Hustler, TBF they look OK.
Pigface - the bluer your eyes the more sensitive they are to sunlight. I have to wear top grade high mountain lenses for sailing and certainly for skiing. The good news is they are cheap.
i have one pair of Oakley's i bought them over 12 years ago for about £80 i have worn them most days (sensitive eyes) about 7v years ago i had a bad crash broke my helmet and chiped my cheek bone the lenses of my Oakley's got a v shaped scratch exactly the same shape and size as the scar on my cheek. Two years ago the frame snapped in my pocket when compressed oddly fixed easily with super glue, then i got hit by a car the frame died but the lenses survived inducing one i picked up from the middle of the road 5 hours later.
i have replaced the frame at a cost of £30 the lenses for £25. 3 or 4 times i have rung oakley and had the arm covers / nose bumpers replaced free of charge when lost or worn.
So a value for money product over its life time and really really robust . i am also sensitive to optical distortion and have never noticed any with the selection of lenses i have.
Crankboy's Oakleys
[b][url= https://en.wikipedia.org/wiki/Luxottica ]Luxottica[/url][/b]
As a vertically integrated company, [b]Luxottica designs, manufactures[/b], distributes and retails its eyewear brands, including Lenscrafters, Sunglass Hut, Pearle Vision, Sears Optical, Target Optical, Eyemed vision care plan, and Glasses.com. Its best known brands are Ray-Ban, Persol, and [b]Oakley[/b].
Same. Same.
been using some oakleys for 15 or so years now, money well spent.
I'm thinking about prescription sunnies for road use, what worries me is that I look back often (as you should) and look out of the corner of my eye - prescription lenses won't help me there I suspect..
I prefer wraparound versions due to wind drying my contact lenses out, which is why i was looking at Smith etc.
Nor will they help you when it rains, or you're out at dusk or later...
Which is what made me go for contacts.
I've had a pair of Oakleys in the past and was fairly unimpressed. The quality of the lenses and frames wasn't above Bloc and perhaps worse than Bolle, a personal fav. They were expensive versions too. Full alloy frames (exepct for the shitty plastic hinge).
Just out of curiosity, which metal framed Oakleys have plastic hinges? I've got a number of pairs of different O's, and the metal frames all have hinges in the same material, as they're an integral part of the frame, same with plastic ones, although Frogskins had metal hinges when they first came out, but are now all plastic.
[quote=twisty ]The real life difference IMHO between £5 safety glasses and something a bit more expensive is the latter usually has coatings that help water bead off and reduce fogging up, they can also be polarised/photochromic.
Anti-fog coating on my £5 safety glasses, which seems to work as well as on anything more expensive I've owned.
Though you do identify the things I'm missing - tempted to try a pair of Tifosi photochromic as those are about the only ones I've seen which aren't getting silly expensive. Might have a look at some fishing glasses for polarized lenses given they've been suggested on here - would be handy for watersports.
Looking at the Bolle website...with them doing clear/yellow and tinted glasses with anti-scratch and anti-fog lenses, designed for far more intensive environments than riding a bike, why do people spend silly money on eyewear when a lot of their stuff costs around £10 a pair? Serious question.
Optical clarity
Fit
Comfort
Eye/Face coverage
Venting
Range of lens tints
Ability to change lenses
The way they look
The fact they make the wearer happy
Etc.
'Optical Clarity' 🙂
[url= https://www.amazon.com/Oakley-Mens-Jury-Rectangle-Sunglasses/dp/B004L2JUZO ]Oakley Jurys do[/url]. I'd forgotten the model but a quick google of "broken plastic hinge oakley no replacement" soon found it. I was offered a £50 voucher. As well as the broken hinge, the lens was delaminating and bubbling around the edges. Some film on it. Perhaps the polarizing layer. It's never happened before. They were well taken care of ie. fresh water after the pool or salt water and not a scratch on them.
You are only given one set of eyes, why risk damaging them by getting cheapo sunglasses with "100% UV protection" ....(Some are possibly more likely to actually damage your eyes than protect them)
Shenanigans!
The wife and I use these for our riding and RC flying and have never had a problem with them.
http://www.rapideyewear.co.uk/product.php/11/expert-cycling-sunglasses-and-running-sunglasses
They also have a full range of replacement lenses and frames.
Well.. I dropped £80 on a set of Smith Asana glasses from RXSports.
They come with three lens options, dark mirror, Ignitor (rose tint) and clear. First opinion was that they are well made & the lenses are a decent thickness/rigidity & well finished with rounded edging. The nose clip has 4 adjustment positions which is nice, and the arms feel solid.
The 'clarity' is good, very good in fact & combined with a rimless design means you forget they are there - the very light weight helps with that too.
Thing is, I'm tight as a ducks arse, and £80 is a lot of money..
..so, are they worth the outlay? I'm not convinced they are worth quite that much but they are noticeably better than the triple lens glasses they replaced, that I paid £40 for.
No- one looks good in white framed Oakley's
You've apparently never met me then 😉
Maui Jim's are worth the money,
Stupendous charity and colour.
I've some RayBans I splashed the last £100 of some holiday money on at Brisbane airport 10yrs ago.
They've more than earned their keep.
But these days I'm wearing Animal prescription sunnies that came from Boots.
They are spot on.
Just about to get them re-glazed again, for a new prescription.
Oakleys I struggle with, as they are plastic. £200 for plastic glasses...
I'm sure they are great, but on a middle aged ginger nut, of rotund stature...
Went for Endura Mullets in the end.
Light-reactive lenses with holes so don't fog up.
Nice fit - not used in anger yet - that's tomorrow.
£31.50 at Wiggle = bargaintastic.
Hope the mullets work well cos they're certainly fugly.
Beauty is in the eye(wear) of the beholder 8)
No its not worth it. Just like any other thing you want to consider e.g. cars, houses, bikes, clothes etc. Cheaper alternatives are always just as good, sometimes better. But they're a luxury and we're lucky enough to live in the first world and these things are nice, so why not if you can afford it. I've got 2 pairs of Oakley's I got in sales - still chuffing expensive for sun glasses, but they're nice and I like them alot, but they're not any better functionally than cheap sunglasses i've had in the past - and i'm alot more precious about them which is a pain sometimes.
