Thanks 👍🏼I’m near the south coast, however, so will look to hire one in the new forest to see what’s what. Much obliged!
Its well worth doing! The tandem club has a list of hire places on their website - I think in the publicly available bit
Mikertriod, I can help out if you want to try something as we are down near south coast, we have a bit of a collection, can try either a Galaxy (ours is a bit gravelised for the occasional trail shortcut, now runs discs front and rear too) or our 29er one, even got a 26in kiddyback too. Drop me a message if your interested.
Great thread! Well resurrected too. The missus had never ridden a bike in her life, until we hired a tandem in Bristol a couple of weeks ago. With the three year old on the back in a child seat. Rode along the river to a pub, combination of tarmac and slightly bumpy dirt. Small wheels (a la Brompton, though maybe not that small). I captained (obvs) & she stoked. TJ is spot on, getting started was occasionally problematic and madame rodent now knows what it feels like when you get shinned by a pedal. Also my propensity to suddenly stop pedalling elicited a few choice bits of language. And the small wheels made it somewhat unsteady to ride.
But, surprisingly, overall it was deemed by the power that be to be a 'good thing' and given she's probably never going to learn to ride a bike there could well be a future in it..
NBT I might be interested in the mountain bike tandem. What's the sizing? I'm 6'3" & the missus is 5'11" so would need to be quite large. Also any idea on cost?
EDIT - Just found it on classifieds. I'm Manchester based so could have a look at it sometime if it's the right size
Aye I'm coming at from an on road, fully loaded touring perspective. Sometimes it's not possible to save all your braking for the bends as you need to keep your speed down before then. Tandems are much faster downhill than solos and you can reach indecent spreads very quickly. We've topped out at over 60mph on ours off one of the big Alpine passes in NZ. Coming off at those speeds in lycra doesn't bear thinking about.
'Traditional' braking is at least 2 vees (or cantis if its even more prehistoric) and an Arai drum brake. The drum brake is used with a Suntour Power shift lever if you can get one and left partly 'on' during a big descent. This moderates your speed without putting heat into the rims and gives your hands a rest. The tandem never gets away from you then. We descended the infamous 20%+ Greenhow Hill into Pateley Bridge on just a rear vee and the drag as we'd run out of front block material. We got the Arai so hot it was smoking and then steaming when squirting it with a bidon.
The option to drag a disc when needed is less appealing even if it's cabled actuated as it's easier to warp the disc. Some recent tandems come with a rear vee as a drag brake and disks. My gold standard would be cable discs (Spyres) and an Arai drag brake but I'm pretty sure they never made a hub that can take both discs and is threaded for an Arai.
I totally agree with TJ about trying one out.
It's sometimes easier for a non cyclist stoker as they've hardly ridden a bike, meaning they won't be too bothered about trying to turn, brake and change gear on the back, which obviously they can't do.
We were lent a tandem by the wonderful Jon at the 'Bicycle Smithy' in Stockport. After a weekend of playing around, we decided it was for us and we purchased our own tandem.
There has to be a lot of communication and trust.
It's so much fun tandeming together, either for a full day out or a trundle down to a local pub.
Boblo - I am just going to disagree with you 😉 - there is no need on road IME to drag brakes - and yes we have done big descents at 50+ mph. Even if you want to reduce your speed on the straight ( why?) you just use a different technique with discs - brake hard for a few seconds then release. Dragging discs at low speed will cook them but there is no need to do this. The other thing to do is alternate brakes when descending. With big discs you have so much braking power that dragging is really not needed
I'm with TJ on this. We've used the Dawes for touring with Panniers hit 50mph a couple of times - hit the brakes hard and release. The new road tandem has Spyres front and rear with 203mm rotors, and a rear v-brake that we use as a parkig brake. I suppose it could be used as a drag brake but I've never felt the need
@funkrodent, You're welcome to pop round and have a gander / test ride. I'll PM you my details
We went on a weighbridge once fully laden and including us - approaching 1/4 of a tonne thats with a fully laden trailer - that rig did get a bit floaty and flighty above 45mph so required a few dabs o the brake to keep it below that
I got beasted by a couple on a tandem yesterday on my commute home - amazing how much momentum they can build up! Admittedly I was JRA from some birthday drinks so wasn't going for pb's, but they must've been sitting comfortably above 25mph on the stretch where they caught me - was properly impressed.
Want one now...
Donwhill - insanely fast
Flat - still fast, as long as you keep pedalling
uphill - rapid deceleration to Dead Slow, approaching Dead Stop.
