tied a length of wool round my baby brothers neck whilst sleeping , im told i was around 4 ish, proceeded to tie other end round door handle, BUT the door opened in the way.. damn it !
Rogerthecat- I can empathise with all that, the spider roundabout being a particular focus for new kids to get initiated, lots of grazes and merriment later it was all good, jumping off the top of the big slide(15ft plus) was another feet as was running down said slide without falling over
You don't see them that size anymore
4 air bomb repeaters and as many bangers gunpowder removed and wrapped in tin foil, using blue torch paper bury it and run like f&@k
Had a few fire engines and coppers in attendance, the crater was fantastic
Nicked a good length of magnesium ribbon from chem class and proceeded to spike my dad's cigarettes with tightly rolled balls of magnesium.
Apparently he handed them round at a works monthly meeting with the MD...
I remember not being able to sit down for a day afterwards! 😳
Walked to the middle of Scammenden bridge and climbed over the rail and leant out backwards, often shudder at the thought of it now.
Aged about 13, I was making a delayed fuse for an air bomb to teach someone who had "irked" me a lesson, by adding one of those trick birthday cake candles that can't be blown out to the side of it to give me a few minutes extra to get away before it went off, after leaving it outside their front window!
Unfortunately , whilst dripping hot wax onto the side of the candle to mate it to the blue touch paper ( in the days before theses namby pamby proper string fuses you get now!), said blue touch paper caught fire and started to burn in its characteristic way!
Wouldn't have been such a problem if I hadn't been doing this in our front room!
Blue touch paper lit the primer pyros in about 2 seconds flat, at which point nothing is gonna stop this baby ( [b]thats[/b] why you have the namby pamby proper string fuses you get now!) and the thing started to splutter an hiss ready to pop out the airbomb in our lounge! Disbelief gave way to blind panic!
THINK FAST!!!!
Fortunately, the fireplace was empty, I shoved my arm as far up the chimney as it will go, showering my hand with red hot sparks, waited for it to give a loud pop as it expelled the airborne charge component, heard it rattling it way up the chimney, and leapt away from the fire place........
the noise, when it came a split second later, having been channeled by the chimney back into the lounge, a shape not unlike that of a giant brick trumpet when you think about it can only be described as "JESUS****INGCHRISTTHEWHOLEHOUSEISCOMINGDOWNANDTHEWORLDISENDING"
Cue huge about of soot and debris falling down chimney into lounge. Ears rang for days after.
Got away with that one!
Probably not my worst pyro incident, but perhaps the most exciting!
Not far behind that was trying to make our own Napalm effects by filling a metal paint kettle with mixture of BBQ lighting gel and Petrol, and then placing an electrically detonated theatrical "maroon" in it ( basically a classic "banger" available in sizes from "puny" all the way through to "your kidding right!" but with a length of wire allowing you to detonate it connecting to a 9v PP9 battery)
Basically, we were actually closer to developing our own "daisy cutter" Fuel-Air Explosive than a napalm effect, and when you assesed the size of the scorched area, the area of defoliation, and the ammount of hair loss on exposed skin, its fair to say that 30 feet of command wire wasn't enough!!! Not so much of a bang as an almighty
"Crack - WHOOOOOOOOOOOOOOOOOOOMF" followed by a feeling of all over warmth!!
once after watching tarzan cartoon aged about 8ish decided to try the ivy climb up the side of a disused building, all going well till the ivy got too thin to hold my weight landed flat on my back,winded didnt try it again...
I really want to learn how to make a proper spud cannon so I can hit Wylam or Ovington from my lofty perch...and teach the Boy how to make one (and not get caught).
derelict building site - they weren't fenced off then - took the scafolding planks and leaned them up against BIG BIG trees so could get to boughs and branches - onwards and upwards
only one hospital visit though
BTW, I havw a few 7.62mm and the odd 5.56mm NATO blanks - who's up fo' cordite?
My dad and his fellow garage trainees put their new found welding skills to the test by making a cannon, packed it out with bangers and match heads, added some wadding and a nut and bolt cannonball, put it in a vice and he was the idiot who lit it.
