Plumbertrackworld -...
[Closed] Plumbertrackworld - blocked sink
[#5872028]
My kitchen sink is blocked. If I run the tap for about 15 secs, the water bacsks up into the sink and then slowly drains away over the course of a few minutes. I am interpreting this to mean that there's a partial blockage below the sink, but before the main drainpipe - does that make sense?
As a ham-fisted amateur, is there anything I can do apart from pouring chemical stuff in, and then calling a plumber?
Posted : 20/01/2014 9:04 am
I got one of these;
which worked better than the really cheap ones you can buy and reached the P Trap in the main drain.
It did clear out a lot of crud from the pipes but in the end I had to get the main drain hosed out by a pro as the P Trap was full of crap.
Posted : 20/01/2014 9:07 am
Check the u bend first - should simply unscrew
Posted : 20/01/2014 9:10 am
 teef
Stick a piece of a metal coat hanger (or similar) down the plug hole and agitate - might clear the blockage without undoing the u bend and a lot less messy.
Posted : 20/01/2014 9:17 am
 kcal
Simple plunger (Dalek type), close off the air outlet with a cloth possibly, get some hot water down there first.
Probably bits of food gunk or congealed fat.
Posted : 20/01/2014 9:24 am
Get some of that Mr Muscle sink unblocker stuff that you pour in, leave for 10 mins and then rinse away.
Posted : 20/01/2014 9:25 am
The U-bend is clear and unfortunately the pipe immediately below the plug has inlets from dishwasher and washing machine, so plunger probably won't work. Such a hassle for a small thing 🙁
Posted : 20/01/2014 9:28 am
