06/2011 12:21 pm
I meant the decorative use of grass in lawns in a domestic setting, obviously!
Posted : 21/06/2011 12:23 pm
That's not me, it's just a video I found on youtube as an example.
I've almost had something similar happen to me though.
Working late shift as a truck mechanic, someone else had fitted a turbo earlier in the day, but left off one pipe as it wasn't in stock at the time.
I was given the pipe and told to finish the job.
I started the engine and it immediately became obvious he hadn't drained the oil from the old failed turbo that had collected in the intercooler.
I drove slowly outside as it was filling the workshop with smoke.
I thought I'd better let it fast idle for a bit in the yard to clear before I took it out on the road for a test drive.
All of a sudden it went flat out past it's normal maximum revs in a cloud of thick smoke.
Turning the ignition off made no difference, it was running on oil, not diesel.
Luckily, it was a manual and I managed to put it in top gear and stall it.
Posted : 21/06/2011 12:28 pm
Had 2 Discovery TDi run away on me at work, brakes full on 5th gear and handbrake and they were still pulling along the road. Luckily was able to force them into neutral and then sit back and watch the carnage.
Posted : 21/06/2011 1:13 pm
After much decking about roadside I have finally got the old girl ticking over and blowing out plumes of steam. The cyclinder head and or gasket has gone. The oil is a nice mix of water and oil and the temp is through the roof. Upon further questioning apparently the car had been making a gurgling noise when switched of. That'll be that then.
Posted : 21/06/2011 1:35 pm
Next time maybe just the amount of oil the engine was designed to take?
Posted : 21/06/2011 1:36 pm
To be truthful I checked the oil last week because it was noisy.! I put two liters in it which came to the bottom of the dipstick. The engine only hold 3.5 liters in total. By my reckoning it had been running round with half a litre in. Oh dear.
Posted : 21/06/2011 1:43 pm
Just to idiot check you, you did let the car stand for a while before you checked the oil level didn't you?
Posted : 21/06/2011 1:56 pm
Related to the oil incident?
Posted : 21/06/2011 2:04 pm
Maybe, maybe not. Don't suppose it helped but I think the damage may have already been done. A few weeks back it broke down due to the thermostat not working. The thing was running red hot and stopped working. Oh well.
Posted : 21/06/2011 2:23 pm
That might've had something to do with it 🙂
Posted : 21/06/2011 2:25 pm
 5lab
you're claiming a disco tdi with 110bhp had enough power, in 5th, to override the brakes? sounds like the engine wasn't the only thing which was broken..
Posted : 21/06/2011 2:30 pm
[i]"A few weeks back it broke down due to the thermostat not working."[/i]
I'd say our grrlfriend's off the hook then.
That's far more likely to cause a blown head gasket than an extra litre of oil.
Posted : 21/06/2011 2:32 pm
I had some Dutch neighbours who didn't know how to look after their lawn and had to ask us. Apparently they don't have lawns in Holland, so I don't see why the India question is so daft.
Posted : 21/06/2011 2:33 pm
5lab, I'd guess that a TDi running on engine oil at 6000rpm could be putting out a lot more than 110bhp. For a short while, anyway. 😉
Posted : 21/06/2011 2:35 pm
No brakes were fine well as much as they were on those, don't get me wrong they weren't hurtling out of control the slowed to an almost stop but they were rolling forward.
Posted : 21/06/2011 2:38 pm
Forum brilliance here. Wide yeed innocence with 'too much oil and the cars stopped working'
And a bit later it turns out that the motor was cooked to death a couple of weeks ago.
There's nothing like getting the full story, and that was ... etc.
Posted : 21/06/2011 3:42 pm
"I had some Dutch neighbours who didn't know how to look after their lawn and had to ask us. Apparently they don't have lawns in Holland,"
looking out my window in van ewickjsluis i can confirm that dutch folk seem to have the most perfect lawns ive ever seen en masse- and i spent 4 years working as a gardener !
also if my old 85bhp landy can over ride 5th and its brakes them im sure a 200 or 300 tDi would have no sweat ... although my brakes are spot the dog awesome since they had new calpers , pads , disks , drums and mastercylinders before i bought it :d the shock factor of dumping the clutch and the brakes at the same time are what kills the engine.
Posted : 21/06/2011 4:25 pm
Sat in Voorburg, I can confirm that grass *does* grow in Holland.
What might be the case is that your neighbours lived in an apartment or had a very small garden when living over here.
Posted : 21/06/2011 5:11 pm
My old man overfilled mine a bit and caused oil leaks in the rocker cover (new gasket and sorted).
Far too much oil? Drain (some) of the oil when engine is cool/cold.
Posted : 21/06/2011 7:46 pm
MidlandTrailquestsGraham - Member
www.youtube.com/watch?v=5zx3qKX_Pno
Yeah, I said 'a bit', not half a gallon 🙂
Doesn't that normally happen with blown turbo oil seals anyway, where the turbo is blowing oil into the inlet, rather than a little overspill?
Posted : 21/06/2011 8:13 pm
A litre over a sump is about 2cm and will make naff all difference even if you really throw the machine around. Engines are designed to cope with overfilling, oil surge and being run a bizarre angles.
An old gneration Cooper S I had with minimalist piston rings had quite a thirst. Overfilling by a litre meant it would just about get to the next prtrol fill up without running dry (a cental pick-up pipe helped).
Posted : 21/06/2011 8:20 pm