Cue one perforated ear drum and permanent tinnitus, a hole through both sides of the metal dustbin they were using for a target, a hole in the horizontal metal shutter door (the type you get on bus garages) behind, a coach maker missed by inches and a nut and bolt lodged in a door frame...at least I know where I get it from...
Jesus, were you ALL pyromaniacs? 😀
When I was 13 or so me and some mates were trying to get conkers out of a tree. I decided a house brick was made for the job. The brick lodged between some branches and me and a mate ran in to gather up our spoils when the brick became dislodged. I was knocked out cold and needed 12 stitches and had four missing teeth.... 😳
I was brought up in the flatlands of Essex, now home to the Olympic MTB course- Don't get me started. Flat, close to Europe, loads of WW2 airfields that we used to explore. I managed to accrue a fair number of 0.5 inch cannon shells, still live of course. I remember knocking holes into the ides with 6 inch nails to remove the cordite whilst dressed in a full-faced bike helmet and loads of layers of clothes, including my trusty polypropylene snorkel parka. And once I'd shken all the cordite out, I would detonate the percussion cap with an air gun.
My step-dad was an industrial chemist with ICI, and a proper clever bloke. He showed me what weedkiller and sugar can do.
And going back to air-rifles. It is very scary hearing them whistle past you as you walk along the overgrown railway line. I was never hit, nor did I hit my friends. However, my brother was not quite so lucky.
I also managed to electrocute him. He was possibly 3 or 4 years old, me three years older. I managed to persuade him to put his fingers into the terminals of a 12" strip lamp above his bed whilst I pulled the cord... and then he let me do it again! I seem to remember thinking/ telling him that his eyes would light up or something similar. My backside was certainly lit up after that!
He now lives in Australia, I'm now in Wales. Possibly for the best.
:D. We did that but without the ski wear and on a transit van roof. As we couldn't call it [i]trannysurfing[/i] we named it urban surfing. Oh you also had to "sing" the theme tune to Hawaii 5-0.Pugskiing
My favourite activity was to find a plank of wood on the beach and to use it as a wing to see how far over the sea wall you could lean into the wind as the tide raged below.
muddydwarf - I properly lolled at the magnesium cigarettes!
So many of these tales have struck a huge chord, especially the ones involving fireworks. We used to buy huge quantities of those 'cup' caps, empty out the powder and make jam-jar bombs. Had one go off in my face and couldn't hear anything for a good hour afterwards.
One fine afternoon I took it into my head to climb out of a third floor bathroom window using a sisal rope tied round a toilet bowl. All went well up until I put my weight on the rope. My nine year old hands weren't up to the job and and I slid all the way down at a surprising speed. The toilet uprooted itself with messy consequences and my hands were shredded.
Won't start on air gun tales - the last time I bust them out on here someone was offended enough to get my post removed 😳
When I was about 10, I filled up a milk bottle with petrol from my Dads lawn mower. I placed an old rag in it and went down to the canal bridge behind my house. I placed the bottle under the bridge ( the canal went under the road) and I lit (or thought I'd lit) the rag and then ran at a speed comparable to Red Rum. After an hour or so nothing had happened but I couldn't risk going back!
A couple of hours later there was a knock at the door and it was the 13 year old girl who lived next door. She explained that she had seen what I had done and that if I provided her with a regular supply of cigarettes (my Mum used to buy them in the 200 cartons) then my Mum and Dad wouldn't find out. I used to sneak a cigarette or two out each day, but eventually she upped the ante and started to demand packets. As requested I started to give her a couple of packets a week. Unfortunately it didn't take long for my Mum to twig, as she was probably loosing 40 cigarettes a week. I was questioned and my Mum went off to speak to the blackmailers parents.
I don't think my parents found out about the milk bottle!
I was quite into bombs aged six or seven.. and I procured an old dead car battery, some wire and a milk bottle full of old turps..
I took all this to the woods across the road on a huckled sack truck.. I was part way through constructing this weapon of mass destruction when Jenny Brimicombe arrived and I somehow persuaded her to show me her fanny, which distracted me from the bomb task until this day..
