It's more of a [url= https://drive.google.com/folder/d/0B1_yFo-SByj6VWNFX3JkUjlxVUk/edit ]lair...
[/url]
I have just bought a flat in peebles. It needs some work. But the basement is potentially way more exciting.
3 mainrooms plus some aditional fritzl type areas. But only the first room is concrete floored the rest apoears to be bare earthed with building detritus and old doors making a "floor".
It appears to be bone dry so what would people recommend as a stopgap flooring solution?
paging Derek Acorah 🙂
Are you suggesting its haunted?
Do you even have to ask? 🙂
The bodies will mostly be under the concreted area, but probably some others under the old doors. Dare say the previous occupants didn't have a chance to finish the job properly
Do you have issues with blood seeping from the walls?
No issues... infact I kind of like it.
I suspect the boddies are in the bricked up chimney breast...
Don't worry, their decaying remains will bubble through eventually and confirm your suspicions.
STW MTB Borders Club crash pad? You've suddenly gained many friends.
Paging Josef Fritzl..
I recommend you get stuck into the living area first! 😛
A few whips, chains and sex swing and you'll have a great place for parties 😯
mcgeordie - Member
POSTED 21 MINUTES AGO # REPORT-POST
Not wrong but I do want to get it useable as storage 🙂
craigxxl - Member
Just to be clear you aren't ANYWHERE near the borders are you?
joat - Member
POSTED 41 MINUTES AGO # REPORT-POST
Feed and water me and you might even get a sofa!
I can be, am I invited to the opening party?
I'm a bit worried what you'd bring as a house warming gift 😯
The clue was in "opening" party
Urethral Sound?
Edit: That's GOT to be a band name!
Urethral Sound?
I'd rather stick metal rods up my knob than listen to a band called urethral sound.
Yes - we know this now.
Spend a weekend with a cement mixer and a wheelbarrow. Put down some DPM first, then give it a good 4 inches on top. Did this below my old flat, and worked a treat, cost a couple of hundred quid in materials and beer for mates to help with the work, and took 2 shifts.
That would require a fair bit of digging and I have other priorities at the moment unfortunately.
The earth is not bone dry, neither is it soaking or muddy and the wood on the floor doesn't seem to be rotting I might dig it level and store everything off the floor
Flag stones on top of a couple of inches of sand?
That's a good shout!
