[i]my speaker and amps setup is probably worth £7000[/i]
I think that's the price, not the value 😉
no, that's the value to me (and to replace without hitting ebay) 😆
From a HiFi point of view, the idea that the most important part of the system is the speakers is a very "1970's" point of view.In terms of reproducing accurately from the source, the most important point of the system is said to be the front-end (turntable/CD player/whatever) and in descending order through the system until the speakers are reached. This is because, if at any point information is lost in transferring between the seperate bits of equipment, no subsequent piece (however excellent) can get it back...
You mean before the audiophile bulllshit marketing industry really got going?
I bet you couldn't tell the difference between a 320kbps MP3 and a high end CD player in an ABX test.....
JY - Yup, this is fundamentally why I think you are a hypocrite Woppit.
I can't even get the speakers located in the right place.One reason why I think computational approaches in which multiple speakers and DSPs are used to correct the room response are interesting. Obviously not as good as getting the room right in the first place, but still interesting
Tact/Lyngdorf promote using small satellites and putting two subs actually against the wall, or in the corners - which might be a more WAF friendly approach. The idea is that the impulse response from the room corner is easier to correct digitally than having to deal with room reflections.
They sell some subs which actually go quite high in response - and using two subs they then crossover up around 300Hz rather than 100Hz.
I heard their setup at a hifi show a while ago - I thought it sounded sh1t!
BBC did a double blind test - found that people couldn't reliably tell the difference once MP3 got to 256kbps...
That's not really true. 1970s/ 80s advice would've been to spend more on the source, the reason being that turntables are expensive to design and produce. The advent of mass produced CD players and hard disc storage means that "spend more on the speakers" is actually contemporary advice.
Expensive cables and cheap cables with the same characteristics (impedance, resistance, etc) will perform exactly the same as electrical connectors. However, if you are evaluating them as "hi-fi components", the effect of marketing and price have to be considered as well, so expensive cables probably are subjectively better:
http://en.wikipedia.org/wiki/Bandwagon_effect
http://en.wikipedia.org/wiki/Belief_bias
The BBC also found that DAB sounds 'annoying' below 192kbps - which is why they run all their feeds below this apart from radio 3.
Choose speakers first (what criteria?).
Match a cheap amplifier to the requirements of the speaker.
Connect any source.
Use inexpensive commercial studio cable throughout.Can someone give an example of a system like this?
Or is it still really subjective?
I reckon the first step is constraints - what will the missus put up with, how much money have I got?
Objectively, I this sort of setup is probably best:
http://www.avihifi.co.uk/adm9.html
Active speakers, decent DAC, not ludicrously expensive. I'd look for measurements of the frequency response from the speakers, which you can often get with studio monitors. Trouble with studio monitors is that they often look awful. Shiny black plastic yuck.
I don't honestly think there is likely to be a fat lot of difference between electronics these days, once you get past a certain point (buying from someone reputable etc). ABXing is made difficult because people are very sensitive to volume levels, and can be very difficult to accurately set the output level during comparisons.
Subjectively, there are lots of other things to take account of. You might enjoy the way a particular setup colours the music, so an objectively better system might not suit anyway. You might like the way a hulking great shiny amplifier looks in corner and says 'expensive'.
no-one here is argueing against that as far as I can see.
As I find grums' comments regarding my "hypocrisy" to be extremely offensive, especially after my subsequent posts attempting to politely explain my position (which seems perfectly reasonable to me) in as friendly a way as I can manage, which I doubt he has read, I am taking no further part in the discussion.
It's a strange one, this, isn't it. Everyone's arguing whilst actually agreeing with each other.
There's nothing wrong with that. Objectively, the best watch is a £5 casio, but you might well prefer the way a vintage Omega looks and feels.
Woppit - it may offend you but you are a hypocrite. Your argument only reinforces that. I wouldn't be being so hard on the point if you weren't so vehement in your criticism of others who show the same faith-based reasoning.