Setting fire to things - didn't really matter what to be honest
Finding dry places to skateboard - The local decommissioned warehouse security guard knew us by name and would send letters to our parents
Screamer wars - Those cheap chinese rockets at 50p for 10. We'd launch them at each other by hand (gardening gloves were classed as protective equipment) across the supermarket carpark. Didn't matter if the place was open
We'd scale the walls of the local quarry to get to the hotel gardens at the top. No idea why as there was a perfectly servicable driveway
Playing "knock off ginger" on the houses of the local relatively violent oddballs colloquially known as "Ragga Bill" (his idea of warm clothing was more newspaper up his jumper as an idea of his sartorial code) and "Manwoman" (generally massively excentric chap who dressed as a lady whose exploits included trying to drift across the humber on a raft whilst eating his sunday lunch).
Likewise, garden creeping in parts of town where you'd get a kicking if you were caught.
Encouraging each other to "drop in" on the banks under the motorway bridge on our skateboards. We'd all done it, we'd all been concussed, grazed, bleeding, but people still tried.
Reading these tales of danger and fun it really has become a sanitised world these days, shame as I think exposure to danger is a learning curve we all need for life
Also:
Climbing big trees 25ft plus
Camping in the woods at 12/13
Jumping out your bedroom window to "see if it can be done"
Climbing drainpipes on factories/ school/ offices
Swimming in the local river/ gravel pit
Running the circular bouys above a weir from one side to the other( Trent)
Night fishing on your own at 13
Garden creeping and door knocking ( not dangerous unless caught)
Sliding down the stairs on a tray
Sliding down banisters ( watch the acorn at the bottom -ouch)
Climbing up the stairs without touching the stairs themselves
Bomb making/ pyrotechnics
Experimenting with petrol
Experimenting with electricity
Scrambling on a stripped Honda c90 grandad
Shooting your mates with a gat gun( or stronger if you were posh)
Making bikes / carts out of old bits
Shopping trolley racing
Throwing a long spiked compass into your arm as hard as you can WTF!! But we did it
Smoking gold leaf fags that you bought as singles with your mates,whoever the ash falls off on had to eat the filter, did the same with a polo mint eugh!!
The kids these days are so protected, maybe for the better but through my rose tinted spectacles it was a great laugh
When I was in primary school in south Cumbria we had to share the playing field with sheep ( I kid you not ) and at break times we used to have sheep sh*t fights. We found out that sheep poo that's a few days old goes quite hard and when your 6-7 years old chuffing hurts when it gets thrown at you. Of cause th more daring of us used to throw the poo that was still warm 😯 That made a proper mess if it landed
Rusty Spanner - Member
My younger brother did actually manage to burn the house down (well, almost)... fire brigade, made the local paper etc. I remember looking for him when I saw smoke pouring out of his bedroom window.. he was out by the back fence, trying to set fire to the fence with my dad's lighter!
Best firework trick I can remember was waiting at the bottom of a straight road and when a car appeared at the top, put a lit rocket on its side and watch it shoot up the road, bouncing off the kerbs straight at the car.
this thread is great!
Once in PE at secondary school I was egged on to climb the monkey bars which led to the height of the gym. I then proceeded to jump off, swing on the basketball hoop, not accounting for my fractured wrist which subsequently slipped off the hoop when I got to 3 o'clock!
I fell, hard onto the wooden floor, and all I remember is the teacher leaning over me and saying, "why have you got the schools football shorts on and not your own?".
Ambulance was rung, with everyone telling me stop being a wuss, there's nothing wrong with you, even though I was in agony!
Imagine my delight as the doctor confirmed I'd fractured my pelvis and would have to stay in bed, in the hospital for a whole week.
Another game we used to play was splat the sheep s**t, where you take a brick from a wall, throw it into a turd and use the spray to splat your friends. I stopped playing that after an occurance with a large amount of spray back.
in 1990 a massive all night rave called Nocturnal (i think) came to the miserable little shitty mining town in Northumberland I hail from. Me and all my (just that month left school) mates all had tickets to see all the big rave acts and they were all wanting to try 'E'.....
As we got in I felt petrified at the thought of taking drugs so bought one to look the business and an hour after everyone had theirs and they were blatantly enjoying them I thought i'd shut my mate up by popping one myself. One wasn't enough and had three 'E's in one night and at 6am we left this huge marquee feeling our childhood had just been topped off with a memorable and unbeatable night.
