poached eggs again....
[Closed] poached eggs again.....
for those that use the silicone cups, do you have a lid on the pan to get it steamed on top?
Posted : 09/09/2015 4:47 pm
I usually wait till they are nearly done then just submerge the cup a little to make sure the top isn't too runny.
Posted : 09/09/2015 4:53 pm
I just don't get all the spinny, vinegar, salt, ling film etc methods.
Take water to boil. Back it off so there's just a hint of a boild. very carefully crack eggs (at room temp is best) into water. upto 4 in a mid sized sauce pan this way
Push down on toaster button.
When the toasts pops, eggs will be cooked, increase heat for a second to get a 'boil' which lifts them off the bottom.
Eat.
Posted : 09/09/2015 5:25 pm
doesnt happen the same way in my pans. boil water, back off heat so no water movement, crack room temperature egg into ladle, gently tip side of ladle into water, "oh b*ll*cks look at that massive white spider taking over the pan, wheres the space for the other eggs now??" :-/
Posted : 10/09/2015 7:14 am
You will get some leakage - there should be a core poached egg forming though.
I'm wondering if the water is cooling down too much?
For me, bubbles coming off the bottom of a pan in size and slightly less quantitity, as if it was a frying pan filled with lemonade.
How much water are you using? Should only be enough to cover the cracked egg - 1.5" ish.
Perseverance man; keep trying!
Posted : 10/09/2015 7:18 am
yep, shallowish water, like i say i knock the heat right off. ive found bubbles for me make the situation worse by spreading out the tentacles even more 😀 i try to have the water as still as possible.
Posted : 10/09/2015 7:49 am
Boil water in pan. Take the pan off the heat, turn heat to minimum.
Break eggs into water while pan is off the hot hob. Put the pan back on on minimum heat hob. Put bread in toaster....
Eggs ready once the toaster pops up !
Fresher eggs work a bit better. The white breaks up less I find.
Posted : 10/09/2015 7:53 am
It's basically that balance of bubbles & heat you're trying to get.
Try heating the pan [b]slowly[/b], so you build up the temperature - more productive way of learning what works.
When it's letting off a handful of small bubbles, dive in.
(and fresh eggs do make it easier) 🙂
Posted : 10/09/2015 7:56 am
Doesn't using oil or butter to line the cling film or silicone cup partially negate the benefits of poaching over frying? If you are choosing to poach your egg because it's the lower calorie option, I mean?
Posted : 10/09/2015 9:03 am
In further fried egg news (which are miles better than poached anyway), the Aldi single egg frying pan was christened successfully last night. I'm happy to say that it produces a perfectly round fried egg, in a suitably non-stick way, that could have been designed specifically to fit on one of these..
I'd say thats 2 quids worth of kitchen equipment that is definitely going to get some hammer. They've got them in at the moment if you like your fried eggs and you've got no mates 😀
Posted : 10/09/2015 9:15 am
Page 2 / 2
