servicing a nissan ...
servicing a nissan note
Take a look at Manol oil. I picked up 20l of the stuff for less than £50, enough to do 5-6 oil changes on our cars.
Posted : 20/07/2023 1:21 pm
4 clips, right.  id better get looking for the other two then 😀
thanks
Posted : 20/07/2023 1:30 pm
well its still baffling me so ive taken a couple of pics.
ive dropped the front and side clips as you can see, but i cant find any way of undoing whatevers at the back, if they are indeed clips.  they look more like hinges than clips, and no matter how i wiggle and jiggle, nothing unfastens.
any ideas?
Posted : 20/07/2023 3:13 pm
got it!  and i could have saved myself all the faff if id just looked at my handbook in the first place 😀
it shows a pic of it tilted down just as ive got it above ^^^, there are only 2 clips and they are indeed hinges at the back.  i took that air pipe out the front to give me a bit more space and it jiggled out.
all done.  i know its only very basic, but ive saved meself over £100 i suppose, and learnt a few things.
thanks for your help chaps.
Posted : 20/07/2023 3:44 pm
simondbarnes and jairaj reacted
That's a £99.99 fee please !
Posted : 20/07/2023 4:13 pm
oh 🙁
and it was going so well......
Posted : 20/07/2023 4:45 pm
simondbarnes reacted
and it was going so well……
...have you just driven it!😬
Posted : 20/07/2023 4:48 pm
just a bump on this as following the heavy rain just lately, the wifes just discovered one of the rear footwells soaking :-/
we've had leaking problems for ever with this car and ive been on the nissan forum previously, which has prompted me to seal all the top light clusters, the tailgate light, and bits underneath the tailgate, all to no avail.  we found the spare wheel swimming a couple of years back so i left the drain hole open and its been fine since (solved the effect, not the cause).  the practical person in me wonders whether itd be a good idea to drill a hole in the footwell so at least it doesnt pool, but im not exactly sure whats under there.  itd be a bit silly to drill through a brake pipe wouldnt it 😀
any advice?
thanks
Posted : 27/07/2023 5:49 pm
Does the car have a sunroof? If so check that all the drains are unblocked (for the rear footwell). Else it could be the membrane behind the door card has failed or has come unsealed/stuck. Double-sided tape and and building membrane for a cheap replacement.
The spare wheel well was always damp in our old one. Double check that the tail-gate seal is properly in place. The high-level brake light seals can fail as can those around the rear light clusters (the material hardens and no longer conforms to the body openings).
Posted : 27/07/2023 9:42 pm
Might be worth checking the rear window washer pipe isn’t leaking.
Posted : 27/07/2023 9:48 pm
doesnt have a sunroof no, but i'll check the door membrane and tailgate seal (would that leak into the footwell tho or just the spare wheel area?).
i remember now that the rear washer has never worked, so there may be a problem there.  think i looked into it at the time but couldnt sort it.  however, itd only leak water if i tried to use it wouldnt it?  if thats the case, i never do, so i cant see it leaking from there?  or if theres a leak would it be constantly trying to fill the pipe even if i wasnt pulling the lever?
thanks
Posted : 27/07/2023 10:34 pm
Rear tail gate seal will fill the spare-wheel well.
Does the pump motor run when you attempt to clean the rear screen with washer fluid? If so the tubing may be broken inside the RH side bellows on the tailgate. (This is also where the lock release and rear wiper fails when the cables break due to fatigue. It's a pain to remove and repair the broken bits and you will get burnt with the soldering iron trying to splice cables back together).
Posted : 27/07/2023 10:54 pm
not too fussed about the spare wheel well now that it drains, i think ive come to terms with the fact ive sealed all the light clusters and it still leaks, but as long as it doesnt pool i can live with that.
yes the motor works when i try to wash the rear screen but no water comes out, so i just never work the motor.  thats why i wonder if theres a constant leak, or if it would only leak if i were to try and use it (which i dont).
gut feeling is its wet cos of the rain, so i think its a leak and will investigate the door card thing.
thanks
Posted : 28/07/2023 12:44 am
update.  found a ripped rubber door seal which ive siliconed up, but..... belt and braces, ive drilled a hole through the floor pan now so at least it drains.
was surprised that under the carpet theres also a lump of polystyrene, so the actual floor is a fair bit lower than the carpet, so mebbes it wasnt actually a pool but just spreading along the carpet?   anyways, ive drilled a hole in each rear floor pan now so will await the next heavy rain with anticipation.
Posted : 29/07/2023 10:38 pm
Page 2 / 2
