Recommended Car tyr...
[Closed] Recommended Car tyres
Do some of you have .... Tracking issues ?
Posted : 26/08/2012 10:23 pm
stay away from Wanli tyres no matter how cheap you are
noisy as f***!
and I don't want to get anywhere near the limits on these. thankfully I drive like an old fart so probably never will
! I took the car (2006 Citroen C4 1.6 petrol) in to the garage for emergency oil diagnostics recently. After changing the oil & oil filter, they did a test drive & thought the wheel bearings were well & truly fubarred, so they checked - no problem with wheel bearings, just noisy tyres
Posted : 27/08/2012 12:42 am
Yeah, Wanli's are noisy 🙂 Still got one on the back though it's time is nearly up. It's done 33k on there though...
Posted : 28/08/2012 9:34 pm
 hora
On the Toyos I thought they were quite mushy on my mx5 had to run them at a higher psi
Posted : 29/08/2012 7:06 am
I have run Falken ZE912 on mine with good results, good performance all round and cheaper than the 'big' brands.
Posted : 29/08/2012 7:27 am
After all the "it's your only contact with the road", "it could be a child's face next time", etc etc scaremongering I bought uniroyal rain-experts. Then this happened within 500 miles.
Track use by any chance? If so did you remember to increase pressures to support the sidewall (it's only stiff sidewall R rated tyres that have pressure reduced as they heat up).
Otherwise I'd go with the tyre compound being/going off for some reason (storage conditions, manufacturing issue).
Posted : 29/08/2012 9:49 am
Remember tyre performance is weight and drive specific, what works well on a heavy RWD may not suit a light FWD (chooose your own comparions). As a decent middle of the road (hee, hee) tyre I've used Yokohama A-Drive's before with great results on light-medium weight FWD cars.
Posted : 29/08/2012 9:56 am
Page 2 / 2
