Time to stockpile B...
[Closed] Time to stockpile Baked Beans?
 Rio
it requires an equal amount of standby generation to cover its arse
Quite, so building more wind capacity doesn't help with the problem outlined in the original article, which is that we won't have enough capacity to meet peaks when we close down the old capacity so we're currently faced with buying more gas.
Posted : 19/02/2013 12:59 pm
and buying nuclear power off the french.
Posted : 19/02/2013 1:00 pm
I wonder just how viable it is to build a hydrogen electrolysis system and then run a generator off it for the brown/black outs we shall surely have to come?! 🙂
Posted : 19/02/2013 1:01 pm
well not from using cheezey-feet's link anyway apparently 😯
http://nlcpr.com/Deceptions7.php
Posted : 19/02/2013 1:04 pm
maxtorque - Member
Tidal power is a fantastic solution to power generation,
yes, it's (currently) the stuff of fantasy.
The issue is the potential for huge changes to the ecosystem...
the main issue is that the technology is not ready to go yet, we're still at the testing stage.
and even when it's all completed sorted, it'll be very difficult (read expensive, and dangerous) to maintain.
Posted : 19/02/2013 1:05 pm
At home, not very, how will you seperate the hydrogen and oxygen, then store them, bearing in mind hydrogen wont liquify so needs huge pressures to store not a lot.
Pumping water up a hill overnight then letting it run down again is the usual way of doing it (Llanberris for example).
if you're thinking of something you could bodge up in your shed, you could spin up a load of really heavy flywheels?
Posted : 19/02/2013 1:07 pm
I was considering sloshing some petrol around and having a fag.
Posted : 19/02/2013 1:09 pm
 grum
No Rio, this was your original ridiculous straw man, which you then repeated after I pointed out other countries do much better. Where has anyone ever said wind power is the sole solution btw?
Right now total demand = 47.33GW, total wind contribution 0.14GW. Maybe we could burn some windmills to produce energy?
Wind is at this moment producing 0.09% of UK electricity demand. If that's what we're going to be relying on to keep the lights on we'd better go and stock up on candles, never mind baked beans.
It's a truly pathetic line of reasoning.
Tell me, which forms of energy should we rely on with no backup from any other methods?
Posted : 19/02/2013 1:17 pm
 Rio
Grum, really don't see where you're coming from. The article linked in the original post pointed out that we're closing down generating capacity and won't be able to meet peak demand. Someone suggested building more windmills, I've pointed out that this isn't the answer. As it happens today's situation is a particularly good example of why - it's a cold day, demand is high, there's no wind. Why is that a "truly pathetic line of reasoning"?
Posted : 19/02/2013 1:26 pm
 grum
The word 'peak' doesn't even appear in the original article. Neither did you mention it, you've just latched onto it now to try and shift the goalposts.
Note also that he says this:
"There isn't a single person or people to blame. In my view it was a single event - the financial crisis. Before the financial crisis the government had backed a a visionary approach to energy on wind, water and nuclear... then came the financial tsunami."
So he clearly thinks wind is part of the solution. But you know better obviously.
Do you think it would be a bad thing if we had more of our electricity coming from wind farms like spain does?
Posted : 19/02/2013 1:34 pm
 Rio
Ok, I'll concede on the word "peak" - he's just saying we won't have sufficient capacity unless we burn more gas. But at no point have I said that it's a bad thing to have electricity coming from wind, that seems to be something you've assumed because I've pointed out one of the shortcomings of wind energy. I do worry about this place sometimes. 🙄
Posted : 19/02/2013 1:43 pm
 grum
When someone said 'build some more windmills' you said 'Right now total demand = 47.33GW, total wind contribution 0.14GW. Maybe we could burn some windmills to produce energy?' - clearly implying that they're basically useless.
Can you not see the gaping logical fallacy in that argument?
Posted : 19/02/2013 1:51 pm
in November 2009, a wind storm caused wind farms to produce a peak of 53% of total electricity demand (11.546 GW).[5][6] Power [b]peaks[/b] of 14.960 GW were reached in November 2010,[7] and in November 2011 a new capacity peak of 59% of power demand being generated by wind power was reached.[8]
These were the peaks I referred to.
None but a mix of ones we can control and ramp up using calculated, historic and predicted data to estimate downtimes and redundancy in the system. Coal/Gas/Nuclear/Hydro as a base with weather dependent taking over where possible.