The following 5 years I endured horrendous panic attacks, months of pyshcotherapy and hypnosis. Not sure if it was a direct result but I'd never do drugs again.
one love. 😆
Also, as everyone else seems to be pyromaniacs. You remember the gas tap for the bunsen burner? We had a go at leaving the tap on with the gas flowing for a while with no bunsen on and then lit it at the tap end. The flame was huge, and best of it all the teacher didn't even notice, I bricked it as flames burn and take all the hair you struggled for so long to grow, directly off your body 🙁
Me and my mate fancied our chemistry teacher - Mrs. McCrink. Think young Amanda Burton.
To express our fondness for her, we'd sit at the back row of chemistry lab workbenches and drop our trousers round our ankles. We'd then ask her questions and she'd answer, oblivious to our state of undress.
Bit weird really.
I set fire to my mate's Grandad. When I was 16 or so, me and my mate used to make 'flame throwers' by getting empty 2L plastic coke bottles punching a hole in the lid and spraying lighter fuel inside. Squeeze the bottle with a lighter in front, bosh, flame thrower.
Only issue was the lighter fuel would become liquid in the bottle, and would eventually start burning too, leaving you not very long to get rid of the bottle before it melts.
All good fun until we made one in my mate's bedroom. Got it going, liquid started burning to I ran to the window to unscrew the cap and pour the burning liquid away. Unfortunately my mate's Grandad was standing at the backdoor having a fag. He was wearing an old winter jacket that went on fire as soon as the fuel hit it. Cue angry old boy grappling with burning clothes, gets himself free he looks up and sees us at the window and legs it upstairs to get at us. We had to barricade the bedroom with the bed to keep him out. I didn't go home till 4 in the morning when I knew he would be asleep. Never needed a wee so much in whole life...
[i]Bit weird really.[/i]
Yep!
Post of the year 😆
That all sounds like my childhood! The jumping off walls (& out of trees) thing was brought about playing "Fall Guy". We even made our own body armour
Never really bothered with armour although I did have a Batman outfit which of course made me indestructable.
A mate had a very long brick wall in his garden which went up in steps along its length. The challenge was to see how far along the wall you could go and jump off. We never did make it to the end one of my mates broke his leg and we kindof lost interest 🙂
The throwing arrows brings back memories - we called them 'flights' and made them out of canes. Used to spend quite some time sharpening the ends.
Gat guns also very popular as we got older (i.e teens) the challenge was to see how close your mate allowed you to get before you shot him in the backside.
Fireworks as well - Roman Candles with [i]handles[/i] so you could hold them 😯 jacks to light and throw on the floor, bangers to put in school bags, mini-rockets that you could hold while launching and huge, mental, lethal sparklers
At about the age of nine we discovered a tree that was called the Bucking Bronco, you could sit on a bend in the branch and a couple of mate would pull the branch back and let it go. Wheeeeee you would shoot forward and then fly back, at the age of 9 it was great.
This kid called Simon asked if he could have a go, no problem jump up onto the branch and hang on. By this time there were about 10 kids pulling the branch back and we all let go before Simon was holding on. He flew a very long way and I can still see him vanishing headfirst into a field of long grass. Oh crap we all ran over to help him and were confronted by the poor kid covered in blood where he had put his teeth through his lower lip. This took up all of our attention untill someone noticed a big bit of bone sticking out of his jumper and his arm being not quite right. We didnt see Simon for about 2 months ad the tree was cut down.
Also cycled to Usk from Abercarn when I was about 11, managed to crash twice on the way and it took about 6 hours. Pontypool was really scarey at that age 😆
Under conscription in the South African defence force, nicked a Samil 120 (big truck) to buy some cigs, caught a low hanging telephone wire, I thought it was a power line and panicked, and bailed out of the cab doing about 40mph. End result was pretty spectacular. Ripped out about 14 pylons before the cable snapped.
Me and a friend used to sharpen metal rulers in the DT workshops........Then hit each other over the head with them!
Same mate had an English Dictionary (the really huuuge edition) dropped on his head from a first floor storey window at school. He was out cold for most of the lesson and the english teacher didn't even notice!
