Space saver spare w...
[Closed] Space saver spare wheels - help
[#10221409]
My Zafira tourer has no spare wheel and after a flat which was not fixable with the foam/compressor, i want to buy a space saver spare.
Is it just a case of matching the the bolt pattern and making sure that the wheel/tyre overall is the same size (or near as dammit) as the existing wheel/tyre combo?  A "kit" is about £250 which seems ludicrous!  Seems to be plenty on ebay for different cars for way less.
Posted : 12/09/2018 6:04 pm
Scrapyard will be cheaper. Wheel needs to be large enough to accommodate the brakes and some need shorter bolts
Posted : 12/09/2018 7:35 pm
Your manual should specify the size of the relevant wheel for your model. Size isn't necessarily a match either, usually just bolt pattern, mount hole and enough offset to clear the brake.
Posted : 12/09/2018 7:53 pm