It was true in the 70s and it's still true now. The most important part of the system is the bit that reproduces least faithfully. That is the speakers, by a bloody mile. Objective measurements confirm this. Distortion and frequency response is a lot worse from pretty well any speakers than from a CD player. Especially if you take into account the fact that the typical room has marked resonant frequencies, which will always put lumps in any frequency response.
Measurements from speakers (alone) are tricky, and require an anechoic chamber, otherwise the pesky room will get involved, and you'll be measuring the room/speaker system.
[i]I also use LS3/5as, which were actually BBC grade 2 monitors designed for monitoring in a outside broadcast van, although mine are upgraded with more-lossy cabinets and external crossovers which bring them closer to grade 1. [/i]
Listening to mine as we speak, and Led Zep as it happens.
Built by my Dad when he worked at R & D department of the BBC at Kingswood.
Top job..
Just to say grum, on my way out, a previous post of mine pointed out the obvious difference between the hifi and the religious (straw man)argument . You have either singularly failed to 1: read it or 2: understand it.
I was in the service planning dept as my first job after uni, several of our rooms were next to the sound dept ones.
Check the back panel of your LS3/5a - are they screwed on - do they look like the pictues just below the
[b]The Kingswood Warren LS3/5As.[/b]
heading on this page:
http://www.g4dcv.co.uk/ls35a/kingswood.html
If so these are some of the prototypes that were built at KW - the production ones had 12mm cabinets and glued on backs instead.
If so they may go for a crazy price on ebay - even crazier than the prices the asians are paying for old rogers and chartwell models.
I've always believed this and various upgrades and tweaks to my hi fi over the year tend to show it too. Speakers make the biggest difference, followed by the amp (pre - power, surround whatever) this is especially true if you listen to more than one source as obviously a good amp speaker combo improves all the sources connected to it.
[i]Check the back panel of your LS3/5a - are they screwed on - do they look like the pictues just below the
The Kingswood Warren LS3/5As.[/i]
Yep my ones are the real deals, before they were licensed.
Cases were hand built by the kingswood cabinet maker, in return for dads collegaues building the cabinet maker a set.
My dad handwound the coils and then matched them in the anachoic chamber - not sure it gets better than that. 🙂
Only mod is that XLR connectors been fitted.
We have another pair in the loft ( licensed ones ), with blown woofers..
Will not be selling them. Just turning volume down a little..
you might be looking at £3k for them, maybe more.
The ls3/5a group on yahoo is run by Paul Whatton - his father was at design dept and brought the LS3/5a to market - Paul has a pair with 001/002 on the back - these have thin wall cabs like yours but I don't think the xovers are as special. They still sound good, but old...
These is a group member named Jim Finnie who also has some 'prototypes' like yours.
Ken Kessler got us a room at the HiFi New shows in 2001 and 2002 where we ran LS3/5as through various tube amps - the rooms were packed all weekend with many people saying we had the best sounding room - needless to say we cheated a bit with the choice of material and we used 001/002.
There are pictures in the gallery on www.ls35a.com.
My pair are in cabinets that are copies of yours - 9mm ply, screwed on backs, which Stirling Broadcast use for their LS3/5as.
I use an 11ohm pair with Cicable external crossovers - they were matched to the drivers but I made the mistake of buying a Bryston amp with its idea of a protection circuit that dumped copies amounts of current into the speaker in response to the slightest static charge meeting its casing 🙁
The Cicables, and the Stirling LS3/5as, which use different drive units, were designed by Deek Hughes, whose father Spencer worked at KW and built the first bextrene cones (using a mattress...) and designed the famous BC-1. Maybe your father knew him. Derek has just designed a new version of the LS3/6, which was a derivative of the BC-1:
http://www.stirlingbroadcast.net/
I am not particularly jealous though - there is something about the bass on 15ohm LS3/5a that I don't like, always seems slow. The same units in JR149s don't seem to be similairly afflicted. Plus the Sp1003 B110s can often get peaky at 1K, fooling people into thinking that they sound better.