We both work in call centres now with no real career aspirations to think of. 🙁
dday - proper lol there, thanks 🙂
O-level Chemistry:
Pouring acetone over our hands, lighting it and then waving at the teacher.
Making paper planes, lighting them and seeing where they would crash en-route to the teacher's desk.
Mixing bench chemicals in the sink (they used to be unlocked on shelves next to my desk!) until it started to smoke/steam and see how fast the teacher could get to the extinguisher.
Stand opposite your mate about a yard apart, with feet wide apart. Then throw knives into the ground, move closest foot until someone bottles - was interesting explaining to the casuality Nurse why I had a throwing knife sticking out of the top of my foot!
Apple cricket - one person lobs them up the second hits them with a bat as far down the row of gardens as possible - points for hitting greenhouses, cold frames and old asbestos roofed garages.
Hedge Hopping - travelling from mates house to mates house through other peoples back gardens without getting caught or chased.
Window budding - in a big gang gather handfuls of rose buds or seed pods, hurl at windows and run, keep throwing them as you run, only the asthmatic kids get caught!
How we stayed out of borstal is anyone's guess!
Making bombs out of 22 live rounds picked up from the ranges on Dartmoor, which involved sawing the round in half??, then packing it all nicely into the golf course greens and blowing big chunks up.
Boring out old toy guns to fire a projectile through, good enough to take a chunk out of a wall at 20ft.
Firing catapults out of friends bedroom window to see who could take out most panes of glass in the neighbours green house. (never got caught).
Climbing onto the ladies toilets on a local beach and using a gas burner and seawater to popp out the glass tiles in the skylight.
Borrowing rowing boats to explore the river dart.
And quite a few other bits which i am never going to own up to, but did manage to spend an afternoon in the local nick with my mate, fortunatley we lied convincingly and got a caution.
So much fun.
to be honest I've not read all of that.. one thing I remember from school (ahem prep school) when we were about 10\11 we were allowed to carry sheath knives, yup you read it knives, and we played a game called chicken, in fact there was another game called streched, anyway back to chicken...
you stood opposite your opponent and threw threw the blade into the ground between his feet, he then moved one of his feet next to the knife, he then did the same, until basically both feet were together and the we'd see who would chicken out...
quite a few LOL from me sat in a totally silent office
I remember pouring white spirit into a glass candle and lighting it, we sat round watching it for a minute until the glass exploded - shit us all up. Plenty of throwing stones and getting chased too 😀
We once went night fishing (d*cking about and drinking beer while one of my mates did some fishing) under the Itchen Bridge in Southampton, it was quite a cold night so we decided to build a small fire on the shingle shoreline. One thing led to another and we had a pile of old wooden pallets burning away nicely, what we hadn't noticed is that the tide had come in slightly and the fire had moved up the bank and off the shingle and onto the concrete. We realised what we'd done when there was a huge explosion and lumps of concrete and burning pallet were thrown in the air lighting up the underside of the bridge and spreading all around us. Needless to say my trousers were a little brown after that!
Made 'dobbers' which effectively were a plank of pallet wood with a wooden peg taped to one end. Inside the peg usually reserved to hold your smalls was the metal spring from another peg. This was then gingerly attached to a huge f***off rubber band stretched to the end of the plank. We used to chase ourselves sillyfiring them. Obviously top score was the bollocks. I can still remember the blood curdling screams now. How I managed to produce 2 kids years later ill never know.
Mate of mine had an air pistol.
We took his younger brother out one day, showed him how to use it, gave him a lecture on safety and responsibility, and how this was not a toy and very dangerous if he wasn't careful.
First thing the little bastard did with it was shoot me in the arse.
My mates and i had a little trick in afternoon English lessons, the teacher was invariably late after break so we would open the window (2nd floor) and my mates would lower me out by my ankles..
The classroom beneath us was laid out so the teacher had his back to the window, i would magically appear upside down making obscene gestures to the delight of the class before rapidly disappearing upwards again 🙂
Went on for a few lessons before the teacher below clocked me! 😆
EDIT: Just remembered they did the same trick over a railway bridge to see if a train was coming, apparently if i screamed the answer was yes!
