Pretty Fly(press) F...
[Closed] Pretty Fly(press) For A White Guy
[#5525303]
Vices? Pah - this is proper hardware 😉
Posted : 17/09/2013 5:27 pm
Thanks for that. The background has reminded me I need to look into getting a loft ladder fitted.
Posted : 17/09/2013 5:29 pm
You monster 😡
Posted : 17/09/2013 5:38 pm
Posted : 17/09/2013 5:52 pm
That looks like you set it up in an aisle in Maplins...
What *is* a flypress?!
Posted : 17/09/2013 6:34 pm
I remember using one of them when I was an apprentice and getting tw@ted in the head, arm hand every time it span back round. OK it may have been operator error but it hurt like hell and I feared the beast.
Proper chuckle at Jamie's photoshop.
Posted : 17/09/2013 6:40 pm
Nice, looks even better on its own cast iron stand as well.
I bought this saw a while ago. Proper cast iron heavyweight, I had to get a friend to unload it with his JCB. 🙂
Posted : 17/09/2013 6:47 pm
isn't it missing the 'flies' ? The ones I have seen had 2 heavy balls with holes through the centre mounted on those 2 bits sticking up.
Posted : 17/09/2013 6:49 pm
Yeah, our ones at college in the jewellery workshop have balls on them. Nice mind, even sans balls.
Posted : 17/09/2013 6:51 pm
Do you have any surplus tooling for it? I'm looking for a 6mm x 15mm racetrack slot and a 15mm radius for ours.
Posted : 17/09/2013 6:54 pm
No balls or tooling. I do need a large pair of balls. However such things are available on the Internet I'm told.
It was fun getting it out of the van and into the shop without a forklift 😉
Posted : 17/09/2013 7:08 pm
only needs balls if you are ****ting big bits unless you have a bit of weight to put behind it.
presumably the stop works too on yours? (will stop the self-****ting of head, arms etc)
Posted : 17/09/2013 7:14 pm
Jamie, I don't think that's a fly.
I know they're useful things but it looks like something you'd use to make cheese, or do the laundry in the 1800s. This is the POWER-MANGLE.
Posted : 17/09/2013 7:17 pm
It's definately a flypress, trust me, I'm a ducter.
Posted : 17/09/2013 11:06 pm
Yes - it's a bit stiff so I'll strip it down and clean it sometime, but all works perfectly. Was pretty pleased to get one with the original cast stand.
Posted : 17/09/2013 11:46 pm
 JoeG
Are you sure that it is not a really old Park headset press? 😉
Posted : 18/09/2013 6:24 am
Oh, it's going to be fantastic for headsets - might need to be careful not to flare them a bit 😉
Posted : 18/09/2013 10:25 am
Oh, and apart from needing some big balls, the ram is also a bit sticky - I'll try wiggling it, but it might need lubrication.
Posted : 18/09/2013 10:26 am
Now stripped, cleaned and rebuilt, with the dings ground off the ram - so it's now super smooth 😉
Posted : 18/09/2013 2:00 pm
Because I know you're all on tenterhooks and it's been over a week since my last update, here it is fully operational:
Now with tooling to cut metal in interesting ways, and giant yellow balls for more oomph 😉
Posted : 26/09/2013 10:56 am
 ed34
what are the balls for?
Posted : 26/09/2013 11:03 am
They add momentum to the rotating arm.
Posted : 26/09/2013 11:05 am
 JoeG
Brass balls or balls of steel? 😀
Posted : 26/09/2013 7:16 pm
You have big balls sir.
Posted : 26/09/2013 7:25 pm
get smacked with that and you'll know it.... well when you wake up.. 🙂
Posted : 26/09/2013 7:36 pm
Nice tool.
Posted : 26/09/2013 8:03 pm
To make sure when you're stupid enough to ram it into your head it hurts twice as much 😆 I ended up in A&E with mild concussion courtesy of one of these just after I'd finished my engineering course at college 😳
Posted : 26/09/2013 8:28 pm
Cast iron 😉
I've got the stop set so I can't hit myself with it (again)...
Posted : 26/09/2013 11:31 pm