The blown pair were given back to my dad about a year ago, and I did a little digging to find that indeed these and the original I have were worth a bit.
I suggested the idea of fixing the blown ones, but the comment was he had no way of tweaking the crossovers so was not worth his while ?? Perfectionist you see..
My Dad was at Kingswood for c. 30 years after starting in service planning, and passed the originals onto me after he bought a pair of Ls7t from whoever it was who set up Rogers .
I went around Kingswood loads as a kid - very cool place.
I am not technical, but if you have any questions I can pass them onto my old man.
J.
you are implying that an 'audiophile' setup is somehow inferior to what they use in a studio - in some cases this may be true but in many it is not - often there is b*gger all difference and the 'audiophile' system may actually use many of the same components, as I am trying to point out but you seem to keep ignoring.
No I'm saying it is different. Audiophile kit is (partly, aside from the wahnk factor)designed to sound amazing and nice, rather than true, it flatters the sound. In the studio the producer needs to hear every detail of the music, every bit of sibillance, every breath, to make a good mix that will reproduce as well as it can on every system. If producers used audiophile kit to mix, the music would most likely sound worse on everyone else's setup, as the audiophile kit is flattering the music. I think someone has already mentioned the 'famous' NS10's, I've not heard them but I have used Adam and some high end JBL monitors, and I wouldn't want them in my living room for recreational listening. If you can you should try your setup against some good monitors and see the difference.
I am ignoring you from now on...
I have had ATCs in my room, and Harbeths, and Spendors. All are 'reference' monitors, with flat responses, etc.
All allow you to hear loads of detail in the music.
Although the speakers were ugly my wife questioned whether we could rearrange the furniture to accomodate the Spendors as they sounded so realistic (she used to play instruments...)
Just because you use poor choices when determining which monitors to populate your studios, it doesn't mean that everyone does.
Woppit, you are being a little hypocritical from a logic point of view, without realising it.
You are absolutely positive of something based on your own actual senses and experience. This is the case with many religious people too. No logical difference.
Saying 'yeah but that's clearly nonsense' is not an argument.
Anyway, as you were.
I worked for Colin Bell, who I think is dead now, but your Dad probably knew him then as he was one of the main engineers in service planning - planned radio 1 going to VHF.
Was there for 2.5 years from 87ish.
Lots of aerials and sat dishes over the grounds when I last looked, where I used to go out and hit 5 irons after lunch after a bit of table tennis and snooker and watching neighbours in the club hut (those were the days of JANE 🙂 ).
Rogers Ls7t
I thought they were pretty ordiniary - he should have got some Spendor SP2/2 - same size and the first design from Derek Hughes - very nice.
Difference is that he probably did as I did and switch cables around repeatedly to determine if the change really was being imagined or if one could be sure of it.
Religeous 'experiences' probably aren't repeatable on demand...
Kingsood was a big part of his life, and he talked in awe about the brains within the place.
Back on topic
Quad used to demonstate their kit with mains cable, and would laugh at anyobe who queried this.
Would quite like a quad pre/power setup,as this was the stuff when I was young, but my old kit is fine for me..
Ls5/9 were the other ones he mentioned worth having..
£3k you say..
Hmm - could buy a bike for that..
Tempted to send the busted ones off to Stirling to get fixed..
Cheers for the info
J.
However, does that mean that if someone told you that they could have a personal conversation with god on demand, you'd give the concept of god more credence?
£3k you say..
Hmm - could buy a bike for that..Tempted to send the busted ones off to Stirling to get fixed..
How are they blown - if the coils are locked up then the drivers are probably done for but if the surrounds are done then some places used to be able to replace the surround.
