Seat Ibiza - retrof...
[Closed] Seat Ibiza - retrofitting parking sensors or camera
[#8413768]
My better half has a 2013 Seat Ibiza Fr which comes with the detachable Garmin navigation/media unit.
The car has not been factory fitted with parking sensors or a reversing camera however on similar spec cars these options are available and link in with the satnav unit as a display.
Does anyone know if a camera or parking sensors can be retrofitted and tie in with the existing car equipment rather than having additional sounders / displays.
Is this type of thing a job solely for the main dealer or should i be looking else where?
Rusty
Posted : 23/03/2017 3:26 pm
I did a quick search on Seatcupra.net & it was a bit unclear. Sounds like you can fit a Cobra kit, but I wasn't sure if this ties in with the in-car screen or not.
A few threads mentioned the dealer doing this job for around £200-300.
Here are the links I found anyway:
http://www.seatcupra.net/forums/showthread.php?t=421116&highlight=retrofit+parking+sensor
http://www.seatcupra.net/forums/showthread.php?t=418660&highlight=retrofit+parking+sensor
http://www.seatcupra.net/forums/showthread.php?t=342385&highlight=retrofit+parking+sensor
Posted : 23/03/2017 4:12 pm
Cheers for seaching stumpy. Seems a bit of a minefield.
I'll pop the dealer we bought from a email and see if they will quote me a price for installation including integration to the seat portable system head unit.
Posted : 23/03/2017 4:38 pm
Good luck with that. I would expect something crazy like £1000+ to come back.
There are loads of after market fitting companies, I would try that route.
Posted : 23/03/2017 4:45 pm
 Solo
Ime, Stumpy is on the right path.
I've two VAG cars and whenever I've wanted to retro fit stuff, I scan the forums. Usually there's a "how to" for the common retro fits.
I have a VCDS cable and a copy of Elsawin, both of which are very useful.
Posted : 23/03/2017 4:49 pm
