Need cable to conne...
[Closed] Need cable to connect etrex H to usb on pc ..cheapest option ?
[#1203333]
apologies as I'm slightly confused ..am I correct in thinking that the satandard cable ends in a serial port connector then you need another cable from serial port to usb?
any links to the cheapest efficient option would be much appreciated!!
thanks
Billyboy
Posted : 09/01/2010 5:39 pm
looks good uplink ..thanks!!
Posted : 09/01/2010 5:49 pm
What happened to the cable that came with it? Old models used a serial port connection. Newer ones have a cable that is USB on one end and plugs directly in to the eTrex on the other. I think the eTrex end is standard to, used on a lot of cameras.
Beware, the USB to RS232 adaptors don't all work. I bought one off Fleabay and was dissapointed.
I bought one of [url= http://www.usbnow.co.uk/Adapters_&_Connectors-USB_to_RS-232_Cables/c42_48/p47/USB_2.0_to_RS232_Adaptor_+_1M_Cable/product_info.html ]these[/url] a couple of days ago and it works like a charm with the Etrex.
Posted : 09/01/2010 5:51 pm
stumpyjon - Member
The Etrex H is Garmin proprietry to RS232 and doesn't come c/w a cable. Legend, Vista etc are USB and do.
Posted : 09/01/2010 5:52 pm
