Recommend me a stri...
[Closed] Recommend me a strimmer and a hedge trimmer?
[#9677363]
Is better to go petrol or electric?
This is for unruly gardens, with bramble and weeds. Hedge is box, and needs trimming twice a year.
So this multi thing - is it worth it or will it be a load of crap?
https://www.sgs-engineering.com/garden-tools/strimmers/sct501-52cc-five-in-one-multi-tool
Posted : 20/11/2017 12:42 pm
A) there's never a question. Always petrol 😀
B) imho the 'all in one'things are very much 'Jack of all trades, master of none'.
Can't help on the hedge trimmer as I have a crap electric Bosch one. Strimmer, however, I have a Stihl fs40, and it's great. Only issue is the auto line feed is ****.
Posted : 20/11/2017 12:53 pm
Stihl make a multi use job, but its mega money.
Posted : 20/11/2017 1:41 pm
bramble and weeds.
IME - four years from jungle to lawn(ish) - if you get on top of brambles for a couple of years the need for lots of strimming becomes less. I bought cheapest Stihl strimmer, its been worth its weight and now is used a lot less than before.
Posted : 20/11/2017 1:48 pm
yeah this my plan to get it to lawn...
Posted : 20/11/2017 2:15 pm
I've got the Ryobi equivalent - not as nice as a Stihl or Husquavarna but fine for garden and clearing local trails use.
Posted : 20/11/2017 5:09 pm
I have a petrol Stihl long reach hedge trimmer and it's made a job that absolutely hated [when using a normal electric trimmer] into one that's not bad at all.
So much quicker and easier.
Posted : 20/11/2017 5:12 pm
Don't buy cheap tools. That will break after little use or just not start next year.
I use this lightweight echo petrol strimmer nearly every day (mainly just trimming grass edges)
https://www.forestandarb.com/iqs/dbitemid.324/ldicdb16ops.%5B13%5D/sfa.view/Strimmers_Brushcutters.html?gclid=Cj0KCQiAl8rQBRDrARIsAEW_To9rZAMICvlPNdHoUjvxEAQl6tlONIc1uovGNgrBC03iXHr9ik-uI0AaAnaSEALw_wcB
And also have a few echo hedge cutters which have been faultless (All echo stuff comes with a 5 year domestic warranty)
I'd be tempted to buy a strimmer and hire a hedge trimmer for a weekend to see how you get on doing it.. it's quite hard-work if you've never spent the day using one).
Don't forget decent eye and ear PPE
Posted : 20/11/2017 5:19 pm
petrol strimmer defo.... Ive had two cheapish mculloch ones that have been very reliable.
For the box and other bits, I have a B & Q Mcallister lithium battery hedge trimmer and its surprising good. Cuts through some pretty chunky stuff and no cable to cut through either, which is a bonus.
Posted : 20/11/2017 5:21 pm
I have a Ryobi petrol strimmer which has seen a good few years use but after replacing the crankcase gasket has never been the same.
I bought one of those 5-in-1 things. Strimmer Ok but tried the chainsaw and it stripped the gear in the head after 20 minutes use, Vibration from the engine means I can only use for about 1/2 hour before having to stop.
I also have a Draper strimmer which has been the best for about 3 years. Recently just stopped for no apparent reason. I discussed with their service department and they repaired under warranty despite the age (although I suspect this was down to the service engineer) and now it's good to go again.
Posted : 20/11/2017 5:22 pm
I bought a Stihl HS45 hedge trimmer years ago to tame several hundred metres of 12' high conifer. It's still a hateful job involving many trips to the tip but at least the trimmer doesn't make it any worse. It's been totally dependable in ~15 years and mostly just gets the odd sharpen with a file.
I also bought a Husquavana 525RX brushcutter recently to take out to France. It replaces a ~20 year old Sovereign catalogue jobbie that's been OK if not a bit frustrating as the bump feed never worked well and the machine always ran a bit temperamentaly. I can't personally vouch for the Husqy yet as it still adorns the hall though they get decent reviews.
I wouldn't piss about with battery unless it's a tiddly job as you're always waiting for it to charge and I definitely wouldn't go mains powered due to the cable restrictions.
Posted : 20/11/2017 5:26 pm
For brushcutter go for the blade not line. Stihl auto line jobs have been launched in to the undergrowth in a fit of frustration too many times. The blades are lethal though!
Stihl.
I'm properly 'casual' when it comes to safety, but i wouldn't advise a bladed brush cutter unless
A) you reeeally need one
B) you've had a smidge of training
C) you have the proper PPE, ie appropriate reinforced boots, trousers, etc. They are absolutely brutal, and can do a serious amount of damage. Think chainsaw levels of maiming.
Posted : 20/11/2017 5:54 pm
I have a stihl brushcutter and hitachi hedgetrimmer, both petrol. Much abused, several parts fitted ovef the years. Saves loads of time, avoid electric omes you l just ut the wire.
Re protective clothing, its a must. Brushcutter flicks up stones that really hurt your shins, facemask has been hit a few times too. You should get the starter kit of ear defenders, face mask etc.
Posted : 20/11/2017 6:11 pm
Stihl for strimmers and hedgetrimmers and you'll only ever have to buy once.
Posted : 20/11/2017 7:09 pm
I bought a used Stihl fs450 about five years ago, Ive cleared and maintained a long driveway and woodland undergrowth with it. For brambles you really need a three pointed blade. I've not had any of the bumpfeed issues other have with the Stihl autocut head. Get yourself a big drum of cord, it will last years.
With a bigger machine you really need a harness and PPE. The first day I used mine a stone flicked up, flew the width of the drive and was still flying at head height for a cars width when it smashed the rear window of my DIscovery.
Our hedges are topiariazed and we still do that by hand. Forearms like Popeye are guaranteed
Posted : 20/11/2017 7:25 pm
Local garden place has the stihl stuff. I am going shopping tomorrow.
Posted : 20/11/2017 7:28 pm
