Recommend me how to...
[Closed] Recommend me how to break down a door..
[#7366112]
Frantically packing to go on holiday in 2 hrs.. Youngest (2) has locked herself in the bathroom.. I also can't find my kneepads or hip flask... Waaaaaaa!
Posted : 02/10/2015 12:47 pm
Get her to sit in the bath with a towel over her head.
Shoulder it.
My youngest once locked herself in the loo at Dover Castle. Now that was a heavy door.
Posted : 02/10/2015 12:48 pm
What type of lock? Can it be disabled by removing the outer door handle?
Posted : 02/10/2015 12:50 pm
Kind of door is it?
what ever you do don't kick it, it hurts!
hammer directly behind the bolt with a n old block of wood between hammer and door.
Posted : 02/10/2015 12:51 pm
Kick it open. Very satisfying, however quite destructive.
You could always just chop your way through gently with a hammer - most interior doors are pretty flimsy.
Posted : 02/10/2015 12:52 pm
Do you have some sort of flat bit on the end of one of your legs, perhaps covered in leather or rubber? Take that and introduce it swiftly to the offending door approximately where you remember the lock to be on the other side. This will encourage the lock to disengage and the offending door to open in a brisk and enthusiastic manner, so it may be prudent to ascertain the locality of your small person before attempting the procedure.
as HtS but get your wife to abseil down from the roof and go in through the window sinmoultaneously - just to be sure
Was your plan to down the whiskey then knee the door in?
Posted : 02/10/2015 12:53 pm
Most modern bathrooms have a slot on the outside you can stick a coin in to open it. Presume it's not one of these?
Lucky guy. Enjoy Center Parcs.
Posted : 02/10/2015 12:54 pm
Unless you live in Dover Castle just kick it open. It really doesn't hurt unless it a composite door.
Don't Shoulder it. It WILL hurt and the door will flex and absorb a load of the force.
Talk the child into opening the door. It'll take time but if the were able to lock they can usually open it again.
Failing that.......
If it's a slip bolt on the inside... Kick it where the bolt is. Try and concentrate as much of the force of the blow into the edge of the door directly behind the bolt.
If it's a turn button on the latch it should be operable from outside using a screwdriver. If not see above.
Butch Cassidy style?
Posted : 02/10/2015 12:55 pm
If there is a window in the bathroom then get child to jump whilst you hold a sheet above a mattress on the ground, jobs a good'un.
But you only get one chance so make it count.
Try speaking in riddle
Posted : 02/10/2015 12:57 pm
 luke
2 hours thats loads of time! On holiday in Crete with a mate who at the last minute whilst waiting for the bus to the airport to come home, got caught short, the bus was ready to go and still no sign of my mate so I go to the loo and call his name, he has the bolt part of the lock in his hand and asks if I can help, using my weight a shoulder to the door and it gave way, my mate was in front of the door when it gave way, we made the bus.
May be a daft question it's not a lock you can put a screwdriver in from the outside and turn?
Can you access the hinges from the outside and unscrew?
Talk him through how to unlock it?
Shoulder to the lock end would be my choice if not a sledge hammer to the top and bottom corners as well as at the lock.
Posted : 02/10/2015 12:58 pm
Good advice, then (s)he'll be safe if the noise generated when forcing the door attracts the attention of the Ravenous Bugblatter Beast of Traal.
I was thinking more of the frame splintering.
Posted : 02/10/2015 1:01 pm
Good advice, then she'll be safe if the noise generated when forcing the door attracts the attention of the Ravenous Bugblatter Beast of Traal.
Hey, you sass that hoopy Harry the Spider?
There's a frood who [b]really[/b] knows where his towel is! 8)
Posted : 02/10/2015 1:03 pm
Many lols
Posted : 02/10/2015 1:04 pm
20 mins of not getting annoyed persuasion and we are back in the room..
now what else have i forgotten..... apart from knee pads?
Posted : 02/10/2015 1:36 pm
How's progress? Is any of this helping? Or have you gone for more dynamite?
Hoof the door in the slats, obvs 😉
Posted : 02/10/2015 1:41 pm
Posted : 02/10/2015 1:55 pm
Gonna need a bigger van...
[URL= http://i219.photobucket.com/albums/cc310/jenga101/2015-10-02%2013.56.03_zpsmjh8n6ns.jp g" target="_blank">http://i219.photobucket.com/albums/cc310/jenga101/2015-10-02%2013.56.03_zpsmjh8n6ns.jp g"/> [/IMG][/URL]
Posted : 02/10/2015 1:58 pm
Ho, ho!
Posted : 02/10/2015 2:08 pm
At least someone got a Duffbag...
Posted : 02/10/2015 2:10 pm
Don't be silly,you could get another 10 2 yearolds in there
Posted : 02/10/2015 2:13 pm
Mkae sure she goes for a wee before you set off
Posted : 02/10/2015 2:14 pm
Don't worry about it. You're sure to remember at about the time you are too far away from home to turn back.
Posted : 02/10/2015 2:21 pm
Knee pads still missing.. there's another childs bike, 6 more bags, 2 adults, 3 children and a Labrador to fit in yet
Posted : 02/10/2015 2:40 pm
What about the hip flask?
Posted : 02/10/2015 2:44 pm
You need packing lessons more like.
Posted : 02/10/2015 2:56 pm
Re-packed leaving without something important??.. have a nice week everybodyeeee
Posted : 02/10/2015 3:26 pm
Right lads, he's gone. Anyone know how to break down a door?
Posted : 02/10/2015 3:34 pm
Yeah, First of all , DON'T PANIC, now, do you know where your towel is? 😀
Posted : 02/10/2015 3:42 pm
You were clearly no good at tetris. That's a woeful example of van packing.
Posted : 02/10/2015 3:44 pm
All I know is, if it's one of those barratts scheme chipboard and cardboard deals, don't kick it in the middle, you end up stuck with your leg through it up to the thigh and people taking photos of you, while the person on the other side steals your shoe and throws it out the bathroom window
Posted : 02/10/2015 3:46 pm
