My in ear headphone...
[Closed] My in ear headphones have gine a bit quiet....
[#10177627]
This happened to any of you folks?There only six months old.I guess a build up of ear wax may be responsible.Anyone found a simple solution to this problem or should I just buy another set?Cheers for any help.
Posted : 19/08/2018 8:11 pm
Check your ears and ear buds? Clean them out?
Posted : 19/08/2018 8:12 pm
Sorry,that's gone a bit quiet.
Olive oil of it's your eats
Posted : 19/08/2018 8:38 pm
I don't what make you've got but my etymotics have removable small mesh filters in the end to prevent wax getting down them I removed them altogether as they would clog and quieten the output a lot... that was about 6 years ago and not had an issue since
Posted : 19/08/2018 8:58 pm
Sony mdx or something sounding like that.
Posted : 19/08/2018 10:22 pm
Someone on here told me to run them under a hot tap. I thought they were having a laugh, but I had nothing to lose so have it a try and it only worked.
Posted : 19/08/2018 11:06 pm
Buy some new ears, Mr Lineker should be able to advise further.
Posted : 19/08/2018 11:20 pm
Put kettle on. Fill mug with resulting hot water. Dip the ear bud mesh bit into the water for a few seconds and then wipe on kitchen towel. Repeat until no more yucky smelly wax marks the towel.
Posted : 19/08/2018 11:30 pm
 Del
Check your device hasn't decided the volume is too high.
Posted : 20/08/2018 1:01 am
If your ears are blocked with wax then everything will have gone a bit quiet.
Posted : 20/08/2018 10:54 am
Isopropyl alcohol for cleaning wax off the mesh bit.
Check device volume settings.
Get some Otex for your ears.
Posted : 20/08/2018 11:46 am
Think me lugs are fine.Plug
Posted : 20/08/2018 3:00 pm
