Thinking of fitting...
[Closed] Thinking of fitting an electric panel rad in our conservatory - worth it?
[#8019334]
We've put a Supalite roof on it so it's not really a conservatory any more. The roof has lots of insulation. Plus we're fitting a small multi-fuel stove. So we probably don't need a bolier-fed radiator. We like the idea of a slimline wall-mounted panel radiator with timer and thermostat. Are they energy efficient? Whenever I think of electric, it's old 70s storage heaters that everyone wanted to rip out and replace with rads.
Posted : 26/08/2016 9:27 am
100% efficient.
It is just the cost of energy that is more than gas. Look at your KwH costs of gas and electric.
Posted : 26/08/2016 9:34 am
 br
[i]Are they energy efficient? [/i]
Do you want to be warm?
Posted : 26/08/2016 9:56 am
Those roof conversion things do not really make it that much warmer.
Posted : 26/08/2016 10:03 am
If you are going electric then focus on IR radiation rather than convective air. The IR will heat you directly so works well if you have a regular seating pattern you can angle it at but you need to find something that looks good. A radiator, despite its name, doesn't really heat by radiating.
Another solution is the dyson heater, might look a bit more stylish and although an air heater which I just said is bad (in a lossy environment) it is directed air and a benefit is you can use it in summer to cool.
Posted : 26/08/2016 10:08 am
