So the lock has die...
[Closed] So the lock has died on the patio Door!
[#4757389]
And its stuck locked!
Its the actual lock mechanism on the door, not the cheap handle. When i removed the handle it seems something has dropped and now there is nothing there that will bind onto the square rod.
Its a UPVC tilt and slide patio door.
So what are the options on removing or fixing it, any ideas?
Posted : 16/01/2013 1:45 pm
wd40? mine have seized in the past and liberal wd40 is the only thing, then once open stick bike lube in. its a bit heavier weight and wont evaporate as easily.
Posted : 16/01/2013 1:54 pm
Last time I used a locksmith it was about £100. I guess thats your best course of action.
Posted : 16/01/2013 1:56 pm
Ti pin man the lock seems to have actually fallen apart leaving the 5 or 6 sliding pins locking in place. I wish it was just a simple spray of wd40.
I thought the handle had gone and even have an emergency supply of them in the loft as they are so crap but its not that.
Looks like it may be a call to a locksmith then!
Posted : 16/01/2013 2:00 pm
