Plastering metal me...
[Closed] Plastering metal mesh lathes - do you pva them?
[#9824043]
Hey all,
Have a small bit of plastering to do but it’s onto wood.
So was going to get some metal lathes
This -> https://www.wickes.co.uk/Expamet-764-20-Expanded-Galvanised-Mesh-Coil-115mm-x-20m/p/220379
Was going to staple it to said wood then plaster.
Question is do you need to pva these?
Many thanks
Liam
Posted : 07/02/2018 11:17 pm
no need to pva but i would use galvanised clout nails to fix it as wouldn't of thought staples would be galvanised. nails also make it easyer to pull it nice and tight by fixing them at a slight angle.
if its more than just covering a wooden lintel may be worth packing it slightly of the wood to really allow the plaster to get hold of the mesh
Posted : 07/02/2018 11:56 pm
I had to repair a corner where I'd removed a fitted cupboard, I glued the corner bead on with a hot glue gun! Worked a treat.
Posted : 08/02/2018 12:03 am
+1 clout nails also remember to put it the right way up
Posted : 08/02/2018 12:05 am
yeah that'll work, i usually use gripfill for thin coat beads if theres nothing to nail to. used to mix up a bit of skimming but its much easyer to glue them on.
Posted : 08/02/2018 12:09 am