It's much easier to maintain speed on the flat once you're up there, but getting up to speed - or getting up hills - can be hard work
Its the wind resistance - only a bit more than a solo - but a lot more power or weight pushing you downhill. Someone worked out for me once that downhill your terminal velocity is 60% higher
Why tandems are slower uphill I have never found an explanation for -= tho it seems to be true. YOU need a massive gear range to cope - specially has you need a lot of skill to stand up and pedal
Oh the amount of times we've discussed this whilst slogging it uphill & still non the wiser too.
+1 for not dragging brakes, dragging builds up too much heat, much better to pulse brake if you need it.
We have a voice activated panic brake - rear vee with lever on stokers bars 😃
@bpd message sent 👍🏼👍🏼
We don't drag brakes on aircraft taxying as that's a sure fire way to get them hot.I'm guessing it's the same on a bike!
Unless of course it's designed as a drag brake... The Arai is, the others not. 👍
Why tandems are slower uphill I have never found an explanation for -= tho it seems to be true. YOU need a massive gear range to cope – specially has you need a lot of skill to stand up and pedal
I think it's possibly because your legs are more tired from sitting and pedaling, on a solo at least you get to stand up and honk to stretch about a bit if you want to.
I'm guessing disc brakes do away with the need for drag brakes?
Maybe. In the days of rim brakes there was a risk of blowout/blowoff(!) through overheating if you 'overused' your rim brakes. This was alleviated by moderating top speed via the drag brake and then using the rim brakes normally for corners. The blowout/blowoff risk is a non issue with disks but if you go for hydros, you'll obviously need to manage the new risk of boiling the brakes hence my suggesting Spryres.
There are circumstances where you might still need to moderate top speed between corners (poor road surface, very steep etc) and there's no option but to use your primary brakes for this if all you have is disks. P'raps drags were in vogue at one time and aren't now, I don't know. I have them on both of my tandems but no disks so all I can comment on is my own experience (50k loaded touring miles all over the globe...).
Mikertroid
As you can see its a topic of much debate. Personally I have discs front and rear tand that is it. Never felt the need for more or for a drag brake
I think the drag brake thing dates from when bicycle brakes were poor and also from people not understanding that you can use the front brake hard along with a lack of understanding of how discs work
Thousands of us use tandems with discs with no issues, however even some manufacturers ( Thorn!) refuse to use them at all ( I think they will now put one on the back as a drag brake - a use they are useless for)
It is possible to boil hydro discs - but you have to try really hard. I also know of people that melted the plastic bits on BB5s. However I also know of people that have had tyres blow from overheating rims with rim brakes.
For me - big discs with heat resistant set ups - no skeleton discs, nice big discs
This is all very appealing to the inner geek in me! I sense I'm going to enjoy this journey...!
For maximum nerdyness, his n hers matching jerseys are required. Something I absolutely refuse to engage in... 😉
We deliberately clash!
We bought one of those Ridgeback Panoramas from Freewheel a couple of weeks back (£1249)...and it is rapidly turning out to be the best bike & marriage related purchase I have made in many a long year!
Isn't the faster-on-the-downhills/flats, and slower-on-the-uphills thing simply due to the combined power to weight issues vs air resistance? i.e I'm slower uphill on the tandem than on my road bike but Mrs Rexated feels like we're going much faster upwards than when she rides alone...at slower speeds air resistance has little effect cancelling out much of the efficiency of the tandem. Compared to solo riding your power-to-weight ratio goes down for the stronger rider, and up for the less powerful rider?? At higher speed the aerodynamic efficiency trumps the power related stuff.
mike, we went for the medium; I'm 5'10" and she is 5'2". there's quite a lot of adjustability for the stoker's cockpit in terms of reach and height. The bike fits me like a road bike, whilst for Becca it is more like an mtb position i.e. more upright and with wider bars, which gives her more confidence (admittedly it is misplaced confidence given that I'm in charge of steering and braking!).
oh, and re the brakes, after an initial bedding in period the cable actuated 200mm discs either end do the job just fine even on longer steeper downhills (although north devon doesn't exactly have alpine topography). coming from a mtb back ground I'm happy to feather brakes and also brake hard into corners....not a roadie-esque 'drag them all the way down the hill' approach. no problems yet.
That's great, thanks! Sounds good fun!!
