I only want to fit this thing once so what's reliable, quiet and worth fitting? We're probably looking at using a dual flush button thing, but apart from just going on price it's hard to know what's what - any experienced advice welome!
make sure you can get at it without ripping your wall apart when it goes wrong 🙂
otherwise they're fairly straight forward. The use an air pump to get your button press to the syphon.
Go for a Grohe, they do a nice system complete with a frame to hang the pan on for a modern clean look. All of the internals can be accessed by removing the front flush plate.
+1 Grohe Adagio is the one you want, no real need for the frame, only really need this if you're going wall hung pan and even then you can knock one up out of timber.
I'm not a plumber, but I've noticed that plumbers on sites always appear to [i]whisper[/i] when they're talking about [i]concealed cisterns[/i]. Hope that helps.
Umm thanks Ernie.
Looks like the Adagio is a single flush - so would the Eau2 the obvious choice for a dual flusher?
