Recomend me an elec...
[Closed] Recomend me an electric shower
[#3599831]
As title, give me your experiences with 8.5kW electric showers. I need to replace mine but don't want to replace the cable. The current shower was a cheapo and has been rubbish from the start. I have a heat only boiler with no storage so no chance of using a mixer shower. If anyone has flow rate information that would be good.
Posted : 23/01/2012 6:56 pm
They are all much of a muchness. More expensive ones have the same insides as the cheapest, but with a fancier outer cover.
Be aware that most showers advertised at 8.5kW are actually 7.8kW at our nominal voltage.
Screwfix have a Triton at £60, I wouldnt pay any more than that, as it wont get any hotter no matter what price you pay if you are limited to 8.5kW.
Alan.
Posted : 23/01/2012 7:08 pm
 Bear
Hang on, no storage, so what do you do for hot water at other outlets if you have a heat only boiler?
Posted : 23/01/2012 7:20 pm
Bear - Member
I new that wuestion was coming. It is for a unit on industrial estate. Hot water comes from 10L multipoint electric water heater, but we need a shower occasionally.
Posted : 23/01/2012 7:35 pm
 Bear
No room to fit a small unvented cylinder?
Posted : 23/01/2012 7:36 pm
re: replacing the cable.
If the cable exists then simply tie a new heavier cable to the old one and pull the old one through whilst pulling the new one in. Easy! And you can now install a much better shower.
Posted : 23/01/2012 7:40 pm
Bear - Member
I have been considering this but it sounds expensive. What sort of cost is the unvented cylinder? Can it be done DIY or do I need a registered fitter as it is a pressurised vessel
Posted : 23/01/2012 7:42 pm
Note sure about lower power ones, but we have had a Mira for years, and when it eventually broke, the very friendly Mira guy came round, fixed it and charged around 50 pounds for the privilege (new main board). A week or so later, we got the cheque sent back to us with a nice letter saying that the fault was a design flaw, and they weren't charging for it. Shower was about 6 years old, and I was happy to pay for a repair.
For this reason, my next electric shower will be Mira.
Posted : 23/01/2012 7:48 pm
Bear, I've not priced Unvented for a while, but I'm sure I could install a small combi for less. What do you think?
We got a Mira electric shower for the ensuite from Boundary Bathrooms. Their service is excellent too. If I remember it was cheap too
Electric is what it is, poor flow, doesn't like lime scale, but has it uses. I fitted ours purely so we had hot water if the boiler went down overnight.
Posted : 23/01/2012 7:55 pm
 Bear
You need to be registered to fit unvented cylinder, but money well spent as you could get get rid of the multipoint.
Gledhill do a decent one with a 25 year guarantee on the cylinder.
Posted : 23/01/2012 7:56 pm
Scottish & Southern Electric - Utter f***ing shower.
Posted : 23/01/2012 8:30 pm
mira sport.. the issue with electric showers is plenty of options for entry for water and the electric the mira sport has by far the best / most options.. as for your cable.. just cos the old cable didnt burn through doesnt mean its good enough get a spark to check it out..
Posted : 23/01/2012 8:43 pm