@rexated assuming Spryres, they are quite alarming when new.... I have them on a couple of solos and braking was notable by its absence prior to bedding in. Fantastic after, shite before... When you change pads, either semi sintered or race further boosts their performance.
bobble - yes, they're Spyres - thanks for the tip.
One thing to budget for - a suspension seatpost makes it a lot more comfy for the stoker. Parallelogram types are best
Remember rule number one for tandeming. The pilots job is to make sure the stoker enjoys the ride
there is no rule two
Nobody ever told me about matching riding tops. Its a no from me. nbt likes pink and I like blue (wink).
@tjagain. There is another rule intrinsically link to your "rule No 1". Never miss an opportunity to stand up.
I'm with TJ on all of the above; after many years of tandem rides for bad weather commutes, café days and especially touring, our Dawes Double Edge has settled into a fast and fun set up:
Rigid fork; wide, strong bars and chunky stem. Hope M4 front for control, BB7 rear for emergency heat handling, both 200mm. Thudbuster post on the back. 3x10 to get the extensive gear range and yes, it's very slow up 20% climbs like the Lecht. And stupendously fast down the other side. Wheels are 650b, 36h on Hope. These fit in the 26" frame just fine with tyres around 38mm, even with mudguards on.
Fastest trailer descent was well over 85kph and we've never had an issue with boiling that front brake. We also do what TJ describes, braking in sharper bursts and communicating this to the stoker, so she doesn't get a fright. See Rule 1.
A tandem copes mush better with a wet, windy day than a conventional bike, plus the Mrs gets a better view of the world when not having to watch out for hazards
For the Tandem Curious, I have a Circe Morpheus Semi Recumbent Tandem - Ideal for Touring Scotland, and you can hire it! It comes with 4 panniers and a trailer for gear or a child and expedition support if you need it.
Got a French Family coming next week doing some West coast and Trossachs.
How are you getting on with the tandem?
Still enjoying it! We're going cycle camping on it this weekend in fact. Hope the weather holds up! 🙂
Alpkit/Sonder have a ti tandem for anyone with waaaaaaaaaaaaaaaaaaay more money than sense.
Fixed that for you there.
We're off out on ours next weekend (bank hol) for a food festival up in South Shields. We'll be taking a couple of panniers and stocking up on nice stuff (rabbit black pudding, anyone?) : )
The davinci symbiosis used to have a ti option and if you hit the options list hard you could get up to over £10 000!
Well, I’ve put the deposit on the Ridgeback and pick it up with the g/f in a few weeks. Very excited about it TBH. Planning on doing some decent mileage to get in sync prior to the trip.
Reckon the trip will be about 600kms all in, which will mean 100km/day which I’m hopeful will be manageable.
Tickets booked so I’m beyond the point of no return!
Dumb q: on the ferry you’re booked as a foot passenger, do you normally pre-book the bike (ferry bookings open in a few weeks)?
Just got to workout a means of carrying and dispensing ashes without the stoker or bike getting covered in them!! 😬
Last time I went on the ferry I seem to recollect some confusion over the 1 bike 2 people situation, so we must have booked the bike on 🤔
Whats peoples view on the ridgeback panorama for pucker touring - it looks a good basis but I'm not sure about 700c wheels & 36 spoked wheels?
NO reason why the wheels should not be strong enough for road touring. The days of needing high spoke counts for tandems are over really - stronger rims and spokes have seen to that. We run a 36 spoke wheel - admitedly rohloff and 26" so stronger but that is used for offroad touring and is still surviving.
In my experience most ferry operators require you to book your bike. P&O give a friendly little prompt on their booking system if you book one bike and 2 passengers, checking that you are riding a tandem. DFDS count a tandem as 2 bikes, and booking has to be done by phone - their website can't cope with booking 2 people and bikes.
Cheers TJ 👍 was the only thing putting me off as we broke 5 spokes on our Dawes last year, but to be fair that was on a 12yr old bike & spoke fatigue was probably the cause. Just need to get Mrs DB on board with the purchase.
36 will be fine even for touring with panniers on, our gravel/road Dawes has 48 spoke, very stiff but makes for a sluggish ride feel, we have used 32 holes on our mtb tandems for years they’ve been fine, we have the odd spoke break in the rear but no major issues, so if your touring just take a few spares just in case taped to the chain stay. We are currently in Vermont riding with the Etor group at the Kingdom Trails on a rented Ventana Edcm which has 32 hole boost wheels, strength and stiffness is fine as they are getting a hard work out on the trails here.