If the drivers are gone then it is very difficult to find 'BBC specification' SP1003 B110 drive units, as the specification was so tight and was also not on the median of production.
As the drive units are hard to find the Stirling repairs consist of drop in baffles with customised Monacor drive units/crossovers.
Buying some LS3/5as to get donor parts is another expensive way forward. Buying JR149s would be cheaper to get a matched pair but they wouldn't be to the LS3/5a spec.
There may be a few people on the ls3/5a forum with some matched drivers hidden away.
I would join the yahoo ls3/5a group and mention the speakers and that you are thinking of selling the good pair - maybe there is a collector on there who would be interested. If not ebay with a high start price - maybe even 3k to start with.
You may also be able to sell the busted pair to someone who has some in-spec drivers, or something like that.
If you still want the ls3/5a sound I have some of the Stirling versions (V2) you could try - I think they are really good, but it depends on how good the rest of system is as to whether you notice that the crossovers on the KW ones are a lot better.
I think many people see the hand of God or gods in everything on a daily basis.
The only way to be sure of it, is to do a double blind test.
Thanks Mr Turner
Will be keeping the good ones.
Busted ones - I might just send to Stirling..
Cheers for advice
J.
There was a thing in Radio 4 a few months ago about compression and digital radio/FM/MP3 affecting music quality and how hard people even bother trying to achieve a great sound in the studio in the first place.
They had great Bob Stanley (google him!) in and played him the same bit of a Neil Young track twice, once 'as it comes' and once compressed. I couldn't tell the difference at all (probably didn't help listening on a DAB!) but in the studio Bob Stanley guessed the wrong way round. I expect they were using doorbell wire for their monitors. 😕
Plus the feed to the FM transmitters is, or at least used to be, something like 15bit resolution.
Deeply confused by this going round in circles.
Anyway, you guys keep paying for your magicke cables and stuff, if it keeps you happy, as it keeps the rest of us entertained!
you didn't mention how they were busted?
but none of us have magic cables - any time anyone asks about speaker cables on this forum I point them at the Van Damme stuff, which is cheap and the same as the cheap studio cable you keep alluding to.
[i]you didn't mention how they were busted? [/i]
I am guessing they have been overworked and the drivers have burnt out ??
I will get my man on the job to identify the problem.
I think one of the tweeters may be dodgy aswell, and to top off some of the laminate has come off the box.
In truth not pretty..
J.
somebody must have been arguing in their favour, or none of this would have happened.
not really - I just mentioned that my amps seems to really dislike certain fat cables, sounding nastily filtered - although it needed a complicated crossover network to trigger it. Not that any cables can make it sound better. I mentioned that the guy who used to run Spendor also occasionaly saw stability problems with Quad 606s (mine are 707s and 909s, so the same).
Mr Woppit said he experienced differences - I mentioned that his Naim amplifiers were known to need a certain level of inductance to drive into or else they become unstable - so it was entirely possible that he did experience differences as the different cables were likely to have different inductances.
This is a pretty well known 'quirk' of Naim amps and some people regard them as badly designed... Naim recommended their owne cable, which to be fair is not exhorbitantly priced - something like £10 a metre which is trivial if you are buying Naim anyway, as you will need loads of costly extra little boxes to extract the best out of them anyway 🙂
oh right, well what I've been trying to say is, in my opinion
'Audiophile' cables etc costing hundreds and thousands are crazy and pointless. If you want to hear a difference, you will, etc. I'm sure they sound great, but so do £30 cables.
The hardware requirements of mixing/mastering studios aren't the same as the home listener,
and both are why studios aren't decked out with Russ Andrews kit, and magic crystals.
well what I've been trying to say is, in my opinion'Audiophile' cables etc costing hundreds and thousands are crazy and pointless.
Correct me if I'm wrong but I don't think anyone here has disagreed with that, at all, despite several people vociferously re-stating the same point as though someone has.
Honestly, I think some people could argue with themselves.