Cover the UK with enough turbines to run everything and it's still not going to work. It will reduce but we will need the big capacity fixed resource stuff to make up for cold still mornings
Posted : 19/02/2013 1:56 pm
 grum
Why do you keep saying this as if anyone has actually suggested it?
Posted : 19/02/2013 1:59 pm
grum - Member
Firstly I don't "keep saying it"
Secondly Anything that is reliant on things outside of our control (Sun/Wind/Waves) is not suitable for critical base load supply. I have no problem with supplementing generation with this stuff. However it is not a solution to the current problem.
The current problem is we have not enough stable reliable energy generation or fuel for generation. Being able to generate half our energy on a windy day is great but I wouldn't want to be relying on it for anything important.
Posted : 19/02/2013 2:05 pm
 Rio
Your words not mine! I was pointing out that they're not generating any significant power at the moment. I regard wind energy simply as a useful contribution to the energy mix that has advantages and disadvantages and must be subject to the same scrutiny and criticisms as any other energy source, and I hadn't realised that anyone would be quite so sensitive about it.
And I wasn't seriously suggesting burning them; I believe they're mostly non-inflammable.
Posted : 19/02/2013 2:19 pm
 grum
mikewsmith - these are classic examples of a straw man argument - absolutely textbook:
There still needs to be something else there or the lights go off. (And the hospitals etc)
No-one has at any point suggested we should have all wind power with no backup, or even anything like that.
Rio - what was this supposed to imply then?
It's not about being sensitive - it's just tedious to hear the same fallacious half-baked arguments about why 'wind turbines are bad mmmmkay' being trotted out over and over again.
Yes, as an argument that they couldn't produce significant power in in the future. 😕
Posted : 19/02/2013 2:23 pm
Why are we obsessing about generating more energy, surely the bright thing to do would be to drastically reduce our consumption? Turning street lights off and capping energy for heating so houses are warm not saunas would be a start. Working in from both ends to find a solution.
Posted : 19/02/2013 2:35 pm
 Rio
Not what I said at all but there is some validity in that view; the best way to look at wind IMHO is as a way of producing energy, so it can save on using other expensive and potentially polluting energy sources in the future. As a way of producing power it is inherently unpredictable; and the message Buchanan has been pushing today seems to be primarily about power (shortfalls in generating capacity), not energy (although he does seem sometimes to mix the two up).
Posted : 19/02/2013 2:47 pm
As much as I hate the idea of nuclear power, unfortunately it is likely to be the best solution until clean energy generation reaches much higher levels of efficiency.
Wind yields have been much reduced in mainland Europe for the last few years - I assume (but don't know) that they have been here too.
To be fair to Ofgem, they have been saying for some time that this reduction in reserve margin in the short term is coming - I recollect the 5% figure being mentioned a couple of years ago. Not sure why the sudden panic now.
Gas to fill the gaps again, but strategically it strikes me as madness to rely on it for security of supply reasons and to a lesser extent cost reasons.
Posted : 19/02/2013 2:51 pm
We're not concerned about generating MORE energy, we're concerned about replacing the generating capacity we currently have.
If we halved our consumption we'd still use a hell of a lot of fossil fuel. We'd like to halve our consumption AND replace the remaining half with renewables.
@Molgrips - looking at the stats, our power usage per capita seems to be equivalent to that of 1960 (source : World Bank) which looks pretty good until you look at population increase - from c52.4m to c62.6m which is a 20% increase so if the trend continues at a linear pace (seems to look more like exponential on the web graphs) we will need 20% more power over the same period. If we are only planning to replace the current demand then we are going to do this all over again very soon.
Posted : 19/02/2013 3:05 pm
 loum
Why are we obsessing about generating more energy, surely the bright thing to do would be to [s]drastically reduce our consumption? Turning street lights off and capping energy for heating so houses are warm not saunas would be a start. Working in from both ends to find a solution.[/s] increase energy imports, at least according to Ofgen's C.E.
But where from? How about oil-rich Northern Mali. It's also uranium-rich for the pro-nuclear camp/French.
Posted : 19/02/2013 3:07 pm
I know but my point is that yes, we have thought of it. Reducing usage and replacing powerstations are both independent activities that can and MUST be done concurrently.
Posted : 19/02/2013 3:25 pm
Page 2 / 2
